23rd August 2005, 02:46 | #61 | Link |
Version 1.4.1 Release Candidate 1
Let's get this puppy out the door! Version 1.4.1 RC1 provides these changes from 1.4.1 Beta 7:
* The Save Project path is now properly saved. * Added "fccHandler" to the credits listing in the DGDecode manual. * Revised the playback speed option. It now gives 5 checkable menu choices: super slow (5fps), slow (10fps), normal (plays reliably at the correct frame rate for the stream), fast (2 times normal), maximum (as fast as possible). * A warning box is popped up if Force Film is used inappropriately. The user can decide whether to proceed anyway or to cancel. * The leading number on the file path lines at the top of the file was eliminated. This makes editing the D2V file to change paths easier. The D2V file format version is therefore bumped to 11, and you will need to remake existing projects. http://neuron2.net/dgmpgdec/dgmpgdec141rc1.zip |
23rd August 2005, 02:58 | #62 | Link | |
You're just in time for 141RC1. Avery (phaeron) told me how to reliably play back at real time rate in a relatively easy way (no messy threads and thread sync). Last edited by Guest; 23rd August 2005 at 03:21. |
23rd August 2005, 11:23 | #63 | Link | |
Registered Jedi
I don't think I've ever thanked you for DGMPGDec. I don't do much DVD ripping, but if I did I wouldn't dream of using any other tool. Thanks!
May the FOURCC be with you... |
23rd August 2005, 11:54 | #64 | Link | |
Life's clearer in 4K UHD
Given that we now have the "Super Slow" feature. Would it be possible to include "Frame Accurate Seeking" by using main slide bar and the keyboards "left" and "right" arrows, while the Preview box is still open? Cheers
23rd August 2005, 13:09 | #65 | Link |
brainless
I have a feature request for DGindex.
I like to create demuxed sound and video off a DVD-ROM-Drive with dgindex. But after creation of the project file/demuxing, I need to re-run DGindek over the demuxed m2v again, because the initially written d2v-project file refers to my DVD-ROM-Drive instead to the demuxed m2v.
Don't forget the 'c'! Don't PM me for technical support, please. |
23rd August 2005, 13:24 | #66 | Link | |
Another problem that should probably be fixed, because this mode would make it more noticable, is the possibility of displaying a few macroblocked frames at the beginning of a play/preview. This occurs because the full random navigation code of DGDecode is not present in DGIndex. But adding that code would begin approaching full frame accuracy and would mitigate the need for the single step mode described above. So I'm still thinking about where to go with this. |
23rd August 2005, 13:27 | #68 | Link | |
23rd August 2005, 13:32 | #70 | Link | |
scharfi's idea could be difficult to implement. I'll think about it but I am not optimistic. Last edited by Guest; 23rd August 2005 at 13:36. |
23rd August 2005, 13:53 | #71 | Link | |
A "Single Step" forward (or Frame Advance) mode would be very useful for what I use DGIndex for. Would it be possible to make the main slide bar active also? So if you miss the frame you want, you can go back and try again. Cheers
23rd August 2005, 14:12 | #72 | Link | |
23rd August 2005, 16:43 | #73 | Link | |
Squeeze it!
I think thats quite a big change for other Apps. which in their state now do parse the resulted d2v for accessing the used source VOB(s). Im not shure but some Apps do readout the d2v at the given line and parse the VOB file for getting informations of the stream which aren't served by openMPEG2Source() i.e.. In most programming Environments does exist a command for eleminating Letters in a string at a given startpos. using a given count, so I think there would be less trouble for exisiting Apps. then just using a string handling command when coding. Thanks |
23rd August 2005, 17:41 | #74 | Link |
@incredible
I cannot decipher what you are suggesting or asking. If you are objecting to a change in the D2V file format, be advised that there have been several since the apps you mentioned were created. If they want to be compatible with the latest DGMPGDec, then they will have to be revised. I cannot halt evolution just because some third-party apps exist. If you are objecting to the loss of the count field, be advised that it can be easily regenerated programmatically by using strlen(). |
23rd August 2005, 21:35 | #75 | Link |
I'm afraid we've to stop
I was wondering, if CLI was updated to allow multiple audio tracks to be demuxed in one go - does it make sense to do the same for audio PIDs in transport streams?
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
24th August 2005, 04:11 | #76 | Link |
requesting support for RFF flags interpretation in Interlaced movies
@neuron2,
I ran the latest build v1.4.1 Beta 7 on a very peculiar movie (NTSC R1). This is an interlace movie but has RFF flags which are playing with the field order. You can get a sample clip and more information at http://forum.doom9.org/showthread.php?t=98921 I would like to see this kind of support in your program since you are basically improving and doing things that original DVD2AVI cannot do. TIA -Amit |
24th August 2005, 04:54 | #78 | Link | |
Is this something you really need, or are you just epitomizing Emerson's hobgoblin? Last edited by Guest; 24th August 2005 at 04:57. |
24th August 2005, 08:37 | #79 | Link |
Mutiple video demuxing? Nah As a matter of fact I don't find video demuxing a particulary useful feature at all.
About audio: I'm not sure how many people actually process multiaudio TS, but in Europe its pretty common I guess to have multiple languages in digital broadcasts, so if people want to keep some of them then its useful to be able to demux multiple ones. But its not something crucial to the process that I really need - just a thought since normal audio demuxing was improved this way.
24th August 2005, 09:57 | #80 | Link |
Hey there neuron2,
would it be possible for dgindex to have the capability to write a .txt-like file of all the I-frames positions in a given video stream? Some sort of "parse .D2V and write I-frames' positions" option; something like Code:
0 12 24 36 44 56 68 78 90 ......
Sorry I had to go see about a girl |
