Old 25th February 2013, 09:57   #17741  |  Link
andybkma
Hi madshi, hate to bother you while you are working out the kinks with Smooth Motion but I was hoping I could sneak in a feature request whenever you get a chance.
Like many users of mVR I am sitting on my couch with just my mouse with no ready access to a keyboard (using my projector). As far as I know there is no way to bring up the "Debug OSD" (Ctrl+J) without a keyboard. Could you possibly add a way to turn that OSD on/off inside the settings of mVR with just the mouse? Like with a checkbox or something?
BTW, been using the Smooth Motion turned on the past coupla days and am really enjoying. Haven't had any blatant judder/motion problems that I can tell like other people have reported but then again I am not able to turn the Debug OSD on in order to actually tell if I am having such dropped frames problems. Perhaps ignorance is bliss haha (Note: just using HD4000 Ivy Bridge CPU graphics with Zoom Player, with a combo of LAV & ffdshow post processing with avisynth Limited Sharpen Faster)
andybkma is offline   Reply With Quote
Old 25th February 2013, 11:02   #17742  |  Link
Dodgexander
Originally Posted by Dodgexander View Post
If you can change the flush settings and it works, what is the problem?
I don't have any of the problems mentioned with a Radeon HD6870 so sadly can't help out.
Maybe it's only related to certain gpu's
Okay I encountered this problem also. To fix it, I just lowered the upscaling and chroma upscaling from jinc 4 taps each to 3 taps each.
I guess this suggests that for lower gpu's might suffer from using the new motion compensation when also using scaling they were before. Perhaps you guys can try lowering the scaling settings to next to nothing to see if the problem goes away?
Dodgexander is offline   Reply With Quote
Old 25th February 2013, 16:04   #17743  |  Link
DragonQ
OK, changed my mind, both of the problems I experienced with 0.86 still exist with 0.86.1 (previous frame repeating when seeking sometimes, plus weird frame order randomly appearing and disappearing with interlaced content ).
HTPC Hardware: Intel Celeron G530; nVidia GT 430
HTPC Software: Windows 7; MediaPortal 1.19.0; Kodi DSPlayer 17.6; LAV Filters (DXVA2); MadVR
TV Setup: LG OLED55B7V; Onkyo TX-NR515; Minix U9-H
Old 25th February 2013, 17:16   #17744  |  Link
chros
chros's Avatar
Buying new laptop for hd playback with madvr/lavfilters/mpc-hc
Sorry if this question is off topic, but I urgently (within 2 weeks) have to buy something new for me, because the laptop I'm currently using (see my signature for details) goes to my mom.
There was a really long discussion here a year ago, but I don't know the current hardware trend since then. So can you recommend a really good bargain "today"?
So I need:
- screen: 15,6" , fullhd
- chipset: intel, with HD4000 integrated VGA (at least it was good a year ago)
- vga: nvidia 6xx , with kepler core(?) (at least it was good a year ago) , I don't need the best GPU today.
- at least 8GB RAM
- hdd: big
- usb3.0
- hdmi out (audio and video)
- webcam, wifi
Thanks for helping!!!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 25th February 2013, 17:30   #17745  |  Link
DragonQ
Any i3/i5 Ivy Bridge CPU setup will last a long time. 8 GB of RAM makes sense due to RAM being so cheap now.
FYI, the Intel HD4000 can't handle Jinc with AR for everything in MadVR, so the best you can do is Bicubic75 AR / Lanczos3 AR / Catmull-Rom AR LL. I think you need an GTX 660 or better for Jinc3 AR, not sure about the mobile versions though.
Old 25th February 2013, 17:58   #17746  |  Link
Dodgexander
I did some further testing with my other, less powerful pc.
First of all, on both my pc's it seems any kind of dxva with smooth motion is a no go, presumably because the scaling+smooth motion takes up so much GPU usage as it is.
With my HD6870 system, I can run max Jinc3 upscaling and chroma upscaling with smooth motion. Without smooth motion jinc4 is possible with anti ringing filters on both.
With my HD5670 system, I can't run anything with smooth motion, otherwise like above (other people have reported) my rendering queue is always 0-3 despite everything being at low and all performance options included. This results in dropped frames and an unwatchable experience. This system however also has a slower CPU than my other. A 2.5ghz dual core wolfdale compared to a 4ghz dual core wolfdale. Without smooth motion it can manage only Jinc3 upscaling and spline3 chroma upscaling, anti ringing turned off.
Its clearly a performance issue, since during busy motion, the rendering queue will often drop all the way to zero, from being perhaps 1 before.
So is smooth motion just too demanding for lower end graphics cards?
Old 25th February 2013, 18:08   #17747  |  Link
detmek
Does it work better if you use FSE? Usually I have far less problems or no problems with FSE.
detmek is offline   Reply With Quote
Old 25th February 2013, 18:32   #17748  |  Link
Dodgexander
For me fse was a no go on my less powerful pc, all my testing was done using it on there. Tried with aero on and off also.
Old 25th February 2013, 18:46   #17749  |  Link
joe42
The 50 test pattern is more demanding than the 23-25 test patterns, of course (twice as much work to do for madVR). The 59 and 60 test patterns probably run with smooth motion frc turned off on your PC, that's why they run without frame drops for you.
With the 50Hz test pattern and FRC on, GPU is at 65% max, and CPU is much lower, so I'm not sure what is causing the frame drops.
But like I said, with 0.86.0 and the exact same settings, no frame drops. But with 0.86.1, continuous framedrops.
joe42 is offline   Reply With Quote
Old 25th February 2013, 18:50   #17750  |  Link
chros
chros's Avatar
Thanks for the answer!
What do you think about this? Lenovo Y580 with GTX660
Old 25th February 2013, 19:18   #17751  |  Link
oddball
When disable desktop composition in fullscreen mode is enabled with window overlay it does not disable Aero. Normal?
oddball is offline   Reply With Quote
Old 25th February 2013, 19:44   #17752  |  Link
baii
660m should handle about 1080@30i deinterlanced to 60 with jinc 3 AR chroma, no scaling.
the y580 is a good overall multimedia machine, check sony S15 if you can live with buttonless trackpad.
baii is offline   Reply With Quote
Old 25th February 2013, 19:46   #17753  |  Link
THX-UltraII
I have a general question:
I just found out that my Intel Graphics 2000 has a buggy driver and 0-255 output is not supported. Will I lose any quality if I put the whole chain on 16-235 instead of 0-255?
THX-UltraII is offline   Reply With Quote
Old 25th February 2013, 19:47   #17754  |  Link
DragonQ
I'm not sure but what is people's obsession with disabling Aero anyway? This isn't the early 2000s, things tend to work better with GPU accelerated GUIs, plus Aero prevents tearing.
Old 25th February 2013, 20:15   #17755  |  Link
oddball
I read conflicting info.
"You should disable it for playback of video, especially on multiple monitor setups, because Aero has a built in anti-tearing algorithm that gunks up smooth video playback. A lot of times when your flash video looks choppy, it's because of Aero."
Old 25th February 2013, 20:30   #17756  |  Link
Budtz
Is a sharpener on the to do list for madvr?
Budtz is offline   Reply With Quote
Old 25th February 2013, 21:02   #17757  |  Link
n3w813
Watched Skyfall BR this past weekend with Smooth Motion enabled for 23.976 at 60Hz. Looked very nice and smooth, not a single issue with several pauses and seeks throughout the ~140 minute film.
Thanks for all your continued effort on MadVR, Madshi!!
[OT]*Great film btw, not as good as Casino Royale though[/OT]
n3w813 is offline   Reply With Quote
Old 25th February 2013, 21:15   #17758  |  Link
Niyawa
Niyawa's Avatar
I'm almost sure it will. PC uses a 0-255 and every time I use a 16-255 instead, it looks awful. Black colors tend to lose it's touch that way.
madVR scaling algorithms chart - based on performance x quality | KCP - A (cute) quality-oriented codec pack
Niyawa is offline   Reply With Quote
Old 25th February 2013, 21:44   #17759  |  Link
yahyoh
yahyoh's Avatar
i'm having weird problem O_o
i can play 1080p @60fps or 23 FPS or 30FPS with chroma upscaling : bicubic and image up scaling : Jinc and AR without any frame drops but some 1080p ( on full screen and on windowed ) @25fps or 720p @25 fps or 60fps (only in full screen ) are dropping frames like hell IDK why
and i can play 1080P 10bit @30fps without single frame drops with the same setting
edit: i tried to set both to bicubic and 720p @25 and 60fps (in full screen ) stopped dropping frames but 1080p @25 fps still dropping frames in fullscreen and windowed
BTW i'm using latest Madvr + latest Lav + latest MPC ( with AMD 5470M GPU )
yahyoh is offline   Reply With Quote
Old 25th February 2013, 23:39   #17760  |  Link
turbojet
Switching from gpu decoding (lavf cuvid) to cpu (ffdshow libav) reduced framedrops from 100-200 a minute to 1-2 a minute on average. An obvious suspect would be gpu load but I don't think that's it because after changing any of the numerous madvr settings (flush, overlay, separate device) with frc enabled I can play 3 videos simultaneously with gpu decoding without framedrops for 15 minutes or so. It might be a conflict between gpu decoding and frc that gets reset after changing madvr settings, until something triggers the issue again.
andybkma: In the meantime you can use autohotkey, nothing needs to be installed, open the installer with 7zip and extract compiler and au3spy. Make a text file and rename it to .ahk and then enter something like this:
#NoTrayIcon
#IfWinActive ahk_class TMainForm
lButton & rButton::Send, ^{j}
lbutton::Send {lButton}
return
Compile this with ahk2exe.exe (older compiler) in the compiler directory and run the compiled exe. This should toggle stats when you left click then right click while zoom player is the active window. Feel free to change it to whatever key combination you want, the keylist may help. Au3spy.exe can be useful for getting window titles, classes, mouse positions, etc. for programs to set hotkeys for.
I'm only posting about autohotkey here in case anyone else is interested in similar functionality. I won't discuss it anymore in this thread but feel free to pm me about it.
