Old 18th January 2012, 13:45   #11881  |  Link
nx6
Playing with MKV files...
nx6's Avatar
You might try the option labeled "Madshi Video Renderer" that's right under your current selection.
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8
nx6 is offline   Reply With Quote
Old 18th January 2012, 13:49   #11882  |  Link
Asskicker2
But that's there no matter if I install it or not? :P
Asskicker2 is offline   Reply With Quote
Old 18th January 2012, 13:58   #11883  |  Link
nx6
nx6's Avatar
Have you tried it already to see what it does now, or are you just being difficult on purpose? -__-'
Old 18th January 2012, 17:53   #11884  |  Link
zmaster
nvidia user
PotPlayer shows «supported VR's», not «installed VR's» .
You will see madVR in this list, even if you install PotPlayer x64-build.
zmaster is offline   Reply With Quote
Old 19th January 2012, 15:46   #11885  |  Link
Weirdo
Sorry, I'm a bit confused with DXVA support. Is it now possible to use madVR with GPU acceleration on an ATI card? Tried mpc-hc 1.5.3.3965 with Microsoft's Video Decoder and LAV Video but it didn't work (ATI 5670).
Weirdo is offline   Reply With Quote
Old 19th January 2012, 16:10   #11886  |  Link
sneaker_ger
It is possible with one of the newest LAV Video preview versions that can copy the DXVA decoded picture back into the RAM, but its stable version does not have that feature yet.
Old 19th January 2012, 19:33   #11887  |  Link
RBG
Weirdo
Yes it is possible, you can use cyberlink video decoder in HAM mode, either DXVA Without Rendering mode in Daum Potplayer. Both work fine, but consume more resources than pure DXVA.
RBG is offline   Reply With Quote
Old 19th January 2012, 19:51   #11888  |  Link
wanezhiling
Originally Posted by RBG View Post
Weirdo
And LAV dxva2(copy-back)
Old 20th January 2012, 04:59   #11889  |  Link
woody777
When I try to play MKVs (standard definition dvds) in MPC-HC using Madvr, I get the message "Madvr Reports: deinterlacing failed" when I press control J.
The error just repeats over and over in red text and there is no other information on the screen.
The MKV plays, but I want to know how to correct the error.
woody777 is offline   Reply With Quote
Old 20th January 2012, 20:26   #11890  |  Link
Pillars of Creation
Feature request:
active screensaver while paused video
a) after x minutes
b) use os default
Screen saving to avoid plasma burn in
Pillars of Creation is offline   Reply With Quote
Old 22nd January 2012, 10:51   #11891  |  Link
secvensor
Whether and it is possible to introduce not only video codecs, but also support of playing of a sound through ASIO?
Bypassing distortion by a mixer windows and by that having raised and tonal quality.
Win7x64
Core i7 920 3.5GHz
Noctua NH-D14/ArcticCooling MX-3
6(3x2)GB Transcend 1426MHz
RoyalHD (64MB)[Solo6c][JPLAY]/HD7850DC22GD5V2[EIZOT965]
Seasonic X-750
VelociRaptor WD4500HLHX/16TB_STORE
secvensor is offline   Reply With Quote
Old 22nd January 2012, 11:12   #11892  |  Link
Paladin77
Why not Use WASAPI Exclusive? (you can set that up in Reclock)
Motherboard: GIGABYTE GA-990FXA-D3
Processor: AMD FX 8150 Black Edition 8-core @3.6 Ghz.
RAM: G-Skill Ares 16GB dual channel DDR3.
GPU: 2X Crossfire AMD RADEON HD 6850.
OS: Windows 7 Utlimate x64.
Paladin77 is offline   Reply With Quote
Old 22nd January 2012, 11:36   #11893  |  Link
e-t172
The Windows Visa/7 audio engine does not introduce distortion. In fact it should be bit-exact if the input sample rate matches the configured sample rate.
e-t172 is offline   Reply With Quote
Old 22nd January 2012, 11:52   #11894  |  Link
secvensor
Whether and madvr it will be supported j.player(in exclusive mode)?
Options allow, but at all hangs.
There by the way interesting render costs too.
Win7x64
Core i7 920 3.5GHz
Seasonic X-750
Old 23rd January 2012, 15:05   #11895  |  Link
Skwelcha
<(ovO)>
Can someone tell me what the Problem with this file is? When i open the file MPC-HC just gets into pause. I added the madvr log but i have this problem with any player and any renderer. Hope you dont mind that i still ask this in this Thread...
Mediainfo:
Complete name : G:\title00.mkv
Format : Matroska
Format version : Version 2
File size : 2.78 GiB
Duration : 23mn 31s
Overall bit rate : 16.9 Mbps
Encoded date : UTC 2012-01-23 13:05:16
Writing application : MakeMKV v1.7.0 win(x64-release)
Writing library : libmakemkv v1.7.0 (1.2.0/1.1.0) win(x64-release)
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 23mn 31s
Bit rate : 15.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.255
Stream size : 2.60 GiB (93%)
Language : English
Default : Yes
Forced : No
MadVR 0.92.9 x64, MPC-HC, LAV 0.70.2, GV-N1060G1 GAMING-6GD @ 385.41, LG OLED65B7D, Denon AVR-1912, Windows 10 Pro 1709 x64, i7-6700k
Skwelcha is offline   Reply With Quote
Old 24th January 2012, 20:43   #11896  |  Link
bozokaydin
I have Nvdia GTX 590, Amd 1090T and using MPC-HC+LavFiters+Madvr. Regardless of the video size, i had dropped frames after 15 minutes. No dropped frames before 15 mins. I have to restart video every 15-20 mins to have zero dropped frames. I can not find the problem. Is there any one can offer a solution?
bozokaydin is offline   Reply With Quote
Old 24th January 2012, 20:48   #11897  |  Link
LigH
LigH's Avatar
Clean your GPU cooler from dust?
New German Gleitz board
Old 24th January 2012, 21:07   #11898  |  Link
bozokaydin
I clean it but it does not fix it
Old 24th January 2012, 21:22   #11899  |  Link
pirlouy
_
I think it's a bug since I don't have it with EVR or Overlay. And I would not understand why madVR would need to write datas to disk:
To achieve this, you just have to launch a video (with madVR default settings for example), look at your task manager, you will see this happening rather quickly. But even if it were normal during playback, it is persistent when video is paused. This is what makes me think it is a bug.
Sorry if I'm totally wrong. I'm just a basic user trying to read numbers he does not necessarily understand.
Old 24th January 2012, 23:42   #11900  |  Link
manni500
Madshi Video Renderer & PotPlayer
Not sure if this is the right place for my query or if I should go over to the PotPlayer section.
Here is my problem: when using Madshi as the Video Renderer, the brightness & contrast controls of PotPlayer do not work. However, the controls work perfectly if I use "Auto Selection" (in other words let PotPlayer choose the Video Renderer)
Am I missing something or doing something wrong? Note: I am using the exact same configuration proposed by imouto (http://imouto.my/configuring-potplay...omment-page-5/)
Thanks for your help
PotPlayer v1.5.31490
Windows 7 Ultimate (32-bit)
manni500 is offline   Reply With Quote
