Old 25th February 2012, 14:00   #81  |  Link
yup
Hi All!
Please advice how calculate radius for Gaussian blur based on variance.
radius=3*sqrt(Var)+0.5
or
radius=2*sqrt(Var)
Which right?
yup.
yup is offline   Reply With Quote
Old 27th February 2012, 09:36   #82  |  Link
yup
I find this relation between radius and sigma
http://en.wikipedia.org/wiki/Talk%3AGaussian_blur
yup.
Old 29th March 2012, 17:56   #83  |  Link
yup
Hi all!
When I try update FFTW to 3.3.1 from 3.2.2. I get error with Avisynth 2.6 Alpha 3 build and SeT last build when call unsharp.
I tested with new FFTW fft3dfilter, MVTools and dfttest (not need rename dll) without problem. only variableblur 0.5 (Tritical release) give crash at VirtualDub.
yup.
Old 31st March 2012, 05:24   #84  |  Link
yup
Hi All!
Before I tested Tritical build, now last neuron2 build situation the same. Please help. I use unsharp function for local contrast enhancement. New fft3w give some speed improvement, but impossible use with variableblur.
yup.
Old 31st March 2012, 10:30   #85  |  Link
yup
To be continue....
Last version which work with variableblur dated 30.01.2004. All newer do not work.
yup.
Old 23rd May 2012, 06:58   #86  |  Link
tritical
I updated my modified version of variableblur. Link is same as before. Changes:
  0.6 Fix border=3 bug for gfunc/gfuncc >= 0 (gamma processing was not done on border values)
      Make radius for gaussianblur 4*std instead of 3*std
      Add border=4 (mirroring) option to gaussianblur and make it the default
      Dynamically load fftw (libfftwf3-3.dll) instead of statically linking to old fftw3.lib
      Multithread gaussianblur using OpenMP and use FFTW multithreaded plans
      SSE/SSE2 optimizations. Gaussianblur now requires SSE2 capable cpu.
Biggest change is that variableblur no longer statically links to an old fftw3.lib, but dynamically loads libfftwf3-3.dll (the same way dfttest does). I tested with 3.3.2, but should work with any 3.3 version. I multithreaded parts of gaussianblur using OpenMP so the VS 2010 SP1 redistributable will be required: http://www.microsoft.com/en-us/downl...s.aspx?id=8328
tritical is offline   Reply With Quote
Old 23rd May 2012, 07:52   #87  |  Link
yup
tritical!
Work also with libfftwf3-3.dll.
yup.
Old 24th May 2012, 23:13   #88  |  Link
tritical
Another update. Same link as before. Again changes are for gaussianblur/unsharp.
  0.7 Fix integrate=true giving incorrect results due to lack of precision in weight
         calculation. Now gives results much closer to integrate=false, as would be expected.
      Add support for YUY2, RGB24, and RGB32 input to gaussianblur/unsharp
For YUY2, RGB24, and RGB32 input it just separates the planes out, processes each one, and then merges them back together. This eliminates having to use showred/showgreen/showblue/mergergb to accomplish the task.
Old 25th May 2012, 03:36   #89  |  Link
Reel.Deel
Old 25th May 2012, 07:04   #90  |  Link
yup
tritical!
One more .
Especially for YUY2 support.
yup.
Old 16th November 2012, 07:21   #91  |  Link
fvisagie
yup.
You mean the one under 'Radius again' and not the one under 'Radius'?
fvisagie is offline   Reply With Quote
Old 16th November 2012, 11:54   #92  |  Link
yup
I mean about relation between sigma and radius. Because variableblur use sigma but unsharp mask filter (Photoshop, GIMP and others) use radius.
yup.
Old 24th August 2016, 11:28   #93  |  Link
yup
Hi all!
Now I continue use this plugin mainly for sharpening.Now I am switch to aisynth+ 64 bit and can not find 64 bit plugin for sharpening. IMO unsharp mask make this work better than other for my source (VHS capture).
May be possible compile this plugin for 64 bit?
Or advice sharpening for 64 bit (I see StaxRip bundle and do not satisfy, for my source).
yup.
Old 24th August 2016, 12:00   #94  |  Link
shekh
maybe you could use my VD plugin (link)
Dont know how it compares to binormal implementation.
There is both blur and USM.
Compiled x64 binary is inside the vd packs.
VirtualDub2
Old 24th August 2016, 12:35   #95  |  Link
yup
shekh!
Pack only 32 bit, I am try place blur.vdf to plugin folder for Virtualdub64 and do not see durin load my video.
Or I could load using VDubFilter in script?
yup.
Old 24th August 2016, 12:52   #96  |  Link
shekh
x64 pack is called VirtualDub64_pack_###.zip
VirtualDub2
Old 24th August 2016, 14:43   #97  |  Link
yup
shekh!
support colorspace RGB24?
How call from avisynth script? Syntax?
yup.
Old 24th August 2016, 14:56   #98  |  Link
shekh
It works int rgb32.
Avisynth has method to use VD plugins, this is all I know, try it on your risk
