Old 6th May 2005, 01:39   #21  |  Link
tsp
tsp's Avatar
new version 0.3 . Now includes a "true" gaussian blur
tsp is offline   Reply With Quote
Old 8th May 2005, 15:33   #22  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
coolies. it looks pretty good, though the scaling (is that the right term) isn't what i'm used to.
for instance, gaussian blur of radius 16 is a huge blur in photoshop, but a modest one with your plugin.
of course, i can just use higher numbers
thanks heaps for the true gaussian blur. it's been a long time coming for the avisynth world, and works pretty good.
Old 8th May 2005, 23:05   #23  |  Link
Didée
x' = x^2
, if I'm not fully mistaken.
Old 9th May 2005, 00:54   #24  |  Link
tsp
tsp's Avatar
Originally posted by Didée
x' = x^2
if the radius in photoshop is the standard deviation (sd) then it is correct. The reason I use variance instead of sd is because else the radius in binomial blur would be really odd (like squareroot 2.5) also I changed the old radius to this after the discussion in this thread.
Another thing currently I'm just using this formula to calculate the coefficient:
1/(2*pi*SD^2) * exp(-(x^2+y^2)/(2*SD^2))
but maybe it's more correct to use the mean value for the whole pixel. For instance when calculating the value for the center pixel I just set x=0 and y=0 but wouldn't it be more correct to use the area from x=-0.5 y=-0.5 to x=0.5 y=0.5?
Old 24th May 2005, 23:50   #25  |  Link
tsp
tsp's Avatar
updated the filter to version 0.4. I fixed a bug when convering to unsigned char from float the result wasn't properly converted if outside the 0-255 range. It includes an unsharp filter for sharpening based on the gassianblur code so you can safely use big variance without affecting speed. I also added an option to use integrated gaussian coefficients.
Old 12th December 2006, 07:29   #26  |  Link
bartrobinson
You know what would be really cool? If you could adjust the radius based on the luminance of a secondary clip input.
Bart Robinson
Dynavision|FX
bartrobinson is offline   Reply With Quote
Old 12th December 2006, 11:39   #27  |  Link
tsp
tsp's Avatar
bartrobinson: you mean the average luma of the second clip or local luma?
Get my avisynth filters @ http://www.avisynth.org/tsp/
Old 13th December 2006, 05:48   #28  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
hmm. so you could do fast DOF, huh? or special denoising...
Old 13th December 2006, 13:45   #29  |  Link
Didée
(If you ask me -) not local luma of 1st clip, not average luma of 2nd clip. Local luma of 2nd clip.
Idea is: don't use just one radius for blurring all pixels in a frame, but:
blur each pixel using the radius that is given by luma value of the corresponding pixel in the 2nd clip. I.e. the filter would have two arguments like "min.radius" & "max.radius", and for filtering the 1st clip it would use min.radius where 2nd clip is zero, max.radius where 2nd clip is 255, and inbetween radii for 0<2ndClip<255.
The idea is good (it ever was :D), but I could imagine some problems regarding implementation, or regarding the speed of that filter's performance ... :oh-oh:
Old 13th December 2006, 15:45   #30  |  Link
krieger2005
krieger2005's Avatar
Such a filter would be nice. But the main question is: Where to get this second clip with the luma-information? If the Idea is know where to get this second clip it could be implented directly in the plugin, so does not need a second clip...
krieger2005 is offline   Reply With Quote
Old 13th December 2006, 18:26   #31  |  Link
tsp
tsp's Avatar
It should be possible to modify the binomialblur code so that the radius is dependent on the local luma value. It will be somewhat slower than a normal binomialblur with max.radius. Also only integer values of radius will be supported (this will also apply to the interpolation).
Do you think it will be usefull?
Old 13th December 2006, 19:34   #32  |  Link
bartrobinson
Luma from second clip. Basically a selective defocus or fake depth of field. Yes, it will likely be a little slow. Why only integer radius? Typically depth passes are in 32bit float (second clip). I'm guessing avisynth doesn't support that, so how about a mode to the filter that loads rgba channels separately and then stacks them for 4x256 levels of depth/luma info or some other similar hack.
Bart Robinson
Dynavision|FX
Old 13th December 2006, 20:03   #33  |  Link
tsp
tsp's Avatar
because the binomial blur code works with integer radius (to avoid multiplication in the code). But how strong blur do you need?
Old 22nd December 2006, 19:52   #34  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
One my russian friend (Drakon Rider) reports about some memory leakage with variableblur for big frame sizes 1920x1080, 100 frames eat 2 Gbytes.
img_src size is 4220х3294
I did not test it.
LoadPlugin("VariableBlur.dll")
Function GBlurRange (clip clin, int StartFrame, int EndFrame, float StartBlur, float EndBlur)
  clip_before=Trim(clin, 0, StartFrame-1)
  clip_after=Trim(clin, EndFrame+1, 0)
  clip_proc=Trim(clin, StartFrame, EndFrame)
  clip_proc=Animate(clip_proc, 0, EndFrame-StartFrame, "gaussianblur", StartBlur,StartBlur,3,false,3,3,3, EndBlur,EndBlur,3,false,3,3,3)
  return(clip_before+clip_proc+clip_after)
fps=30
src=ImageReader("img_src.bmp",fps=fps)
src=ConvertToYV12(src)
cl01=Crop(src,0,0,1920,1080)
cl02=Trim(cl01,0,fps*4)
cl02=GBlurRange(cl02,0,fps*4,80.0,0.1)
cl03=Trim(cl01, 0, fps)
stt01=BlankClip(cl02,length=fps*5).Subtitle("My Text01", align=8, size=70, first_frame=0, last_frame=fps*5, text_color=$7FFF00, halo_color=$2F2F2F).Coloryuv(levels="tv->pc")
maskstt01=Tweak(stt01,cont=10.0)
stt02=BlankClip(cl02,length=fps*5).Subtitle("Other Text 02", align=2, size=80, first_frame=0, last_frame=fps*5, text_color=$7FFF00, halo_color=$2F2F2F).Coloryuv(levels="tv->pc")
maskstt02=Tweak(stt02,cont=10.0)
cl02=overlay(cl02,stt01,mode="blend",mask=maskstt01)
cl02=overlay(cl02,stt02,mode="blend",mask=maskstt02)
intro=Dissolve(cl02,cl03,fps)
return(intro)
Old 23rd December 2006, 22:49   #35  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
@tsp: "float *realout;" might need some freeing.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 10th February 2007, 16:52   #36  |  Link
AlanHK
How to install
I've got the file:
variableblur_25_dll_20050524.zip
There are no installation instruction in the text file.
I guessed I should put variableblur.dll in Avisynth's plugins directory.
That didn't seem to make the functions active.
The text file mentioned an fftw file as being necessary.
Fetching that, again no installation instructions, or any text at all. So guessing again I get the fftw3.dll file from this and put it also in the Avisynth plugins directory.
Now I get a different error message when calling GaussianBlur
"LoadPlugin: Unable to load p:\Avisynth 2.5\plugins\VariableBlur.dll"
Which seems a step forward, at least the function seems to be known.
Can anyone advise how to install this?
AlanHK is offline   Reply With Quote
Old 10th February 2007, 17:10   #37  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
I've been confused by this plugin too; I put variableblur.dll (version 0.4) into the plugins folder, only to find that none of the functions described in the accompanying text file were available. There does seem to be a function called variableblur, but that isn't described in the text file!
David
wonkey_monkey is offline   Reply With Quote
Old 10th February 2007, 17:42   #38  |  Link
*.mp4 guy
*.mp4 guy's Avatar
You need to put fftw.dll in your system rout foulder, for windows xp that would be "C:\WINDOWS\Sytem32\".
*.mp4 guy is offline   Reply With Quote
Old 11th July 2008, 00:37   #39  |  Link
Didée
*bump*
Ah, only now I see that the memory leakage of VariableBlur already has been reported.
Any hope to fix that issue? In its current state, VariableBlur is more or less unusable because of the leakage.
(And GaussianBlur is too slow to be a serious replacement, try on 720p or 1080 HD footage...)
Old 19th August 2008, 15:10   #40  |  Link
I haven't seen tsp in a while, so I made the patch. Try this and let me know how it works.
http://neuron2.net/misc/VariableBlur.dll
