27th January 2014, 11:44 | #18961 | Link |
Here are the settings
[Options] VERSION=0.46.0.5 MULTIPROCESS=1 HC_PROFILE=BEST DEFAULT_LANG=eng ENABLE_TEST=1 ENABLE_BLANKING=0 IMPORT_FOLDER=D:\ KEEP_HD_LPCM=1 DEINTERLACER_TYPE=3 UPRESIZE=LanczosResize SD_PROGRESSIVE=1 MIN_M2TS_SIZE=0 REMOVE_IMPORT=1 USE_ZLIB=0 MODE=3 ENCODE_QUALITY=3 ONEPASS_ENCODING=0 AUTO_QUALITY=0 MENU_BACKGROUND=D:\IMPORTS\4.jpg IMPORT_THRESHOLD=15 QUICK_PLAY_THRESHOLD=10 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP= SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=1 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=1 USE_FILTERS=0 BDMV_CERT_ONLY=1 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=1 OUTPUT_3D=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=33000 TARGET_SIZE=33000 MOVIEONLY_TYPE=6 ALTCRF=18 ALT_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 AUTO_BURN=0 MENU_AUTO_BACKGROUND=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 [Paths] WORKING_PATH=W:\MKV\ SOURCE_PATH=I:\CHERNOBYL_DIARIES\ DGIndexNV=C:\Program Files (x86)\dgdecnv\DGIndexNV.exe DGDecNV=C:\Program Files (x86)\dgdecnv\DGDecodeNV.dll |
27th January 2014, 14:44 | #18963 | Link | |
27th January 2014, 15:33 | #18964 | Link |
I am on it and will let you know.
[Update] I use MPC-HC and it works for me with and without ffdshow. However I just demux and mux again with nothing added and removed and used tsmuxer 2.6.12
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 27th January 2014 at 15:54. |
27th January 2014, 16:43 | #18966 | Link | |
[01/27/14] BD Rebuilder v0.46.05 (beta) [12:18:08] Source: MISTERIOS_DO_NILO_00001 - Input BD size: 10,48 GB - Approximate total content: [00:47:38.814] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1280x720, 448Kbs DD5.1 - Output folder: E:\VIDEOS\ - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [12:18:08] PHASE ONE, Encoding - [12:18:08] Processing: VID_00001 (1 of 1) - [12:18:08] Extracting A/V streams [VID_00001] - [12:25:13] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 68.543 frames - [12:25:13] Reencoding: VID_00001, Pass 1 of 1 - [12:46:31] Video Encode complete - [12:46:31] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [12:47:39]PHASE ONE complete [12:47:39]PHASE TWO - Rebuild Started - [12:47:39] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [12:48:56] - Failed to REBUILD ---------------------- [01/27/14] BD Rebuilder v0.46.05 (beta) [13:04:48] Source: MISTERIOS_DO_NILO_00001 - Input BD size: 10,48 GB - Approximate total content: [00:47:38.814] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1280x720, 448Kbs DD5.1 - Output folder: E:\VIDEOS\ - Decoding/Frame serving: DirectShow [3-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [13:04:50] PHASE ONE, Encoding - [13:04:50] Processing: VID_00001 (1 of 1) - [13:04:50] Extracting A/V streams [VID_00001] - [13:08:04] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 68.543 frames - [13:08:04] Reencoding: VID_00001, Pass 1 of 1 - [13:32:49] Video Encode complete - [13:32:49] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [13:33:58]PHASE ONE complete [13:33:58]PHASE TWO - Rebuild Started - [13:33:58] Building ALTERNATE OUTPUT Structure [13:34:45] - Encode and Rebuild complete - IMPORT folder removed. [13:34:45] JOB: MISTERIOS_DO_NILO finished. |
27th January 2014, 19:49 | #18967 | Link |
Ive been having an odd situation lately where no matter what settings i use for making mkv/mp4 files, the file sizes keep coming out to be 4.30gb range, regardless of the length of the movie. Ive never had this issue before in the past and most of my files would usually be around 2-3gb range. Has anyone else experienced this? Have a possible solution? Ive tried both DirectShow and X264/LAVF, but not DGD.
27th January 2014, 20:12 | #18968 | Link | |
27th January 2014, 20:50 | #18969 | Link |
I think this should be the last one. Also, sorry if im attaching these wrong, not sure how you guys are doing the scrollable attaching, its been a while for me since ive attached stuff in forums lol.
I have been using CRF 23 |
27th January 2014, 23:01 | #18971 | Link |
Sorry it took so long to reply, just got home from work.
Here is my ALTERNATE.TXT just in case you still need to see it. Code:
# The options below show up in the Alternate Output Dialog # Settings: # caption=Text to show on alternate selection list # vBitrate=Bitrate to use for two-pass video encoding, * = variable (DVD only) # aBitrate=Bitrate to use for audio encoding, * = automatic (not allowed for iPod & iPad) # aType=Output Audio Type, 0=AC3, 1=AAC (Note: Audio bitrate less than 384Kbs implies stereo downmix) # 2=[Intact audio -- MKV & MP4 only] # vFormat=Video Format: 0=320x240/180, 1= 480x360/270, 2= 640x480/360, 3= 1024x768/576, # 4= 1280x720, 5= 1920x1080, 6= 720x480/576, 7= No Resizing, 8=Intact # vKeyint=Video GOP size (interval): Default=24, "Auto" = 10x framerate (MKV & MP4 only) # cType= Container/limits type, 0=iPod (mp4), 1=MKV, 2=iPad (mp4), 3=DVD-5, 4=DVD-9, 5=MP4 6=iPad 2+ (MP4) [00001] caption=DVD-5, 720x480/576, AC3 Audio vBitrate=* aBitrate=* aType=0 vFormat=6 cType=3 [00002] caption=DVD-9, 720x480/576, AC3 Audio vBitrate=* aBitrate=* aType=0 vFormat=6 cType=4 [00003] caption=MKV Container, 720x480/576, 448Kbs DD5.1 vBitrate=872 aBitrate=448 aType=0 vFormat=6 cType=1 [00004] caption=MKV Container, 720x480/576, Intact Audio vBitrate=872 aType=2 vFormat=6 cType=1 [00005] caption=MKV Container, 1920x1080, 640Kbs DD5.1 vBitrate=5120 aBitrate=640 aType=0 vFormat=5 cType=1 [00006] caption=MKV Container, 1920x1080, Intact Audio vBitrate=20000 aType=2 vFormat=5 cType=1 [00007] caption=MKV, Intact Video, Intact Audio aType=2 vFormat=8 cType=1 [00008] caption=MKV Container, Intact video, 640 kbs DD5.1 vFormat=8 aBitrate=640 aType=0 cType=1 |
28th January 2014, 00:42 | #18973 | Link |
I had to rerun a job, which was no big deal, since .m2ts files don't have to be reencoded(depending on a few factors). Rebuilder decided to use Jdobbs default picture instead, despite my renaming my file, to the appropriate name.
I had renamed his, to "menuback DEFAULT.jpg". Rebuilder still used it. So, the next time around, I called it "JD background". That did the trick. It's possible that "I" screwed up somehow, so I'll be looking into this further. Just thought I'd report back on this.
Only one rooster, need be in the hen house... |
28th January 2014, 02:04 | #18977 | Link | |
28th January 2014, 08:46 | #18979 | Link | |
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
