Old 8th February 2018, 23:59   #48901  |  Link
mclingo
Originally Posted by jkauff View Post
MediaInfo isn't always correct. What's the madVR OSD say the frame rate is? I get symptoms like this when a video is really 29.97, despite what MediaInfo reports. Seems to happen mostly with converted TV shows.
thats what I thought initially but it plays fine at 23.976 using the EVR renderer.
Madvr clocks it as 23.976
Old 9th February 2018, 00:20   #48902  |  Link
mclingo
3D
My system is now fully stable for 3D, no more messing around with batch files, dropping into 1080p etc etc, no dropped frames, just perfect playback. I mentioned this before and i'm hoping MADSHI will get chance to look at it at some point. MADVR refresh rate switching for 3D is broken, at least for AMD cards so i've switched to using it in my player instead, MPC / KODI DS. Now all my 3D movies, start, skip and stop correctly and smoothly with no loss of HDMI and no machine crashes.
If you are a bg 3D fan and your're not a gamer I would certainly recommend and AMD card over Nvidia, the caveat being the AMD cards tend to have less processing ability so you are slightly limited to what MADVR goodies you can throw at it.
Old 9th February 2018, 23:12   #48903  |  Link
steakhutzeee
steakhutzeee's Avatar
Here for asking what I think is a noob question
Using madvr on files on my PC I have no dropped frames.
But with dvd discs I've a lot of them, continuously increasing as the movie goes on. Why this? There is something wrong I'm doing?
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 10th February 2018, 00:51   #48904  |  Link
ryrynz
ryrynz's Avatar
Look at your OSD.. look at your loads
Old 10th February 2018, 03:03   #48905  |  Link
steakhutzeee
Sorry, what I've to look at exactly?
Old 10th February 2018, 03:44   #48906  |  Link
ryrynz
ryrynz's Avatar
Post screenshot of your OSD. Check CPU and GPU loads make sure nothing is ~80+%
Old 10th February 2018, 09:33   #48907  |  Link
stefanelli73
Originally Posted by mclingo View Post
3D
Hello, could you kindly tell me what you did exactly to have a stable 3d without dropped frames? I have an AMD RX480
stefanelli73 is offline   Reply With Quote
Old 10th February 2018, 14:00   #48908  |  Link
mclingo
yeah sure.
Firsty if you press control J what do the first two lines say, it should say something like:
display 23,97598hz
composition rate 23,976
Old 10th February 2018, 14:37   #48909  |  Link
el Filou
el Filou's Avatar
Originally Posted by steakhutzeee View Post
Using madvr on files on my PC I have no dropped frames but with dvd discs I've a lot of them, continuously increasing as the movie goes on.
I also have something weird happening with DVDs and madVR, while playing SD MPEG2 TS files always work just fine. I have posted screens of the OSD showing an issue but nobody noticed/had any answere unfortunately: https://forum.doom9.org/showthread.p...13#post1832113
Try pausing/unpausing your DVD playback a few times, or seeking a few seconds back. When I do that it usually stops dropping frames. I have no explanation for this.
Old 10th February 2018, 15:44   #48910  |  Link
steakhutzeee
Here is my osd, cpu is ok, don't know how to check gpu load.
[SPOILER]
[/SPOILER]
Tried to pause/unpause like @el Filou suggested but nothing changed.
Don't know why but with dvd I can't select a specific point of the playback in the seekbar. I can skip to next/previous chapter tho. I use mpc be and with vlc I can instead. This is off topic I think but maybe you know why this happens.
Thanks!
Old 10th February 2018, 17:26   #48911  |  Link
mclingo
Here is my osd, cpu is ok, don't ....
Try again with MADVR playing at the correct rate.
I find its best to play movies in there default rate, your skips will likely be caused by MADVR changing up from 23,976 hz to 60 hz.
do you have 1080p23 or 2160p23 set as a display mode in MADVR? do you have refresh rate switching turned on in MADVR?
Old 10th February 2018, 17:37   #48912  |  Link
el Filou
el Filou's Avatar
Here is my osd, cpu is ok, don't know how to check gpu load. https://uploads.tapatalk-cdn.com/201...c95a9cb643.jpg
What's happening is your PAL DVD is being deinterlaced as video to 50 fps ('frame = 20 ms') and your rendering times are higher than the resulting frame time so you get dropped frames.
If this is indeed a video source then you need to lower your scaling settings.
If this is a film, enable IVTC or manually disable deinterlacing by pressing the shortcut (that's what I do), then it will play at 25 fps/40 ms per frame.
Old 10th February 2018, 18:54   #48913  |  Link
steakhutzeee
I never touched the screen rate options in madvr, screenshots in spoiler, don't know how to do the changes you suggest. And why you talk about 23.976 if movie is 25.000?
Can you help me?
I'm on a FullHD monitor setted on 60hz.
[SPOILER]
[/SPOILER]
Old 10th February 2018, 18:56   #48914  |  Link
steakhutzeee
What is IVTC? So I have to simply disable deinterlacing when running a DVD movie disc?
What's difference between video source and film?
I added screenshots in post just before this.
Old 10th February 2018, 19:50   #48915  |  Link
el Filou
el Filou's Avatar
What is IVTC?
IVTC is InVerse TeleCine. It analyses frames to try and reconstruct the original cadence before the conversion to TV/DVD. It can, among other cases, for example reconstruct 24p film converted into 60i back into 24p (so called 3:2 cadence), or 25p converted into 50i back to 25p (so called 2:2 cadence). Your PAL DVD is the second case. However, IVTC uses some processing power, and madVR runs it on the CPU, so if you can avoid it then you gain a few ms.
If the only material you watch on DVD is movies and the DVDs are PAL, then yes. It's easy because when a cinema movie is put on a PAL DVD, it's simply accelerated 4% to 25 fps, then each frame is plit in two fields to give 50i. If you just disable deinterlacing, the fields (half-frames) are just combined back together into 25p.
Note that some TV series are also shot on film, and some parts of cinema movies on disc can be video, like some end credits, so you need to test with each film (or enable IVTC and accept the few ms of additional processing).
Video is natively captured in 50i (or in 50p and then converted to 50i for TV/DVD/HD Blu-ray), so if you disable deinterlacing with true video, you'll end up with stuff like that: https://larryjordan.com/assets/nxltr69/interlace-01.jpg
Check madVR's keyboard shortcuts configuration, there are shortcuts for toggling deinterlacing between auto/off/on, and for forcing film/video. Test and see what each does to playback.
Old 10th February 2018, 20:04   #48916  |  Link
stefanelli73
yeah sure.
display 23,97598hz
Yes, both the display and the composition rate can be found, sometimes having a high rendering while having low settings in madvr
Old 10th February 2018, 20:42   #48917  |  Link
steakhutzeee
IVTC is InVerse TeleCine. It analyses frames to try and reconstruct the original cadence before the conversion to TV/DVD. It can, among other cases, for example reconstruct 24p film converted into 60i back into 24p (so called 3:2 cadence), or 25p converted into 50i back to 25p (so called 2:2 cadence). Your PAL DVD is the second case. However, IVTC uses some processing power, and madVR runs it on the CPU, so if you can avoid it then you gain a few ms.If the only material you watch on DVD is movies and the DVDs are PAL, then yes. It's easy because when a cinema movie is put on a PAL DVD, it's simply accelerated 4% to 25 fps, then each frame is plit in two fields to give 50i. If you just disable deinterlacing, the fields (half-frames) are just combined back together into 25p.
Note that some TV series are also shot on film, and some parts of cinema movies on disc can be video, like some end credits, so you need to test with each film (or enable IVTC and accept the few ms of additional processing).Video is natively captured in 50i (or in 50p and then converted to 50i for TV/DVD/HD Blu-ray), so if you disable deinterlacing with true video, you'll end up with stuff like that: https://larryjordan.com/assets/nxltr69/interlace-01.jpg
Thank you very much for the complete explanation!
So,
Disabling deinterlacing works, and no dropped frames with video mode.
With deinterlacing on 'if in doubt deactivate' (as i always have) , and forced to movie mode, no fps drop. (possible?)
So I simply setted madvr to force movie mode and now I have not to press anything, (not touched deinterlacing setting).
I can use these settings for movies I've on my PC so not on dvd discs?
I tried and switching between source type (on a movie on my PC) I see 1.movie with deinterlacing off 2. Movie 3.video
What's the difference between 1 and 2?
>>So I assume I can safely completely disable deinterlacing because I never see true video but only movies? Deactivating 'automatically activate deinterlacing when needed'? Or it's useless because I m forcing movie mode?
>>Forcing movie mode automatically enable IVTC? So I have to install anything and I can leave the deinterlacing option active on 'if in doubt, deactivate'?
Btw, I still continue to can't navigate through the movie selecting a point in the seek bar. Why this? (only on DVD discs).
What's the use of the settings in the first two screeshots i posted in spoiler previously? Those settings refer to this problem too?
Thanks again and again!
Old 11th February 2018, 14:55   #48918  |  Link
Clown shoes
King of the Jungle
Clown shoes's Avatar
Afternoon all. I have Madvr set up to render all my content via Kodi DSPlayer and everything is working perfectly except for a couple of movies out of over 1000 that are dropping frames like nobody's business.
I have a 4K display and a GTX 1060 and my upscaling is set to NGU sharp (high) which seems perfect for 99% of my content resulting in 0 frames dropped, however with these problematic movies I'm forced to drop NGU sharp down to low if I want to avoid dropped frames.
The movies in question don't appear to be anything special; 1080p, not particularly high bitrates, certainly no more demanding than some of the material I throw at my setup, however they are completely unwatchable.
Can anyone suggest the best way to troubleshoot this?
Clown shoes is offline   Reply With Quote
Old 11th February 2018, 15:08   #48919  |  Link
the frame rate of the movies would be interesting. maybe deinterlancing?
Old 11th February 2018, 15:27   #48920  |  Link
SamuriHL
SamuriHL's Avatar
Post an osd cap with one of the titles that's giving you trouble so we can take a look.
Sent from my Pixel XL using Tapatalk
