16th January 2020, 00:29 | #18241 | Link |
Like i said encoderserver.exe needs only avisynth.
Booting from pxe seems to be very complicated. Personally i would use some cheap pendrives as boot drive. Wintousb should be able to create so called windows-to-go.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th January 2020 at 00:37. |
16th January 2020, 00:43 | #18242 | Link | |
Grumpy Old Man.
I have a small render farm (6 dual cpu systems), and I have used small SSD drives, so each unit has an individual Windows OS installed. With my VERY limited understanding of PXE booting, don't you require a dedicated "client" to host the PXE Windows image ?? As I use different clients for different jobs & day's, I doubt this would work, as there would be multiple IP's floating around, so for me, I doubt this would work. And if Atak says it's very complicated, then it must be !!!!
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
16th January 2020, 00:49 | #18243 | Link |
You need one "server" to host the image, of course.
That would be the machine the EncodingClient runs on I'd think. It makes only really sense if you want a very centralized approach, with one Master and many slaves. As long as your DHCP works properly the IP thing should not be a problem. There a very small free Tools that do both the tftp-server and the bootloader. If someone creates a Tutorial on how to implement a working smb share, avisynth and encodingserver.exe into a working pe image, for implementing it yourself would be a peach. I knew nothing about pxe, and it took me 15min to find the right sources and get into a Windows10Pe. I'm to stupid to integrate my own software into the image though and I'm not very good with the commandline myself. Atak does stuff with creating custom image's, his signature reminds us with every post, so I thought that might be worth looking into. Maybe even have it build into RipBot for version 2.0 or something Last edited by HehoChef; 16th January 2020 at 00:52. |
16th January 2020, 02:46 | #18244 | Link |
Grumpy Old Man.
So I tried that file on another pc, and it worked fine...and I'm running W10 with an AMD RX 480.
The pc it still doesn't want to work on has a GTX 1080, with the very latest drivers...and in fact, now MPC-HC won't play ANYTHING on that pc..
16th January 2020, 02:53 | #18245 | Link | |
Grumpy Old Man.
It does play with MPC on my laptop, but is very choppy. But playing it with VLC, was perfect. I wonder if Atak could give us some options to what player the preview uses !?!?!?
16th January 2020, 05:11 | #18246 | Link | |
When my 2 encodes finished and I removed the completed jobs, I ran into the same problem trying to either close or show the icon from the tray.
If anyone has any ideas about this application hang on Windows Server 2019, please let me know. Thanks. Quote:
16th January 2020, 16:22 | #18247 | Link | |
ByteShare
Only issue I've had with MPC is on some computers the AVISynth preview will show an image and some won't but they'll both show an error if there is one, although on some I have to change the playback position (seek bar) to see the error. |
17th January 2020, 01:15 | #18248 | Link | |
Grumpy Old Man.
but next time I'm using RB on WS2K19, I will check it out. edit:- I have noticed this behaviour in W10, depending on how you shut RB down, to how the taskbar icons co operate (sometimes) they just like to sit there, and you can't do too much with them.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 17th January 2020 at 07:25. |
17th January 2020, 01:26 | #18249 | Link | |
Grumpy Old Man.
It's just a little odd that it works on AMD cards, but not on my best nVidia.....I don't "fiddle" with the settings, either. There must be another issue So I will report back, after reset. edit:- well a reset fixed the problem, but I'm not sure what caused it, in the first place. But I'm still having some issues with it, using Preview...it either doesn't want to play the clip, or it takes a LONG time to open it.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 17th January 2020 at 07:21. |
17th January 2020, 16:51 | #18250 | Link | |
ByteShare
As for the preview issues, I've never really been able to figure those out myself. On some of my machines it works fine and others I really can only use it as an AVISynth error test. I use AVSPmod to test scripts and actually see the output on a lot of machines now: https://github.com/gispos/AvsPmod/releases |
18th January 2020, 10:42 | #18251 | Link |
Grumpy Old Man.
Welcome to v1.25.1 for 2020
Hey guys, a nice new autoupdate...
Atak has been busy...there's a new Core, ES, EC versions, lsmash, x265, mpc, scripts, etc. And apparently, NO Java, from now on
18th January 2020, 23:20 | #18252 | Link | |
Emperor building empire
Thanks much It's all good Pascal |
20th January 2020, 01:50 | #18253 | Link |
ByteShare
Since switching to only LSmash the good news is that the unicode naming thingy issue doesn't stop you from adding a job and encoding it, but the bad news (and it is a small thing) is the name changes:
"test ¡;#¦_“’` test.mkv" > "test í;#ª_ôÆ` test.mkv" Question about the update, what is the number represent in the Encoding Client underneath each server in the black box with white text? Last edited by byteshare; 20th January 2020 at 02:00. |
20th January 2020, 04:03 | #18254 | Link | |
Grumpy Old Man.
https://forum.doom9.org/showthread.p...61#post1893261
21st January 2020, 05:37 | #18256 | Link | ||
ByteShare
21st January 2020, 11:04 | #18257 | Link |
Just add video=ConvertToYUV420(video)
21st January 2020, 20:54 | #18259 | Link | |
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
21st January 2020, 21:41 | #18260 | Link |
I'm very sorry if this has been asked before:
I couldn't help but notice that the UI has become a lot better over the last couple versions, but I'm not always sure what it means: Especially the "Encoding Client" gives out a lot more informations now, about the state of the server. Is there anywhere a longer readme or a explanation what all the blinking red, green, blue, yellow lights mean? |
