13th December 2007, 16:08 | #1961 | Link | |
My problem is I could not get Nero to give me an AC3 file that sounded right. It skipped all over and I could not fix that. On the other hand, despite the issues you guys point out with using Sonic to decode DD+ --> AC3, the AC3 file sounds very good using an external high-end decoder played through big speakers! Hey... what do you need to decode the .wav files eac3to generates if decoding to WAV? These do not play for me in WMP so that I can test them/listen to them. |
13th December 2007, 16:42 | #1962 | Link | |
So i guess you were right! How can i reinstall the nero decoder? Edit: i reinstalled nero 7 premium, but it did not help.. I am also noticed, that there is no "writing outoputfile" when i use nero, with sonic, there is one.... Cu Last edited by Penecho; 13th December 2007 at 17:32. |
13th December 2007, 18:21 | #1963 | Link |
Never Grow Up !
You need to buy the HD plugin serial seperately from Nero. You put in your serial at "ProductSetup/Licence/Add" and you're good to go !
No SPAM just for help: http://www.nero.com/eng/bluray-hddvd-video-plugin.html Goodluck. Last edited by SvT; 13th December 2007 at 18:26. Reason: Put in URL for help. |
13th December 2007, 20:18 | #1964 | Link |
I think i had that already, coz if not it would look like this (i uninstalled my nero and tested):
E-AC3, 5.1 channels, 1:49:16, 1536kbit/s, 48khz, dialnorm: -27dB Removing dialog normalization... Decoding with DirectShow (Nero Audio Decoder 2)... Getting "Nero Audio Decoder 2" instance failed. Cu Penecho |
13th December 2007, 20:25 | #1965 | Link | |
Never Grow Up !
(I think your error shows if the plugin isn't properly registered). |
13th December 2007, 21:35 | #1966 | Link |
New version of EAC3toGUI released
Fellow Forum members,
The latest version (v1.49) of EAC3toGUI can be found here: http://www.sendspace.com/file/xilu5v Changes and features in this version include: - Removed comma in audio delay output for values over 999ms. - Added "Other Options" tab to allow custom or non-integrated options. - Added *.dts as valid extension in the destination file. - Changed command line output box to READ only. This is an interim revision and I hope to release a version with all current options integrated. As usual, remember to use the settings menu option to tell EAC3toGUI where the eac3to executable is located. Please report any problems or feature requests. Regards, The_Keymaker Last edited by The_Keymaker; 16th December 2007 at 18:57. |
13th December 2007, 22:46 | #1967 | Link |
can anyone explain what the current status with xport 1.00 and seamless branching movies regarding audio sync is? link with info here: http://forum.doom9.org/showthread.ph...63#post1069463
I dont understand what we have to do now, or if we have to do something other than just demuxing with xport to keep audio in sync. will any joined part with LPCM audio now have +5ms delay and we have to fix that manually, either with altered fps rate or with that 'tail' procedure, that well have to cut off the endings and adjust both audio and video pts together at the end? or was this only an info he posted there and xport takes care of all that automatically? |
13th December 2007, 23:56 | #1969 | Link | |
I'm not sure what the best remedy is. If you're re-encoding, then an extra frame (strategically placed) when necessary would be the best solution. If you're just re-muxing, why? There is one positive note. The PES granularity of Dolby Lossless is 0.83 milliseconds. So for movies with Dolby Lossless audio, the A/V sync should be very close over many segments. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
14th December 2007, 02:17 | #1970 | Link |
Im remuxing, because I want the best possible quality at smallest possible size :P
which track count as dolby lossless, only TrueHD tracks, right? 0.83 is like nothing then. is this the same for DTS-HD (MA) tracks?? would it be possible for you to make a quick list of all tracks granularity for each .m2ts file, this should be helpful then when having movies with many parts to figure out how the delay has to be at the end. so for LPCM it was 5ms and for DD+ something like 32ms? trueHD 0.83 then? if you still need info about other audio tracks, then tell me, maybe I will be able to cut more samples, just to complete this. LPCM: 5ms DD+: 32ms TrueHD: 0.83ms DTS-HD MA: ? DTS-HD HiRes: ? (same as MA?) (I sent you both samples, MA with close encounters and DTS-HD HiRes with basic instict) just assuming it is also 0.83 for DTS-HD MA for example, so when I remuxed close encounters with dts-hd converted to flac and this movie consists of 30 pieces, then the delay at the end would be ~25ms for the last part of the movie? and in case of ratatouille with 31 pieces of LPCM the delay at the end would then be 155ms? and a 2 piece .m2ts movie with lpcm only ending up with 5ms, so this would be not worth correcting at all btw. you mean positive delay, right (meaning we would have to slow down the fps rate of the video a little to make the video stream gradually longer) ? btw² since you mentioned PES, do we have to use the -z option in xport now additionally for such files? (=e.g. xport -hz bla.m2ts 1 1 1) or still only -h ? Last edited by Thunderbolt8; 14th December 2007 at 03:24. |
14th December 2007, 02:40 | #1971 | Link | |
The real problem is when the small amounts per segment amount to a total offset that's greater than 70ms.
Chumbo |
14th December 2007, 02:43 | #1972 | Link | |
14th December 2007, 04:20 | #1973 | Link |
LPCM: 5ms
DD+: 32ms TrueHD: 0.83ms DTS-HD MA: 10.666ms DTS-HD HiRes: 10.666ms Note that these are the maximum amounts of extra audio. On average, it will be half of the maximums. And yes, there's too much audio, so the video needs to slow down. Don't use the -z option. That's for demuxing to PES packets, which almost no tool uses. Also, I think it's a little buggy (and never fixed since nobody uses it). Here's an article on lip-sync tolerance. http://www.tvtechnology.com/features...g_it_all.shtml "The International Telecommunications Union (ITU) released a specification called BT.1359-1 in 1998. It was based on research that showed the reliable detection of A/V sync errors was between 45 msec audio leads video to 125 msec audio lags video. Remember, this is just the detectability region; the acceptability region is an even wider +90 to -185 msec." Ron
14th December 2007, 04:35 | #1974 | Link |
thanks for completing the list
hm the difference between max and average shouldnt make too much difference, at least not for trueHD and LPCM. but with movies with ~30 .m2ts files then it can already make a little difference (~50ms) for dts-hd and surely will in case of DD+ (~500ms). guess theres some experimenting needed :S |
14th December 2007, 07:47 | #1975 | Link |
When I join 3 m2ts files and demux the LPCM stream with xport, eac3to comes up saying that the format isn't recognized, though a graphedit graph of File -> ffdshow audio decoder shows that it is indeed (L)PCM.
Need a sample? |
14th December 2007, 09:09 | #1976 | Link | ||
for 48khz there's 48 samples per ms so you can get pretty damned accurate if you just have the patience to do it right. (from earlier in this thread) Quote:
it takes a lot of time but i feel it's worth it. what would make it a bit easier would be if xport could be updated with a switch that displays only the last video and audio pts |
14th December 2007, 09:44 | #1978 | Link | |
Obviously things are much more complicated with AC3 compared to LPCM because we can't just chop off half an AC3 frame. So for AC3 demuxing the only reasonable solution would be to keep track of the "too much audio milliseconds". Once the delay sums up to over the length of an AC3 frame, we could then chop off one full AC3 frame (or several, if necessary). This way we could keep delay under the length of one AC3 frame. Thoughts? |
14th December 2007, 15:47 | #1979 | Link |
Can someone please help me with this I would be very very thankful.
Just bought Bourne Ultimatum and I would like to remux it into TS and put it on my server so I can have it playable in Vista Media Center. The edition I bought have a TrueHD track. And as there are no decoders that works with vista media center I will (if possible) convert it to flac. I don't really understand about sync problems and how to fix them. Also the pulldown (29.97fps issue) must be removed from the VC-1 stream before it's muxed into a ts. I know in theory what needs to be done. But not how (tools and exec) to do it. HD DVD disc -> Demux VC-1 es and TrueHD -> remove pulldown from VC-1 es -> a perfect convert TrueHD to FLAC -> sync everything 100% -> mux into ts If someone could write a step-by-step guide to get a perfect in Vista Media Center playable TS with the same exact sq as the truehd track (no dynamic range compression and stuff like that). I will just need one (TrueHD->FLAC) audio stream. And also a perfect VC-1 es without stutter or speed up. It would be the best christmas gift ever! Sorry If this post belongs in another thread... Last edited by rickardk; 14th December 2007 at 15:52. |
14th December 2007, 17:41 | #1980 | Link | |
eac3to |
