Old 7th November 2016, 11:24   #39981  |  Link
Sunset1982
can't wait to see NG1 in action. Hopefully my RX480 can handle it to upscale 108p to UHD. We'll see...
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 7th November 2016, 12:39   #39982  |  Link
HillieSan
I hope so.
HillieSan is offline   Reply With Quote
Old 7th November 2016, 19:38   #39983  |  Link
InstantAli3n
InstantAli3n's Avatar
i have to ask this:
https://abload.de/img/whyv10wspi.png
WHY?
How did you get that extended breakdown of the rendering stats? I can't find any way to see that. Just the overall with CTRL + J.
EDIT: Oh there's a guide http://forum.doom9.org/showthread.php?t=171787
I just made a blank file named ShowRenderSteps in the madVR folder and that enabled it. That would be neat if it had a shortcut like CTRL + SHIFT + J or something.
InstantAli3n is offline   Reply With Quote
Old 7th November 2016, 20:08   #39984  |  Link
kasper93
MPC-HC Developer
@madshi: Do you plan, is it possible to optimize hue preserve option for HDR content? High quality option looks way better, but tanks performance. With some bare bone options it already hitting the 16ms mark. https://i.imgbox.com/rVty1gQZ.png I'm just curious, HDR content is probably still not something to invest much time.
kasper93 is offline   Reply With Quote
Old 7th November 2016, 20:41   #39985  |  Link
may try a displaycal smpte 2084 3D LUT.
i don't know what settings are close to preserve hue. maybe render intent: preserve saturation.
it should be faster and "better" in general quality.
Old 7th November 2016, 21:30   #39986  |  Link
kasper93
MPC-HC Developer
@huhn: Exactly what I needed. Thanks for tip.
Old 8th November 2016, 01:10   #39987  |  Link
Warner306
+1 to adding this as a keyboard shortcut.
Old 8th November 2016, 13:00   #39988  |  Link
Mistery 73
madvr 4k
a greeting to all, I need your advice from experts,
I upscalare 1080p to 4K in madVR image doubling is better to use NEDI or super -xbr sharpness 150? I have a video card gtx 1070
Mistery 73 is offline   Reply With Quote
Old 8th November 2016, 14:51   #39989  |  Link
kolak
When can we expect HDR flagging on HDMI?
Based on this looks like it's possible:
https://developer.nvidia.com/display...nuts-and-bolts
Old 8th November 2016, 15:09   #39990  |  Link
Asmodian
I like super-xbr 100 over NEDI but I like NNEDI3 more if you have the performance, I am not sure how the 1070 performs.
madVR options explained
Old 8th November 2016, 15:44   #39991  |  Link
fedpul
Hi, Mistery 73, following the recommendation from Asmodian I would say that you can use NNEDI3 easily at 32 Neurons with that card depending on the rest of your madVR config. If you want a cheaper option I would use super-xbr 100 or either super-xbr AB 25.
fedpul is offline   Reply With Quote
Old 8th November 2016, 15:46   #39992  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
i have to ask this:
WHY?
Why do you have so many steps in there? I don't understand what you're trying to do or why...
My render report looks much simpler...
Georgel is offline   Reply With Quote
Old 8th November 2016, 15:50   #39993  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
It's understandable that waifu2 is still not within our grasp GPU wise, but some day GPUs will be strong enough to do it, and I guess we will see it by then!
That new algorithm looks amazing!
Can't wait to have it included in madVR!
Great job madshi! Love the difference in the results!!!
Old 8th November 2016, 16:08   #39994  |  Link
http://forum.doom9.org/showpost.php?...ostcount=39994
Old 8th November 2016, 16:23   #39995  |  Link
nevcairiel
madshi usually doesn't like vendor-specific solutions, but with Microsoft dragging their feet with a generic thing, maybe he might make an exception.
It seems to be a combination of NvAPI extensions to signal metadata, and the new (or rather, re-defined) fp16 surfaces for floating point HDR video samples (as defined by Microsoft, so that part is cross-vendor, hopefully).
Definitely looking forward to proper HDR pass-through in 2017.
If only HDMI 2.0 would have allowed for 4K, 444, 10-bit. When do we get a new one that does that?
Old 8th November 2016, 16:31   #39996  |  Link
Mistery 73
thanks for the advice .... then in image doubling imposed NNEDI 32 neurons and how should I set chroma upscaling NNEDI 3 64 neurons and superRes 4?
Old 8th November 2016, 16:49   #39997  |  Link
leeperry
Kid for Today
I'm contemplating getting a BenQ EX3200R when it'll be out very soon, long story short Windows 1DLUT's when outputting 8bit from mVR killed dynamics but this becomes a non-issue when outputting 10bit from mVR I presume? The windows desktop LUT will be applied in 10bit as well?
I can't seriously be hassled to build 3DLUT's, I prefer to go with a general D65 windows CLUT and map gamuts with a PS script using PotP profiles based on resolution and/or framerate.
My expectations are around NNEDI3 128-256 neurons worth of hogging.
that good ole crystal ball huh.
Old 8th November 2016, 16:52   #39998  |  Link
Mano
i read guide about setting up madvr and lav. Most guide tell me to disable all the source filter but doing so my mpc can't open h265 file anymore (or i get audio relapse for video with flac audio).
Is there anything wrong with my set up or it is a normal thing?
Mano is offline   Reply With Quote
Old 8th November 2016, 16:56   #39999  |  Link
just leave all activated. using external or internal lavfilter doesn't really matter.
Old 8th November 2016, 18:17   #40000  |  Link
Warner306
I'd go with super-xbr. NEDI is too soft/blurry.
With that card, NNEDI3 would be possible and preferred. Chroma upscaling can be set to something lower like super-xbr. Then you can use all of your resources on image doubling (32 to 256 neurons).
