Old 13th January 2020, 20:57   #421  |  Link
gpower2
gMKVExtractGUI author
gpower2's Avatar
Originally Posted by jpsdr View Post
Hello, thanks for your tool.
Any idea of rough ETA of the "soon", as this information is now 2 months old ?
Probably sometime this week.
gpower2 is offline   Reply With Quote
Old 16th January 2020, 19:46   #422  |  Link
gpower2
gpower2's Avatar
gMKVExtractGUI v2.5.1
Hey people! New year, new version! This is actually a minor fix version, basically fixes the issues with the long delays reported from @2-perf.
As always, enjoy!
Download link:
https://sourceforge.net/projects/gmk....1.7z/download
Changelog
v2.5.1
  • Fix finding delays with newer mkvinfo versions
  • Optimize finding delays with mkvinfo by searching only for tracks that couldn't find delays with mkvmerge
Old 17th January 2020, 14:39   #423  |  Link
redbtn
redbtn's Avatar
As always, enjoy!
Hey! Thank you!
redbtn is offline   Reply With Quote
Old 26th January 2020, 19:44   #424  |  Link
gpower2
gpower2's Avatar
Hey people! This is a minor version, fixing a bug I discovered by accident (those are the best! ).
As always, enjoy!
Download link:
https://sourceforge.net/projects/gmk....2.7z/download
Changelog
v2.5.2
  • Fix issue in checking for an existing job when adding a new job
Old 17th February 2020, 01:39   #425  |  Link
mbcd
Any chance to get a function to remux all together again?
I have a series with lots of episodes where I want to remove all languages I dont understand. So basically there are two languages I need left in all episodes.
It is easy to demux those streams with gMKVExtractGUI by selecting those languages, thats very comfortable doing for all episodes together.
But how to remux all together again to mkv (including chapter, delays, metadata -> language-ID).
With mkvmerge you can do this, but not very comfortable, lots of clicks needed and every episode has to be done manually.
Any chance for a function that not demuxes all mkvs, but only using selected, so "keep" instead of "demux" ... (streams selected streams/tracks into a new file)
mbcd is offline   Reply With Quote
Old 17th February 2020, 10:15   #426  |  Link
sneaker_ger
MKVToolNix GUI can do this automatically:
1. Preferences>Multiplexer>When dropping files>Create one new ... for each file
2. Preferences>Multiplexer>Enabling Items>Only enable copying of tracks with specific languages by default
3. Drag&Drop all your source files
4. Multiplexer>Actions for all tabs> Start multiplexing (, or Add to job queue and then start the jobs)
Old 17th February 2020, 10:19   #427  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Hmm...
gMKVExtractGUI is an extraction (de-muxing) application. If you want a re-muxing application (along with track/stream selection) then MKVToolNix GUI is the way to go
Old 17th February 2020, 16:11   #428  |  Link
mbcd
@sneaker_ger:
Damn, never got this feature. Thank you very much for pointing to it, will try it!
@SeeMoreDigital:
Yeah, its also some kind of extraction ... you extract specific tracks out. I think extraction does not mean you get always multiple files for each track, so it was not so far away from being "legit" to ask for it.
You can extract tracks directly into a new mkv, or is there another word to describe this type of extraction better? Of course it is always also some kind of remuxing. But without saving it to seperate files I would call it "extracting into single file".
Demuxing is a clear process (with multiple output) in my eyes, but extracting is a bit unprecise and gives some room for interpretation ...
Old 17th February 2020, 20:21   #429  |  Link
lvqcl
Remuxing.
lvqcl is online now   Reply With Quote
Old 5th April 2020, 05:48   #430  |  Link
gendalv
suggestion: add an option to batch export standard mediainfo information into txt files with file names
also are there other tools that can do this in a couple of clicks?
I've found this manual https://pastebin.com/V5jt5Zai
but it creates ANSI .txt files, which isn't inclusive enough - if file names contain Japanese or other symbols, how to make it create UTF-8/BOM files ?
gendalv is offline   Reply With Quote
Old 5th April 2020, 08:53   #431  |  Link
tormento
Acid fr0g
tormento's Avatar
gMKVExtractGUI v2.5.2
You can do from MediaInfo GUI itself, both txt and CSV, customizing the fields you need.
Simply drop the whole bunch of files you need to index and export what you want.
@turment on Telegram
Old 7th April 2020, 09:45   #432  |  Link
gendalv
mkvtoolnix doesn't come with a mediainfo gui, I've tried an official one, but it does the same thing - creating ansi text files when custom is selected (to have a individual .txt per video option) and requires a template too
Old 7th April 2020, 15:34   #433  |  Link
tormento
Acid fr0g
tormento's Avatar
Never complain about free work of people or they could reply "do it yourself".
MediaInfo has its own GUI and, I know, create a custom template is a PITA. It took me 45 minutes last week to create a custom CSV sheet for my movie collection. But, hey, it's the "price of free software".
Old 11th April 2020, 11:40   #434  |  Link
gpower2
gpower2's Avatar
Hey man, I understand the validity of your request, however you' re barking at the wrong tree here! :P
gMKVExtractGUI has only one use, to extract data from matroska files.
What you're asking is to extract information from media files, so MediaInfo is the tool to use. Perhaps you could make a request to MediaInfo.Net project which is a GUI for MediaInfo.
Old 8th May 2020, 02:49   #435  |  Link
RainyShadow
Would it be possible to disable the "Success" dialog? Or, at least make it non-blocking?
RainyShadow is offline   Reply With Quote
Old 9th May 2020, 01:53   #436  |  Link
gpower2
gpower2's Avatar
Just uncheck the "Popup" checkbox on the bottom left part of the form.
Old 9th May 2020, 10:03   #437  |  Link
tormento
Acid fr0g
tormento's Avatar
If you had a dime for every person who asked, you could afford yourself, well, a Coke.
Much better to set is disabled in the next version.
Old 9th May 2020, 12:19   #438  |  Link
gpower2
gpower2's Avatar
Haha! Indeed! :P
I am thinking of changing its name to something more intuitive like "Show Success Dialog", I believe this would so it.
Old 9th May 2020, 17:54   #439  |  Link
RainyShadow
Thanks!
I thought that was related to "Jobs" somehow, heh.
A tooltip would be fine too, in case "Show Success Dialog" takes too much space. Or just move it to options.
Old 9th June 2020, 13:17   #440  |  Link
tormento
Acid fr0g
tormento's Avatar
@gpower2
Sometimes I have to extract the same tracks from different files, where the only thing that changes is the file name.
In the mean time that you find a solution, could you expose the command line, such as mkvtoolnix-gui.exe does?
So I can create batch file, while you are thinking to how to automatize that.
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui
