Old 24th January 2010, 14:17   #6761  |  Link
mochevolete
Originally Posted by stasi View Post
Sub support for DVD was very useful, I manually extract subs from DVDs with VSRIP. The old AutoMKV uses VSRIP, too (I used AutoMKV before I heard about RIPBOT)
@Atak: Is is possible to add this option?
+1 on multiple audio tracks and DVD subs
Nik
mochevolete is offline   Reply With Quote
Old 24th January 2010, 16:11   #6762  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
can somebody send me m2ts file with DTS-MA 6.1?
Old 24th January 2010, 18:22   #6763  |  Link
ludeboy12
ludeboy12's Avatar
Not 6.1 but you can get a couple 7.1 DTS-HD MA m2ts trailers over here: http://www.demo-world.eu/trailers/hi...n-trailers.php
-Lude
ludeboy12 is offline   Reply With Quote
Old 24th January 2010, 18:38   #6764  |  Link
Atak_Snajpera
I need 6.1
Old 24th January 2010, 19:40   #6765  |  Link
consultant
What controls the location of the ripbot264temp directory?
consultant is offline   Reply With Quote
Old 24th January 2010, 19:43   #6766  |  Link
Atak_Snajpera
ripbot264.ini
Old 24th January 2010, 20:30   #6767  |  Link
johnny50
Atak, I get the error message in DGSplit "Insane start/end values!" when I try that.
johnny50 is offline   Reply With Quote
Old 24th January 2010, 20:33   #6768  |  Link
Atak_Snajpera
How big is your m2ts file?
Old 24th January 2010, 20:56   #6769  |  Link
Arbelisk
FLAC is only available for lossless audio! I checked your movie (http://www.blu-raystats.com/Stats/Stats.php) and it has plain DTS audio not DTS-MA!
Thanks Atak! Guess they didn't even bother to remaster the audio for Blu-Ray.
Arbelisk is offline   Reply With Quote
Old 24th January 2010, 23:15   #6770  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
Originally Posted by fantasmanegro View Post
I guess u're talking about CoreAVC and AnyDVD right?
I was talking about the rented video comment, but yes if they are ripped off then them as well.
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 25th January 2010, 02:15   #6771  |  Link
rcrh
ripbot264 and dvr-ms files.
Is there any way to get ripbot264 to encode a dvr-ms file? When I open the file it says "Please wait... Gathering information..." but it never finishes.
It would be great to avoid having to go through an extra step to remux this into another container.
Thanks in advance.
rcrh is offline   Reply With Quote
Old 25th January 2010, 04:21   #6772  |  Link
prettyboy85712
Here you go. It's clip of Terminator 2.
http://www.mediafire.com/?tvmfjidyvne
prettyboy85712 is offline   Reply With Quote
Old 25th January 2010, 04:29   #6773  |  Link
blackcell
DieselDog
mplayer site has all types
http://samples.mplayerhq.hu/A-codecs/DTS/dts/
blackcell is offline   Reply With Quote
Old 26th January 2010, 06:07   #6774  |  Link
awake33
Originally Posted by awake33 View Post
No sir, no artifacts show up. I watched it for a good while from the beginning.
And thank you for the time you take to help us here.
Dump CoreAVC 1.9.x !
I don't have CoreAVC software installed on my PC. Nothing has changed on my PC other than changing from 1.14.6 to 1.15.0.
I've tried a newer ffdshow.exe file and re-installing codecs, but the problem remains. Any other suggestions?
awake33 is offline   Reply With Quote
Old 26th January 2010, 06:18   #6775  |  Link
Tolham
i'm trying to convert a blu-ray rip of Oldboy to mkv. it is a korean movie and i need subtitles. when i tell it to "build in picture" and start the conversion, it says conversion is complete after 1 second of initializing. if i reset the subtitle option, the conversion begins normally. the subtitle file i select is the one found in the job temp folder.
Tolham is offline   Reply With Quote
Old 26th January 2010, 10:31   #6776  |  Link
marax
Windows 7 x64,
i have installed klite codec pack x64 and ripbot asks for 32bit version ?! FFDSHOW NOT INSTALLED in red, even I have installed 3158
also for Halli media splitter
why ?
marax is offline   Reply With Quote
Old 26th January 2010, 10:42   #6777  |  Link
twazerty
AVCHDCoder developer
Originally Posted by marax View Post
Windows 7 x64,
why ?
because ripbot asks for 32bit versions. Most GUI's still works on 32 bit decoders/encoders/splitters. Sometimes a 64 bit encoder but still a 32bit splitter and decoder.
twazerty is offline   Reply With Quote
Old 26th January 2010, 13:40   #6778  |  Link
prettyboy85712
Windows 7 x64,
why ?
Never use codec packs. Uninstall and then download/install each app separately. You're asking for problems otherwise.
Old 26th January 2010, 14:12   #6779  |  Link
Atak_Snajpera
@Tolham
Send me 100 MB sample (.m2ts file) to www.mediafire.com. Use DGsplit. Show me log file from Logs folder
Old 26th January 2010, 17:49   #6780  |  Link
stumped
i'm having issues with ripbot and blu-ray files. It's only recently though that it's happening. It's not related to 32bit or 64bit differences (i just finished trying that, it first started on win7 x64 and now on win7 x32)
When i load either the elementary h264 stream, or one that's inside an mkv container, i get an avisynth error "DirectShow Source: Timeout waiting for graph to start.
M:\temp\Ripbot264temp\job1\getinfo.avs, line 2"
It's also not related to just one movie. It started doing this on "The Fifth Element" last friday (64bit) and when i did a fresh install of 32bit (like only gpu driver, ffdshow, firefox, haali, java, avisynth) it worked fine. Yesterday i finished setting up the pc and tried loading "Land of the Lost" (in both mkv, then .264) it gave me the avisynth error. I tried earlier version,s same issue. I tried reinstalling avisynth, same issue. I'm pulling my hair out right now trying to figure out what's going wrong. I have coreAVC 2.0 installed (wasn't an issue before) and i have ffdshow rev3222 clsid variant (i'm thinking that might be the issue, but when windows was fresh install, it worked?).
Can you please help me? I love ripbot 264, but if i can't get it to work, i'm not sure what i'll do!
EDIT: i read the first page, downgraded my Haali (although .264 files inside .mkv container shouldn't be an issue, also haali changed something, the FouCC so that it can work around windows 7 stuff) and now all works just fine!
stumped is offline   Reply With Quote
