Old 31st October 2019, 11:32   #14881  |  Link
hubblec4
Matroska find' ich toll
Hi videoh
That are great news.
Could you keep in mind your project should run on Linux and Windows and we need all what eac3to can do plus a bit more.
In my case I have often seamless branching BDs and eac3to has some bugs for e-ac3 streams.
Skip identical frames works almost for all cases but not 100%.
chapterEditor || Matroska-Playback || hSplit || DiscShare
hubblec4 is offline   Reply With Quote
Old 1st November 2019, 14:13   #14882  |  Link
von Suppé
von Suppé's Avatar
Originally Posted by videoh View Post
He he, now I have to deliver it. No way I can let you down.
Created the project today and started coding... Whee!
Thanks in advance, great!
Would next week be possible? I've decided to spend my end-of-year holidays early and I'm eager to unpack my X-mas presents.
Old 2nd November 2019, 10:31   #14883  |  Link
jpsdr
Be realistic.
As good as he is, you can't expect videoh to produce all the eac3to features within the snap of a fingers.
It will be allready very great if there is a simple demuxer wich demux properly streams where eac3to fails.
My github.
Old 2nd November 2019, 11:52   #14884  |  Link
von Suppé
von Suppé's Avatar
I was just joking. My apologies.
Old 2nd November 2019, 12:35   #14885  |  Link
videoh
I took it as a joke.
Old 3rd November 2019, 18:37   #14886  |  Link
videoh
Just successfully did a first full demux from Cars 2 UHD using DGDemux. I have to clean up some stuff, remove the licensing, and make a manual. Maybe by Thanksgiving, or even next week!
I will start a new thread for further status reports, as it doesn't belong here.
EDIT: New thread is here:
https://forum.doom9.org/showthread.p...34#post1889434
Old 8th January 2020, 05:15   #14887  |  Link
MrVideo
MrVideo's Avatar
Found a problem with eac3to v3.34. It freezes while attempting to analyze a full ABC network feed mux. It gets to 96% and halts.
A sample tsreader capture of the mux is here (53,879,018 bytes).
MediaInfo reads it just fine.
My Total Eclipse 2017 Photos
Old 8th January 2020, 10:32   #14888  |  Link
LigH
LigH's Avatar
MediaInfo does not analyze the whole file, only the file parts where it assumes to find the headers with the attributes describing the content (usually in the beginning of a file, sometimes in the end as well). It will most probably skip parts with possible broadcast data errors.
New German Gleitz board
Old 8th January 2020, 11:49   #14889  |  Link
tebasuna51
tebasuna51's Avatar
Maybe there are some problem at end of mux (96%), MediaInfo never read all the stream, only the headers.
ffmpeg info say:
ts streams:
41: hevc (Rext), yuv422p(tv, bt709), 1280x720 [SAR 1:1 DAR 16:9], 59.94 fps
36(aaa,aab): mp2, 48000 Hz, stereo, s16p, 384 kb/s
38(aac,aad): mp2, 48000 Hz, stereo, s16p, 384 kb/s
37(aae,aaf): mp2, 48000 Hz, stereo, s16p, 384 kb/s
35(aag,aah): mp2, 48000 Hz, stereo, s16p, 384 kb/s
29(eng): mp2, 48000 Hz, stereo, s16p, 256 kb/s
15: hevc (Rext), yuv422p(tv, bt709), 1280x720 [SAR 1:1 DAR 16:9], 59.94 fps
22(aaa,aab): mp2, 48000 Hz, stereo, s16p, 384 kb/s
24(aac,aad): mp2, 48000 Hz, stereo, s16p, 384 kb/s
20(aae,aaf): mp2, 48000 Hz, stereo, s16p, 384 kb/s
23(aag,aah): mp2, 48000 Hz, stereo, s16p, 384 kb/s
12(eng): mp2, 48000 Hz, stereo, s16p, 256 kb/s
1: hevc (Rext), yuv422p(tv, bt709), 1280x720 [SAR 1:1 DAR 16:9], 59.94 fps,
30(aaa,aab): mp2, 48000 Hz, stereo, s16p, 384 kb/s
32(aac,aad): mp2, 48000 Hz, stereo, s16p, 384 kb/s
31(aae,aaf): mp2, 48000 Hz, stereo, s16p, 384 kb/s
33(aag,aah): mp2, 48000 Hz, stereo, s16p, 384 kb/s
39(eng): mp2, 48000 Hz, stereo, s16p, 256 kb/s
40: hevc (Rext), yuv422p(tv, bt709), 1280x720 [SAR 1:1 DAR 16:9], 59.94 fps
17(aaa,aab): mp2, 48000 Hz, stereo, s16p, 384 kb/s
21(aac,aad): mp2, 48000 Hz, stereo, s16p, 384 kb/s
16(aae,aaf): mp2, 48000 Hz, stereo, s16p, 384 kb/s
18(aag,aah): mp2, 48000 Hz, stereo, s16p, 384 kb/s
8(eng): mp2, 48000 Hz, stereo, s16p, 256 kb/s
19: hevc (Rext), yuv422p(tv, bt709), 1280x720 [SAR 1:1 DAR 16:9], 59.94 fps
25(aaa,aab): mp2, 48000 Hz, stereo, s16p, 384 kb/s
28(aac,aad): mp2, 48000 Hz, stereo, s16p, 384 kb/s
26(aae,aaf): mp2, 48000 Hz, stereo, s16p, 384 kb/s
27(aag,aah): mp2, 48000 Hz, stereo, s16p, 384 kb/s
34(eng): mp2, 48000 Hz, stereo, s16p, 256 kb/s
42: hevc (Rext), yuv422p(tv, bt709), 1280x720 [SAR 1:1 DAR 16:9], 59.94 fps
3(aaa,aab): mp2, 48000 Hz, stereo, s16p, 384 kb/s
5(aac,aad): mp2, 48000 Hz, stereo, s16p, 384 kb/s
4(aae,aaf): mp2, 48000 Hz, stereo, s16p, 384 kb/s
6(aag,aah): mp2, 48000 Hz, stereo, s16p, 384 kb/s
10(eng): mp2, 48000 Hz, stereo, s16p, 256 kb/s
And show many errors and warnings when try to extract some track.
Try yourself:
ffmpeg -i "ABC-H265-mux-test.ts" -map 0:42 -vcodec copy "ABC-H265-mux-test.ts_42.h265"
Old 8th January 2020, 14:05   #14890  |  Link
MrVideo
MrVideo's Avatar
I tried opening the file with tsmuxer (2.6.15) and it complained about pieces of it and ignored a couple of video streams and audio streams. So, I did another capture of 500 MB and tsmuxer didn't like it either. So I read the new file into VideoReDoPro and extracted each of the 6 programs (1 video stream and 5 audio streams). Not one error was reported. I remuxed the 6 TS files into a M2TS file via tsmuxer and eac3to liked it.
I have no idea what is wrong with a complete mux capture that causes eac3to and tsmuxer to not like it. If I just capture one of the program streams, eac3to doesn't have an issue with it.
Thanks for the pointers.
As a side note, I normally do not capture the ABC network feed. I'm only doing it lately because of the Jeopardy! special programming. And because ABC switched over from H.264 to H.265, I was also testing out my ZShell script extract a single stream and extract three of the audio streams to convert the MPA to DD5.1 AC3. When eac3to hung I thought that the new 3.34 version had issues. Turns out that the ABC network feed has something in it that eac3to and tsmuxer do not like, when captured as a whole.
Old 8th January 2020, 16:55   #14891  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Hi @MrVideo,
It's been a few years since I've played around with transport streams that contain multiple TV channels. But I seem to remember that Mosu's MKVToolNix did quite a good job at identifying all the separate streams...
Old 9th January 2020, 02:12   #14892  |  Link
MrVideo
MrVideo's Avatar
I know what all of the streams are. I don't use eac3to to identify the streams, but to extract one of the program's video and audio streams in order to create 6 separate wave files from the MPA stereo audio streams so that I can use ffmpeg to create an AC3 5.1 file that I'll then tsmuxer into a new TS file. I have a Zshell script that runs all of the pieces. If eac3to can't find all of the streams, it means that I have to use VideoReDo to pull what I want into a new stream that will then be used to create the AC3 file. That said, it means that I should only capture the program that I need, which is what I am doing as I write this.
There is always a way around an issue.
Old 21st January 2020, 03:25   #14893  |  Link
Bandits
I have a UHD disc with different audio streams with different delays. The THD+AC3 (Atmos) stream has a -5ms delay and I was told earlier in this thread that eac3to cannot apply a delay to those streams. This results in the file name being appended with a "DELAY -5ms". The other audio streams show a -17ms delay but the file names are not appended. Looking at the log, it shows the -17ms streams have had a adjustment applied to the stream by eac3to. It also shows that +15ms of the delay could not be applied to the same streams.
Is the timing of these audio streams correct when eac3to corrects them even when showing it couldn't correct it completely?
eac3to v3.34
command line: "C:\eac3to.exe" "C:\XXXXX" 1) 1: "C:\Chapters.TXT" 2: "C:\Video_2_HEVC.h265" 3: "C:\Audio_3_English.THD+AC3" 4: "C:\Audio_4_French.AC3" 5: "C:\Audio_5_Italian.AC3" 6: "C:\Audio_6_Japanese.AC3" 7: "C:\Audio_7_Portuguese.AC3" 8: "C:\Audio_8_Spanish.AC3" 9: "C:\Audio_9_Thai.AC3" 10: "C:\Audio_10_English.AC3" 11: "C:\Subtitle_11_English.sup" 12: "C:\Subtitle_12_English.sup" 13: "C:\Subtitle_13_English.sup" 14: "C:\Subtitle_14_English.sup" 15: "C:\Subtitle_15_Chinese.sup" 16: "C:\Subtitle_16_Chinese.sup" 17: "C:\Subtitle_17_French.sup" 18: "C:\Subtitle_18_Italian.sup" 19: "C:\Subtitle_19_Japanese.sup" 20: "C:\Subtitle_20_Korean.sup" 21: "C:\Subtitle_21_Portuguese.sup" 22: "C:\Subtitle_22_Spanish.sup" 23: "C:\Subtitle_23_Thai.sup" 24: "C:\Subtitle_24_French.sup" 25: "C:\Subtitle_25_Japanese.sup" 26: "C:\Subtitle_26_English.sup" 27: "C:\Subtitle_27_Italian.sup" 28: "C:\Subtitle_28_Japanese.sup" 29: "C:\Subtitle_29_Korean.sup" 30: "C:\Subtitle_30_Spanish.sup" -progressnumbers -minPlayListRuntime=0:01:00 -log="C:\log.txt"
M2TS, 1 video track, 8 audio tracks, 20 subtitle tracks, 2:18:01, 11.988p
1: Chapters, 16 chapters
2: h265/HEVC, 2160p24 /1.001 (16:9), 10 bits
3: TrueHD/AC3 (Atmos), English, 7.1 channels, 48kHz, -5ms
(embedded: AC3, 5.1 channels, 640kbps, 48kHz)
4: AC3 Surround, French, 2.0 channels, 192kbps, 48kHz, -17ms
5: AC3, Italian, 5.1 channels, 640kbps, 48kHz, -17ms
6: AC3, Japanese, 5.1 channels, 640kbps, 48kHz, -17ms
7: AC3, Portuguese, 5.1 channels, 640kbps, 48kHz, -17ms
8: AC3, Spanish, 5.1 channels, 384kbps, 48kHz, -17ms
9: AC3, Thai, 5.1 channels, 384kbps, 48kHz, -17ms
10: AC3 Surround, English, 2.0 channels, 192kbps, 48kHz, -17ms
11: Subtitle (PGS), English
12: Subtitle (PGS), English
13: Subtitle (PGS), English
14: Subtitle (PGS), English
15: Subtitle (PGS), Chinese
16: Subtitle (PGS), Chinese
17: Subtitle (PGS), French
18: Subtitle (PGS), Italian
19: Subtitle (PGS), Japanese
20: Subtitle (PGS), Korean
21: Subtitle (PGS), Portuguese
22: Subtitle (PGS), Spanish
23: Subtitle (PGS), Thai
24: Subtitle (PGS), French
25: Subtitle (PGS), Japanese
26: Subtitle (PGS), English
27: Subtitle (PGS), Italian
28: Subtitle (PGS), Japanese
29: Subtitle (PGS), Korean
30: Subtitle (PGS), Spanish
Creating file "C:\Chapters.TXT"...
[a06] Extracting audio track number 6...
[v02] Extracting video track number 2...
[s30] Extracting subtitle track number 30...
[s22] Extracting subtitle track number 22...
[s20] Extracting subtitle track number 20...
[s27] Extracting subtitle track number 27...
[s21] Extracting subtitle track number 21...
[a09] Extracting audio track number 9...
[a09] Applying (E-)AC3 delay...
[a09] A remaining delay of +15ms could not be fixed.
[s29] Extracting subtitle track number 29...
[s19] Extracting subtitle track number 19...
[a04] Extracting audio track number 4...
[a04] Applying (E-)AC3 delay...
[a04] A remaining delay of +15ms could not be fixed.
[s17] Extracting subtitle track number 17...
[a03] Extracting audio track number 3...
[a10] Extracting audio track number 10...
[a10] Applying (E-)AC3 delay...
[a10] A remaining delay of +15ms could not be fixed.
[a07] Extracting audio track number 7...
[a07] Applying (E-)AC3 delay...
[a07] A remaining delay of +15ms could not be fixed.
[s18] Extracting subtitle track number 18...
[s16] Extracting subtitle track number 16...
[s12] Extracting subtitle track number 12...
[a08] Extracting audio track number 8...
[a08] Applying (E-)AC3 delay...
[a08] A remaining delay of +15ms could not be fixed.
[s23] Extracting subtitle track number 23...
[s28] Extracting subtitle track number 28...
[a05] Extracting audio track number 5...
[a05] Applying (E-)AC3 delay...
[a05] A remaining delay of +15ms could not be fixed.
[a06] Applying (E-)AC3 delay...
[a06] A remaining delay of +15ms could not be fixed.
[s14] Extracting subtitle track number 14...
[s24] Extracting subtitle track number 24...
[s25] Extracting subtitle track number 25...
[s11] Extracting subtitle track number 11...
[s13] Extracting subtitle track number 13...
[s26] Extracting subtitle track number 26...
[s15] Extracting subtitle track number 15...
[v02] Creating file "C:\Video_2_HEVC.h265"...
[a03] Creating file "C:\Audio_3_English.THD+AC3"...
[a06] Creating file "C:\Audio_6_Japanese.AC3"...
[a05] Creating file "C:\Audio_5_Italian.AC3"...
[a07] Creating file "C:\Audio_7_Portuguese.AC3"...
[a08] Creating file "C:\Audio_8_Spanish.AC3"...
[a09] Creating file "C:\Audio_9_Thai.AC3"...
[a04] Creating file "C:\Audio_4_French.AC3"...
[a10] Creating file "C:\Audio_10_English.AC3"...
[s26] Creating file "C:\Subtitle_26_English.sup"...
[s27] Creating file "C:\Subtitle_27_Italian.sup"...
[s30] Creating file "C:\Subtitle_30_Spanish.sup"...
[s28] Creating file "C:\Subtitle_28_Japanese.sup"...
[s29] Creating file "C:\Subtitle_29_Korean.sup"...
[s13] Creating file "C:\Subtitle_13_English.sup"...
[s11] Creating file "C:\Subtitle_11_English.sup"...
[s15] Creating file "C:\Subtitle_15_Chinese.sup"...
[s12] Creating file "C:\Subtitle_12_English.sup"...
[s14] Creating file "C:\Subtitle_14_English.sup"...
[s16] Creating file "C:\Subtitle_16_Chinese.sup"...
[s18] Creating file "C:\Subtitle_18_Italian.sup"...
[s23] Creating file "C:\Subtitle_23_Thai.sup"...
[s21] Creating file "C:\Subtitle_21_Portuguese.sup"...
[s22] Creating file "C:\Subtitle_22_Spanish.sup"...
[s17] Creating file "C:\Subtitle_17_French.sup"...
[s20] Creating file "C:\Subtitle_20_Korean.sup"...
[s19] Creating file "C:\Subtitle_19_Japanese.sup"...
[s24] Creating file "C:\Subtitle_24_French.sup"...
[s25] Creating file "C:\Subtitle_25_Japanese.sup"...
Video track 2 contains 198533 frames.
Subtitle track 11 contains 1946 captions.
Subtitle track 12 contains 1832 captions.
Subtitle track 13 contains 1946 captions.
Subtitle track 14 contains 1854 captions.
Subtitle track 15 contains 2101 captions.
Subtitle track 16 contains 2145 captions.
Subtitle track 17 contains 1250 normal and 5 forced captions.
Subtitle track 18 contains 1720 normal and 6 forced captions.
Subtitle track 19 contains 1874 captions.
Subtitle track 20 contains 1863 captions.
Subtitle track 21 contains 1870 normal and 6 forced captions.
Subtitle track 22 contains 1988 normal and 5 forced captions.
Subtitle track 23 contains 1832 normal and 9 forced captions.
Subtitle track 24 contains 4 forced captions.
Subtitle track 25 contains 4 captions.
Subtitle track 26 contains 2055 captions.
Subtitle track 27 contains 1713 captions.
Subtitle track 28 contains 346 captions.
Subtitle track 29 contains 1983 captions.
Subtitle track 30 contains 1754 captions.
eac3to processing took 13 minutes, 49 seconds.
Done.
Blu-Ray Ripper 0.112a/0.2a
Bandits is offline   Reply With Quote
Old 21st January 2020, 10:05   #14894  |  Link
tebasuna51
tebasuna51's Avatar
The only way to correct delay, without recode, is add/delete full audio frames to extracted streams.
- eac3to can't do it to TrueHD streams.
- Over AC3 streams can add/delete frames of 32 ms, then over -17 ms delete 1 frame and the output need a + 15 ms of furter delay to be applied in the next container.
- BTW delays lower than a video frame duration, here 41.7 ms, can be ignored safely because can't be detected.
- If you insist to extract a stream with 0 ms of delay you need recode the AC3 (not recommended) with something like:
8: stdout.w64 -17ms | ffmpeg -i - -c:a ac3 -b:a 640k -center_mixlev 0.707 %_8spa.ac3
Old 1st February 2020, 17:23   #14895  |  Link
Bandits
I have a UHD disc that outputs the following:
eac3to v3.34
command line: "C:\eac3to.exe" "C:\XXXXX" 1) -log="C:\log.txt"
M2TS, 1 video track, 5 audio tracks, 5 subtitle tracks, 2:13:12, 11.987p
2: h265/HEVC, unknown parameters
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
4: AC3, Spanish, 5.1 channels, 640kbps, 48kHz
5: AC3, French, 5.1 channels, 640kbps, 48kHz
6: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz
7: DTS, English, 2.0 channels, 768kbps, 48kHz
8: Subtitle (PGS), English
9: Subtitle (PGS), French
10: Subtitle (PGS), English
11: Subtitle (PGS), French
12: Subtitle (PGS), Spanish
The video track is not correctly identified.
Using bdinfo.exe on the disc shows:
2160p / 23.976 fps / 16:9
Using the new tsMuxer.exe on the disc shows:
Profile: Main 10@5.1 Resolution 3840:2160p Frame rate 23.976
I don't know if tsMuxer.exe is just faking the detection or can see something that eac3to.exe and bdinfo.exe can't. If I use txMuxer.exe to demux/remux the output is still detected the same way as "unknown parameters".
Is there something that eac3to.exe is missing or is the video track just not made right? This is the first time I have seen this message.
Old 1st February 2020, 20:55   #14896  |  Link
tebasuna51
tebasuna51's Avatar
Last eac3to version is from 2017, the new tsMuxeR, updated at present, maybe can do a better job.
The last version of BDInfo is from 2018.
Old 2nd February 2020, 15:09   #14897  |  Link
Yoshi
Downmix clipping (7.1 -> 5.1)
I'm not sure whether this issue has already been covered here before as on a pre-search, the closest I found was only this post.
With several movies now which provide a 7.1 mix such as "Dredd" or "Ford v Ferrari" (and no matter whether Dolby TrueHD or DTS-HA MA), I encountered clipping when downmixing to 5.1. It goes undetected and eac3to doesn't issue a second pass. However, if I inject any volume change, like -0.1dB, then the audio all of the sudded isn't only treated as a 64 bit source (probably due to the internal workings of the libav/ffmpeg decoder's gain control), but also clipping is correctly recognized, triggering a second pass with an often more severe volume reduction.
To me, this doesn't make any sense as the clipping should be recognized without any manual gain intervention by the user.
Either I missed something here or this is a real bug in eac3to.
Yoshi is offline   Reply With Quote
Old 10th February 2020, 01:03   #14898  |  Link
Richard1485
AviSynth monkey
Yes, I've come across such clipping as well, so I usually check the output in Audacity. You could decode the 7.1 to w64 with eac3to and then use BeHappy to downmix to 5.1. It uses AviSynth, like this:
LoadPlugin("nicaudio.dll")
LoadPlugin("AudioLimiter.dll")
a=RaWavSource("file.w64", 1)
\.ConvertAudioToFloat()
flr = Getchannel(a, 1, 2, 3, 4)
blr = Getchannel(a, 5, 6)
slr = Getchannel(a, 7, 8)
sur = MixAudio(blr, slr, 1.0, 1.0).SoftClipperFromAudX(0.0)
return mergechannels(flr,sur)
Richard1485 is offline   Reply With Quote
eac3to
