Old 14th August 2019, 17:37   #6981  |  Link
benwaggoner
Originally Posted by jlpsvk View Post
@benwaggoner
any thought about aq-mode 2 vs aq-mode 4?
CPUs have been too busy doing other things! But I'll kick them off now.
Ben Waggoner
My Compression Book
Old 14th August 2019, 20:53   #6982  |  Link
brumsky
I'm looking forward to your results as well. I tested hevc-qa and it was bad... I had weird banding and everything was smoothed out really bad.
brumsky is offline   Reply With Quote
Old 14th August 2019, 23:53   #6983  |  Link
markiemarcus
I've had positive results with HEVC-AQ on animation; in part due to it taking AQ strength out of the equation.
Live action not so much.
markiemarcus is offline   Reply With Quote
Old 15th August 2019, 00:34   #6984  |  Link
benwaggoner
I'm running a 2-pass veryslow Tears of Steel encodes at 1 Mbps ABR comparing aq-mode 2, 3, 4 and aq-hevc. I should have some clips to evaluate tomorrow.
Ben Waggoner
My Compression Book
Old 15th August 2019, 01:23   #6985  |  Link
markiemarcus
It has actually surprised me how much variation there is between them. I've only really tested extensively on animation, often at 720p where the problems are more noticeable. The trouble really starts when you disable SAO, but you often have to in order to preserve high frequency detail. The artifacts resemble a mixture of ringing and mosquito noise around dark lines.
Under these circumstances Aq mode 1 is by far the most prone to distortion and though it's subjectively more detailed, I don't like it, unless the source has a lot of grain where it can be quite useful. Aq mode 2 is much less prone to distortion, but grain can look soft and it's noticeably poor in low luma. Aq mode 3 generally works well, but it's often a sub optimal usage of bits, especially if only fleeting scenes are low luma. That's usually where Hevc-aq does rather well (though Cbq and Crq need a -1 nudge down). I find it to be the most predictable and least troublesome in motion.
Aq mode 4 I don't really know what to make of. With grainy animation it seems a little more detailed than Aq mode 2. Just to clarify again that the above is all for animation; I haven't looked at the metrics and I don't have much experience with live action.
Looking forward to your results! I'm a long time lurker.
Old 15th August 2019, 10:11   #6986  |  Link
Boulder
Pig on the wing
Boulder's Avatar
1 Mbps is quite low already, it would be nice to see some results with average bitrate around 7-8 Mbps or so.
Old 15th August 2019, 21:47   #6987  |  Link
benwaggoner
I'd expect there's be a lot of convergence at high bitrates. I'm most interested in how the different modes do when they don't have enough bits to do it right.
I'm also replicating the procedure from my encoding challenge, for apples-to-apples
https://forum.doom9.org/showthread.php?t=175776
Ben Waggoner
My Compression Book
Old 17th August 2019, 00:34   #6988  |  Link
tebugg
3900x cpu usage
hello everyone. i am seeking a little bit of help with cpu usage. i have an amd ryzen 3900x overclocked to 4200mhz. it is on an msi x570 godlike mobo. so the vrm's are the best. i currently can only get between 70-80% cpu usage on the first pass. on the second pass it drops down to 60% usage. this is encoding a 4K video file that was originally encoded with x265 from my cell phone. is there a way for me to squeeze out more usage from x265's settings?
edit: on crf the encoder maxes out all the cores. also on x264 with 2pass and crf both max out the cores.
tebugg is offline   Reply With Quote
Old 18th August 2019, 16:04   #6989  |  Link
Forteen88
Herr
Originally Posted by tebugg View Post
i currently can only get between 70-80% cpu usage on the first pass. on the second pass it drops down to 60% usage..
If you can, then you should do 2 encodes at the same time.
Forteen88 is offline   Reply With Quote
Old 20th August 2019, 06:30   #6990  |  Link
LazyNcoder
Hello guys,
Any specific commands to encode HDR10+?
--transfer smpte2094 instead of --transfer smpte2084? is it enough? Does it work at all? because I couldn't find smpte2094 on x265 documentations ...
Edit:
Nope.
x265 [error]: invalid argument: transfer = smpte2094
Is there something wrong with my build?
LazyNcoder is offline   Reply With Quote
Old 20th August 2019, 07:46   #6991  |  Link
kabelbrand
Compression mode: Lousy
kabelbrand's Avatar
There is a command line switch to insert HDR10+ metadata but you'll need a separate tool e.g. from Samsung to process your source file for metadata creation.
https://x265.readthedocs.io/en/defau...on-dhdr10-info
kabelbrand is offline   Reply With Quote
Old 20th August 2019, 08:15   #6992  |  Link
LazyNcoder
Thank you.
1- What if the source we already have is HDR10+? Can we somehow extract or bypass the metadata into x265?
2- What tool from Samsung exactly? or any alternative
Old 20th August 2019, 13:05   #6993  |  Link
kabelbrand
kabelbrand's Avatar
I guess you'd have to be a HDR10+ adopter to get access to the Samsung tools (JsonFromVideo, Hdr10PlusGenerator) or instead use a software like Colorfront Transkoder.
Old 20th August 2019, 16:55   #6994  |  Link
filler56789
SuperVirus
filler56789's Avatar
Maybe off-topic but probably a necessary notice...
«After much consideration, we’ve decided to remove Mercurial support from Bitbucket Cloud and its API. Mercurial features and repositories will be officially removed from Bitbucket and its API on June 1, 2020.»
https://bitbucket.org/blog/sunsettin...t-in-bitbucket
filler56789 is offline   Reply With Quote
Old 21st August 2019, 04:46   #6995  |  Link
quietvoid
Thank you.
This might be useful for you: https://github.com/quietvoid/hdr10plus_parser
quietvoid is offline   Reply With Quote
Old 21st August 2019, 08:19   #6996  |  Link
LigH
LigH's Avatar
@filler56789: Good to get this notice way ahead ... enough time for the x265 team to possibly move the repository to either a different hoster or a different versioning system... (I would assume rather the first, since they love funny version tags which annoy some compiler suites not expecting their syntax).
New German Gleitz board
Old 22nd August 2019, 10:16   #6997  |  Link
kabelbrand
kabelbrand's Avatar
hdr10plus_parser
Thanks, good work! Even though the Samsung Hdr10PlusInjector tool does not like this JSON format I guess as long as x265 is happy that's good enough.
For reference I attached the raw JSON output from my test. There are some additional indexes and ids in the Samsung output but these might be optional.
Old 22nd August 2019, 14:24   #6998  |  Link
quietvoid
Yes, if I remember correctly x265 just adds the metadata for each frame encoded, scene related info is ignored.
At the time of development (possibly now too), HDR10+ titles also have metadata inserted at every frame, and not like 1 SEI message per scene.
After all, some of this is trial and error using x265 as "correct" implementation.
There is still some desync between source JSON and extracted where there is a metadata change (scene change?), but it's usually just 1-2 frames that are different.
Old 22nd August 2019, 18:39   #6999  |  Link
benwaggoner
You want to use --dhdr10-opt. That'll insert the SEI only on IDR frames and frames where the metadata changes.
Note that dynamic metadata isn't necessarily static across a shot; if there are dramatic changes in a shot, than there likely will be mid-shot metadata.
Ben Waggoner
My Compression Book
Old 22nd August 2019, 23:16   #7000  |  Link
quietvoid
I'm aware of x265's --dhdr10-opt, but I prefer to keep it the same as the source (which seems to always be for every frame).
Not sure if it would affect compatibility as well.
