16th January 2008, 22:31 | #482 | Link |
also why is the priority now set to low? i have to manually go change it every time on both passes :P could it not be added as a drop down like megui so we can set it and leave it?
not that i like complaining (even a little bit) about my fav video app |
16th January 2008, 22:50 | #483 | Link | ||
17th January 2008, 18:55 | #486 | Link |
Hi Atak, I am currently trying to convert The Ten Commandments on to my psp and it the movie uses 2 disks (part 1, intermission, then part 2 on another disk) I ripped both disk's main movie vobs and they are listed as VTS_01_1.vob and VTS_02_1.vob is it possible to join them with Ripbot264 or do I need to use a vob joiner or use dvd decrypter in another way or even dvd shrink...It's no big deal to join them but if I can then I might try joining some of the trilogy movies.(like star wars or Lord of the Rings) . Any suggestions?
17th January 2008, 20:37 | #487 | Link |
Just select both files.
18th January 2008, 15:54 | #489 | Link |
I know that I have complained about this before but I wanted to take one more shot at it.
Using single pass with a quantizer of 21 your files are much, much bigger than your competitors; like megui, automkv, staxrip and such. I have tried to make the quantizer larger to reduce the filesize but when the filesizes are equal the quality of your output is much lower than the others. I did a movie last night and MeGui was 675k and yours outputs was 1172K; both had the same framerate (24fps) and the same audio bitrate. Both movies appeared to have the same quality. |
18th January 2008, 19:24 | #491 | Link |
also, ripbot264 uses CRF and not constant quantizer
edit: i just tested a 15 min clip using CRF 22 in megui and x264 and the results were only 300kb out, which might be AQ not conclusive by any means, but try with CRF and not constant quantizer in megui and see how that goes Last edited by deets; 18th January 2008 at 19:53. Reason: added some testing |
18th January 2008, 21:54 | #493 | Link |
RipBot now uses new AQ algorithm (Dark's) . Sometimes you will get even smaller files than without AQ and believe me quality is alot better! Check this thread http://forum.doom9.org/showthread.php?t=132760
18th January 2008, 21:54 | #494 | Link | |
19th January 2008, 00:08 | #495 | Link |
Hello guys !
I'm trying to convert one mkv file (x264 720p) with ripbot for my PS3 but I don't manage it... I add a new job with the file, and when I press the start button, the job is immediatly indicated as *DONE* but nothing append in reality. I really don't understand where is the problem... It is the same when I try with a simple avi file ! Thanks in advance for your replies ! |
19th January 2008, 00:25 | #497 | Link | |
19th January 2008, 04:36 | #498 | Link |
Now I'm confused again!
I thought I could have Ripbot load an avs file, yes/no? I load this avs file called "megui-720p.avs" -- DirectShowSource("M:\HD_EncodeTesting\movie\HVDVD_TS\testing\FEATURE_1.EVO",fps=23.976,audio=false) crop( 0, 128, 0, -136) Lanczos4Resize(1280,544) # Lanczos4 (Sharp) Undot() # Minimal Noise AddBorders(0,88,0,88) Trim(114247,0) ConvertToYV12() It then loads OK. I then press the "properties" button and see that Ripbot has made a new avs file -- #MT #VideoSource video=DirectShowSource("M:\HD_EncodeTesting\movie\HVDVD_TS\testing\megui-720p.avs",audio=false) video=ConvertToYV12(video) #Deinterlace #Decimate #Crop #Resize #Colors #Subtitles #AudioSource #DownMixToStereo #Tempo #Delay #Normalize #AudioDub #Triming #ColorSpace video=ConvertToRGB(video) return video So how can 2 avs files be executing at the same time? Can this be causing my instant termination when I start to encode, just like the above poster?? When I press the "preview script" button it does load in MPC ok. Update - For the first time I added an audio source for the encoding and it starts to work. I asked this in one of my above posts but I guess it was missed. So it looks like an audio source must be entered or instant termination, yes?? Where is the file being encoded stored as encoding is happening? It is not in the destination directory I selected in the gui! Last edited by tyee; 19th January 2008 at 04:50. |
19th January 2008, 13:28 | #500 | Link | ||
