20th January 2020, 09:21 | #1321 | Link | |
--------- Error Video encoding using x265 3.2.1+3-b4b2ecac21f6 --------- Video encoding using x265 3.2.1+3-b4b2ecac21f6 failed with exit code: -1073741674 (0xC0000096) The exit code might be a system error code: {EXCEPTION} Privileged instruction. ------------ Video encoding using x265 3.2.1+3-b4b2ecac21f6 ------------ C:\StaxRip-x64-2.0.6.2-beta\Apps\Support\avs2pipemod\avs2pipemod64.exe -y4mp "video_input.avs" | C:\StaxRip-x64-2.0.6.2-beta\Apps\Encoders\x265\x265.exe --crf 20 --preset slow --level-idc 4.1 --output-depth 10 --csv-log-level 1 --ssim --psnr --frames 200000 --y4m --output "video_output.hevc" - avs2pipemod[info]: writing 200000 frames of 24000/1001 fps, 1904x792, sar 0:0, YUV-420-planar-8bit progressive video. y4m [info]: 1904x792 fps 24000/1001 i420p8 unknown frame count raw [info]: output file: video_output.hevc x265 [info]: HEVC encoder version 3.2.1+3-b4b2ecac21f6 x265 [info]: build info [Windows][MSVC 1924][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [warning]: --psnr used with psy on: results will be invalid! x265 [warning]: --tune psnr should be used if attempting to benchmark psnr! x265 [warning]: Specifying a decoder level with constant rate factor rate-control requires x265 [warning]: enabling VBV with vbv-bufsize=50000kb vbv-maxrate=50000kbps. VBV outputs are non-deterministic! x265 [info]: Main 10 profile, Level-4.1 (High tier) x265 [info]: Thread pool created using 16 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 4 / wpp(13 rows) x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3 x265 [info]: Keyframe min / max / scenecut / bias: 23 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 25 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 4 / on / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-20.0 / 0.60 x265 [info]: VBV/HRD buffer / max-rate / init : 50000 / 50000 / 0.900 x265 [info]: tools: rect limit-modes rd=4 psy-rd=2.00 rdoq=2 psy-rdoq=1.00 x265 [info]: tools: rskip signhide tmvp strong-intra-smoothing lslices=4 x265 [info]: tools: deblock sao avs2pipemod[info]: finished, wrote 24000 frames [12%]. avs2pipemod[info]: total elapsed time is 12446.648 sec. avs2pipemod[error]: only wrote 24000 of 200000 frames. Last edited by neo_sapien; 20th January 2020 at 09:26. Reason: prevent breaking tables |
20th January 2020, 22:27 | #1323 | Link |
Hello guys,
I hope you can help me here. What I'm trying to do is, to create a blank video in length of the %Video_Delay% and add it to the start of the encode. I mean, if the source video has 5000 ms delay, I create this 5000 ms delay as blank black video. I'm using Vapoursynth. What I already have is this: clip2 = core.ffms2.Source(r"%source_file%", cachefile = r"%source_temp_file%.ffindex") clip1 = core.std.BlankClip(clip2,length=%Video_Delay%) clip = clip1+clip2 I know it has huge problems. So, What should I do here? I also need to change the delay which is in ms to needed FPS here. |
21st January 2020, 15:55 | #1324 | Link | |
Quality is excellent with QSV (I used the StaxRip "video comparison" tool). I haven't checked every frame , but I did check the usual suspects (dark scenes, fast moving action) and the QSV held up very well. Being very picky, there were some really very minor differences in the dark scenes, but I was impressed with QSV. During normal playback of these scenes I could not see any differences. Settings for x265 (medium preset, CRF 24, 10bit HEVC, aq mode 3), rest of settings at default. Settings for QSV (best quality, ICQ 18, 10bit HEVC, bframes 8, ref frames 5, mbbrc on (per macro block rate control), rest of settings at default. In my previous post, I noted some discrepancies between the ICQ levels for KL and IL, but I was messing around so much with different driver versions and other things that those initial quick tests should probably be ignored. Thus I ended up doing a fresh install of the manufacturer's Win10 image for the above test. It does appear that QSV compression has improved with IL. On KL, I was getting approx ICQ of 21 or 22 equivalent to x265 CRF24 (bit rate equivalents), whereas now on IL, I get the same bitrate with ICQ 18 or 19. The IL QSV encodes at ICQ 18/19 are better than my KL encodes at ICQ 21/22 yet achieving equivalent bit rates. I hope to do a few more movies this way (or at least sections of more movies) and will post if I find anything of note. UPDATE: Checked more dark scenes and QSV still lags a little behind x265 in the really poorly defined dark scenes, where details are not clear even in the original source. The differences on a per frame basis are noticeable but not terrible. Normal playback does not usually expose these differences (to my eyes). I guess for those archive quality videos that you are going to keep forever, then x265 is still the way to go, but IMHO the gap is small between QSV and x265 and seems to be getting smaller with each generation of processor. I'll revisit this if/when new graphics drivers are released (I'm sticking to OEM drivers as trying the latest from Intel made the output worse.) Last edited by ukmark; 22nd January 2020 at 23:13. |
22nd January 2020, 07:49 | #1325 | Link | ||
x264 seems to be working fine without crashing, so I'm doing a workaround - I'm encoding the heavy duty filters that really slow down your encode into x264 qp0 (lossless), then taking that lossless x264 pre-filtered file and running it through x265 using the medium preset and without any additional filters. So instead of spending 25-30 hours running x265, I'm spending 20 hours to build a lossless x264 file, and then spending another 5 hours or so to encode it to x265. This way, if my x265 encode crashes, I only lose up to 5 hours of work, not up to 25-30 hours of work. Last edited by neo_sapien; 23rd January 2020 at 12:44. Reason: x264 working |
28th January 2020, 07:41 | #1327 | Link | |
Some time ago the code for the progress feedback was changed. Original code is Code:
if( last_ts ) bitrate = (double) i_file * 8 / ( (double) last_ts * 1000 * param->i_timebase_num / param->i_timebase_den ); else bitrate = (double) i_file * 8 / ( (double) 1000 * param->i_fps_den / param->i_fps_num ); if( i_frame_total ) { int eta = i_elapsed * (i_frame_total - i_frame) / ((int64_t)i_frame * 1000000); sprintf( buf, "x264 [%.1f%%] %d/%d frames, %.2f fps, %.2f kb/s, eta %d:%02d:%02d", 100. * i_frame / i_frame_total, i_frame, i_frame_total, fps, bitrate, eta/3600, (eta/60)%60, eta%60 ); } else sprintf( buf, "x264 %d frames: %.2f fps, %.2f kb/s", i_frame, fps, bitrate ); fprintf( stderr, "%s \r", buf+5 ); x264_cli_set_console_title( buf ); fflush( stderr ); // needed in windows return i_time; Code:
if( last_ts ) bitrate = (double) i_file * 8 / ( (double) last_ts * 1000 * param->i_timebase_num / param->i_timebase_den ); else bitrate = (double) i_file * 8 / ( (double) 1000 * param->i_fps_den / param->i_fps_num ); if( i_frame_total ) { int eta, eta_hh, eta_mm, eta_ss, fps_prec, bitrate_prec, file_prec, estsz_prec; double percentage, estsz, file_num, estsz_num; char *file_unit, *estsz_unit; fps_prec = fps > 999.5 ? 0 : fps > 99.5 ? 1 : fps > 9.95 ? 2 : 3; bitrate_prec = bitrate > 9999.5 ? 0 : bitrate > 999.5 ? 1 : 2; file_prec = i_file < 1048576000 ? 2 : i_file < 10485760000 ? 1 : 0; file_num = i_file < 1048576 ? (double) i_file / 1024. : (double) i_file / 1048576.; file_unit = i_file < 1048576 ? "K":"M"; if( i_frame_total ) { eta = i_elapsed * (i_frame_total - i_frame) / ((int64_t)i_frame * 1000000); percentage = 100. * i_frame / i_frame_total; eta_hh = eta / 3600; eta_mm = ( eta / 60 ) % 60; eta_ss = eta % 60; estsz = (double) i_file * i_frame_total / (i_frame * 1024.); estsz_prec = estsz < 1024000 ? 2 : estsz < 10240000 ? 1 : 0; estsz_num = estsz < 1024 ? estsz : estsz / 1024; estsz_unit = estsz < 1024 ? "K" : "M"; sprintf( buf, "x264 [%.1f%%] %d/%d frames, %.*f fps, %.*f kb/s, %.*f %sB, eta %d:%02d:%02d, est.size %.*f %sB", percentage, i_frame, i_frame_total, fps_prec, fps, bitrate_prec, bitrate, file_prec, file_num, file_unit, eta_hh, eta_mm, eta_ss, estsz_prec, estsz_num, estsz_unit ); } else sprintf( buf, "x264 %d frames: %.*f fps, %.*f kb/s, %.*f %sB", i_frame, fps_prec, fps, bitrate_prec, bitrate, file_prec, file_num, file_unit ); At the moment, i do some tests in compiling x265 with msvc2019 and a filesize of 7 MB. Stay excited Short question: Does anyone use the -bStylish option of my x265 build? Or is it enough for you to see the estimated size? Last edited by Patman; 28th January 2020 at 08:28. |
29th January 2020, 00:30 | #1329 | Link | |
Definitely Nvenc is the problem, as I have tried it in other ways as well. |
1st February 2020, 07:36 | #1330 | Link |
Hi all, hoping someone can help me please.
I'm using Staxrip 2.0.6.0 stable and I've noticed that subtitles are not being copied exactly from the source MKV. eg: looking at the source file Text #1 ID : 4 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Duration : 23 min 27 s Bit rate : 15.2 kb/s Count of elements : 10888 Compression mode : Lossless Stream size : 2.55 MiB (0%) Title : Signs [kdfss / FFF] Language : English Default : Yes Forced : No Text #2 ID : 5 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Duration : 23 min 38 s Bit rate : 15.3 kb/s Count of elements : 11334 Compression mode : Lossless Stream size : 2.58 MiB (0%) Title : Subtitles [kdfss / FFF] Language : Japanese Default : No Forced : No looking at the output file: Text #1 ID : 4 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Duration : 23 min 27 s Bit rate : 15.2 kb/s Count of elements : 10888 Compression mode : Lossless Stream size : 2.55 MiB (1%) Title : English Language : English Default : No Forced : No Text #2 ID : 5 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Duration : 23 min 38 s Bit rate : 15.3 kb/s Count of elements : 11334 Compression mode : Lossless Stream size : 2.58 MiB (1%) Title : Japanese Language : Japanese Default : No Forced : No MPC-HT will not display any subtitle text from the output file when subtitles for stream 1 are enabled. If I select stream 2 on the output file then the ENGLISH subtitles are displayed (not the Japanese). my Subtitle settings in Staxrip are set to: Preferred Languages: all Track Name: %language_english% Demux Subtitles: All Default Subtitle: None convert sup - disabled Add hardcoded - disabled I believe those settings are default as I haven't messed with them that I can remember. What should the settings be to directly copy the existing subtitles from the source file be please? Thank you. |
1st February 2020, 15:23 | #1331 | Link | |
@craigpro the only thing I can see is that subtitle 1 is set as default in the original file and not so in the output. Last edited by Spunkmeyer; 1st February 2020 at 15:26. |
1st February 2020, 22:05 | #1332 | Link | |
4th February 2020, 00:43 | #1333 | Link |
How to add new AVISynth Filters to StaxRip
How to add new AVISynth Filters to StaxRip?
I have spent several hours reading around and I have to admit that I simply am stumped on how to add a new AVISynth script/filter to Stax. I know how to make new filters in Stax in Profiles I have a few dozen customized filters I use all the time under MyName grouping. I am trying to add AviSynthShader v1.6.5 into Stax so that I can try using many of the GPU shader real time filters that keep coming out that look interesting. https://github.com/mysteryx93/AviSynthShader/releases/tag/v1.6.5 I put the .dll and autoload file in the /plugins64+ folder and then I am lost. I am more lost on how to import the HLSL shaders after. https://github.com/bloc97/Anime4K The new Nvidia sharpen I would like to try and is available as well as Anime4K filters, both of which are real time and of great interest. That being said (as every other ask gets bogged down on what HLSL shaders I use as an example) the main thing I am asking is using AviSynthShader for all those interesting HLSL filters |
8th February 2020, 10:54 | #1334 | Link |
Hello,
anyway of staxrip having the option to automatically remuxing the subtitles files back into the final job, so it doesn't have to be remuxed by manual methods. what i want is the original subtitles string to just be remuxed in the final MKV, as most if not all of my players/streamers can handle native subtitles files now (dvd and bluray pgs). thanks, i'm doing a huge job of many dvd's (episodic tv shows and my wife is italian, so keeping the english subtitle files is a great help for her understanding). |
9th February 2020, 22:51 | #1335 | Link |
Just an observation and an FYI.................
Just thought I'd pass this along.
During testing of StaxRip in conjunction with Intel QSV 10bit HEVC, I accidentally found a way of drastically reducing CPU usage when encoding the video, and not lose any encoding speed. I had already changed in the encoder settings, the "Decoder" (under the "Basic" section), from "Avisynth/VapourSynth" to "QSVEnc Hardware", and that did reduce the CPU usage a little, but not by much. CPU usage was still around 30-35% with no other activity occurring on the laptop. However, by chance, I changed a setting "Async Depth" - this is under the "Performance" section. I changed the value from the default 0 (this appears to set the value at runtime to some random number - often 6 - in my case), to a value of 1. Now my CPU usage ranges between 4-7%!!! Hard to believe the difference. I have done this a few times now just to confirm what I'm seeing. The bottom of the laptop is barely lukewarm. Makes a change from 100% CPU usage with SW encoding. There's not much info out there I could find about Async Depth, but just thought I'd pass this finding on. UPDATE: Just had one file that was encoding at half-speed. I increased the async depth to 2 from 1 and it is now encoding at full speed. CPU usage is still between 4-7%. UPDATE 2: After some quick testing re "async depth", this is what I found on my laptop. It appears that setting this value explicity from 2 to 5 keeps the CPU usage between 4-7%. Also fps encoding speed is identical (so far) regardless of which value you choose between 2 to 5. Setting the value to 1 can cause speed to drop about 50% (but not always). Setting the "async depth" to 0 (default), caused the CPU usage to increase to approx. 35%. There was no fps encoding speed increase. The "async depth" 'chosen' by QSVEnC (or the Media SDK API??) for this video was 6. All of this stuff is new to me, but it would appear a safe bet to set "async depth" to 3 or 4 and leave it there. That's what I plan on doing and if anything changes I'll let you know. Good to know that you can get very low CPU usage with QSV and not lose any speed. I am using ICQ setting (1=best & quality=21), HEVC 10bit, output 720p, and using latest version of QSVEnC (v3.30) and Media SDK API version of 1.30. Laptop is i7-1065g7/12gb ram and 4 cores/8 threads running Win 10 v1909. UPDATE 3: I find that setting "1=best" is required to keep the CPU usage in that 4-7% range, setting it to "balanced" or "fast" sends it back up to 25% or higher (no idea why that is). That's fine by me as I always use that setting. I'm still getting around 90-100 fps, and as I have alluded to in a previous post, I'm finding video quality to be very good with the settings I am using. That excellent "video comparison" tool works really well, and I am seeing very little or no difference between the QSV encode and ones done with SW encoding using the "medium" preset with CRF 24, x265 720p 10bit HEVC, (also set aq-mode to 3 and aq-strength between 0.7 and 1). I have compared about five movies so far and every comparison is extremely close between HW and SW encoding. Also, bitrates are reasonably close between HW and SW and I have had 2 movies so far where the HW bitrate was lower than the SW with equivalent (or very similar) quality. These were Captain Marvel and Avengers Infinity War. QSV seems to do a really good job with the modern digital format movies, where the image is very clean and has very little or no grain. Considering the speed difference between HW and SW (about 3 to 4 times faster with HW), the drastically reduced CPU usage (less than 10% vs 100% with SW encoding) and the very acceptable quality of current HW encodes I am getting, then this will be default from now on. I'll only revert to SW encoding if the quality is poor for a HW encode. Last edited by ukmark; 14th February 2020 at 15:53. |
10th February 2020, 00:49 | #1336 | Link |
I'm brand new to Staxrip, so when I took a look at the options list and got hit with... where do I start
First I'll start with my goal, transcode 4k blu rays to H.265 for space storage with as little video degradation as possible. Of course saying 'as little degradation' will make some people say then just don't transcode, however, other than the loss of HDR, when I was using handbrake, I managed to get extremely good quality with H.265 file sizes. You couldn't tell which video looked worse with my settings. That was comparing using a sdr monitor, so the color looked the same. But now that I have seen the light of a 10 bit pipeline, I want to take advantage. So my question is this, what needs to be adjusted in the huge list of options to get the best quality to size videos. I'm not afraid of having 2 systems run 24/7 as I'm used to having 24-34hr transcode times per 4k movie on HB. So far I have changed the preset to slow and mode to quality, with a value of 18. For video I don't know what else needs to be touch. Additionally for audio, I don't want anything to be transcoded, just pass through. Do I just set it to Copy/Mux the audio I want? I swear somewhere I read you want all or non under 'Demux Audio'... but I'm not sure. |
14th February 2020, 18:20 | #1337 | Link |
Major VCEEncC v5.02 update for AMD cards.
-Only Win10 is supported. -Updated the version of AMF to 1.4.14-> 1.4.16. Requires AMD Radeon Software Adrenalin Edition 20.2.1 or later. -Added an option for pre-anaysis added in AMF 1.4.16. (Valid only in VBR mode, VCEEncC only) (--pa, --pa-sc, --pa-ss, --pa-activity-type, --pa-caq-strength, --pa-initqpsc,- -pa-fskip-maxqp) -Added the option to calculate ssim / psnr. (--ssim /-psnr) ...and more. https://onedrive.live.com/?authkey=%...%21516&o=OneUp
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
15th February 2020, 23:35 | #1339 | Link |
Is this an Intel bug?????
Came across something I've never used before on my new shiny i7-1065g7 laptop - "fixed function encoding" setting in StaxRip.
Thought I'd give it a try and....!!! Tried h264 encoding with the best (slowest) preset, output to 720p, ICQ method, and used QSVEnc decoding. Encoding speeds reached ..... over 500fps!! The resulting file is of very good video quality and file sizes are not excessive. Can't find much on the web regarding what settings are changeable (if any), when using fixed function encoding (I assume the term "fixed function" is self-explanatory). I can see that it ignores the number of b-frames selected and sets this to 0 in the encode log. Looks like you choose the decoder, preset, profile, level, encoding method and quality setting, and output resolution. With h264 if I change the ICQ setting from say 24 to 26, the resulting file size is reduced as you would expect. However, with h265, changing the ICQ level has no effect on the file size produced. Does this seem like an Intel bug with h265 ICQ on fixed function encoding, or is it a QSVEnc bug (rigaya) or even something in StaxRip?? BTW, speed on h265 10bit is 350fps using same settings as for h264 and video is very good quality. File sizes are approx 30-50% smaller than h264. Any feedback welcome - also if anybody can shed more light on fixed function encoding and what settings are available. I've also asked the question on rigaya's QSVEnc github. Ta! UPDATE: If encode method is VBR or QVBR-q, then changing the quality (or bitrate for VBR) does affect output file size for h265 when "fixed-func" is activated. Just does not currently work for ICQ and h265. I did find some notes on rigaya's github that "fixed-func" gave a lower quality output when activated. TBH, on Ice Lake, quality looks very good to me. I know that Intel touted improved QuickSync performance on Ice Lake - maybe this is why the quality has improved for fixed-function encoding? (I don't have anything to compare it with - but to my eyes, quality is very comparable to SW encoding). I've uploaded 4 images from the "video comparison" tool showing 2 versions of "Star Trek Into Darkness". First version is 10bit HEVC SW encoded with CRF 24, x265, medium preset (encode used 100% CPU and achieved around 25-30fps). Second version is 10bit HEVC HW encoded with ICQ fixed-function (unknown quality setting due to issue above, used 25% CPU @ 350fps!). There is a tiny bit more detail on the face of Spock and Khan. However, watching the footage, you'd be very hard pressed to see any differences. Fixed-function file size is 20% bigger (bit rate ~1200kbps vs ~1000kbps on x265). I also encoded fixed-function to h264 8bit with ICQ setting. The file size is 40% larger than the h265 fixed-function version (bit rate ~1700kbps). Quality on this is also very good and encode achieved over 500fps. I've uploaded the freeze frame of Khan from h264 fixed-function encode also. It would be difficult to go back to SW encoding. I can accept a very tiny drop in quality (and 20% larger files), in return for vastly improved encoding speed and much reduced CPU usage. Last edited by ukmark; 16th February 2020 at 18:00. |
19th February 2020, 01:39 | #1340 | Link |
I can't figure out why my encodes with AAC audio keep getting an error. AC3 works fine but AAC does not. I think it has something to do with "CoreAudioToolbox 7.10.9.0" but I've followed the instructions for extracting the dll files from the itunes downloader with the make portable script and moved those dll files into the same folder as the qaac64.exe file yet i still get an error.
qaac 2.68, CoreAudioToolbox 7.10.9.0 ERROR: Not available input file format Anyone having success using qaac and AAC audio? |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
