31st March 2009, 20:35 | #2282 | Link | |
BD burner and BD-R discs.
Google is your friend. A 6x BD-R/2x BD-RE combo burner by LG you can get for $199.99 from newegg.com, but the sales ends today. http://www.newegg.com/product/produc...82E16827136155 As for BD-R 25GB single sided discs, the cheapest I've found is about $3.29 each (I've seen them slightly cheaper at times). Obviously not as cheap as DVD media, but look at the capacity vs DVD-9. I get mine from mediamegamall.com but pay a 20 cents more so that I can have the inkjet printable ones. These are Optical Quantum 2x and have had no issues playing back on my PS3 and not one coaster yet...knock on wood! http://www.mediamegamall.com/bluray-...FQUWGgod3XAdpw Maybe we should start some type of "Deals on Blu-ray media and Burners" thread or maybe added to the guides for sources of media. |
31st March 2009, 21:53 | #2283 | Link |
Hi!
I have a problem with "The Prestige", German version. Full Backup to BD25. I get english audio, when choosing german, and german audio when choosing spanish. Its the same, when choose language via menu oder via PowerDVD directly. In BD-RB 20.03 and 20.05 the same behaviour. For the main movie the audio settings are: [x]AUD_001 AC3 MuliCh Eng [x]AUD_002 AC3 2-Ch Eng [ ]AUD_003 AC3 MuliCh French [ ]AUD_004 AC3 MuliCh Spanish [x]AUD_005 AC3 MuliCh German The INF File: Code:
[Status] LABEL=THE_PRESTIGE VERSION=v0.20.05 (beta) SOURCE_SIZE=26405903888 SOURCE_VIDEO_SIZE=26299072512 TARGET_SIZE=24117248000 REDUCTION=.912975794604326 RESIZE_1080=0 AUDIO_TO_KEEP=deu;eng;ger; SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=0 ENCODE_STEP=0 REBUILD_COMPLETE=1 COMPLETED=4 [00000] AUDIO=11001 PGS=11111111111 M2TS_TARGET=13983072736 RATE=17346 NSIZE=19724752896 FLINK=0 MLINK=0 [00005] AUDIO=11111 PGS=11111111111 M2TS_TARGET=3619399020 RATE=20749 NSIZE=3560620032 FLINK=0 MLINK=0 [00015] AUDIO=11111 PGS= M2TS_TARGET=97983659 RATE=6277 NSIZE=98273280 FLINK=0 MLINK=0 [00032] AUDIO= PGS= M2TS_TARGET=153162572 RATE=3644 NSIZE=128004096 FLINK=0 MLINK=0 Code:
[Options] MODE=0 QUICK_EXTRAS=0 PRIORITY_CLASS=1 RESIZE=0 AUDIO_TO_KEEP=deu;eng;ger; SUBS_TO_KEEP=all DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=0 #AVCHD=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 ENCODE_QUALITY=5 TARGET_SIZE=23000 TRELLIS=1 COLOR_BOOST=0 RESIZE_1080=0 #MIN_M2TS_SIZE=60 CUSTOM_TARGET_SIZE=23000 #KEEP_HD_AUDIO=1 [Paths] SOURCE_PATH=G:\ WORKING_PATH=D:\_BD_REBUILDER_TEMP\ |
1st April 2009, 00:14 | #2286 | Link | |
1st April 2009, 00:25 | #2287 | Link | ||
The BD-RB finished successfully but it wont play on Panasonic BD35 Menu is O.K and the sound is O.K, but there is no picture. Works perfectly on the PC and on Sony 350 . |
1st April 2009, 02:09 | #2289 | Link |
x.264 constantly crashing
I've backed up about 12 movies thus far and this program has been great. Lately, I've been getting a lot of x264 crashes either at the beginning or at the end when it's trying to rebuild everything. Are my settings wrong or something? I'm not going to claim to know a bunch about this whole process but I have been following here for a while and have been trying to learn as much as I can. This is what BDRB looks like after crash:
[20:55:58] BD Rebuilder v0.20.05 (beta) - Source: 300 - Input BD size: 32.42 GB - Approximate total content: [04:03:37.619] - Target BD size: 7.72 GB [20:56:00] PHASE ONE, Encoding - [20:56:00] Extracting audio/subs [VID_00004] - [20:56:53] Collecting video information [00004] - Video: 1920x1080, 29.970fps - Bitrate: 2,629 Kbs - [20:56:53] Reencoding: VID_00004, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [21:00:38] - Failed video encode, aborted Settings are: [Options] MODE=0 QUICK_EXTRAS=0 PRIORITY_CLASS=1 RESIZE=0 TARGET_SIZE=7910 VERBOSE_STATUS=1 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; TRELLIS=1 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=1 AC3_640=0 KEEP_HD_AUDIO=0 AVCHD=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=C:\USERS\JOSH\DESKTOP\300\ WORKING_PATH=C:\WORKING\ Last Command: "C:\BDRB\BD_Rebuilder\tools\x264.exe" "C:\WORKING\WORKFILES\VID_00004.AVS" --bitrate 2629 --level 4.1 --sar 1:1 --aud --vbv-bufsize 14500 --keyint 24 --min-keyint 1 --vbv-maxrate 17500 --filter 0,0 --subme 2 --me dia --bframes 3 --direct auto --weightb --partitions none --trellis 0 --analyse none --threads auto --thread-input --progress --no-psnr --no-ssim --stats "C:\WORKING\WORKFILES\VID_00004.AVS.264.stats" --pass 1 --output NUL Any ideas on what I'm doing wrong, other than being a big noob? Thanks all...
1st April 2009, 03:39 | #2290 | Link | |
Try changing H.264 in ffdsow to ffmpeg-mt from libavcodec and retry from start. Last edited by jewish; 1st April 2009 at 03:46. |
1st April 2009, 03:47 | #2291 | Link |
it won't let me. it's libavcodec or disabled for options. I'm using rev2787 20090317. Is there a newer version I should be using?
1st April 2009, 04:04 | #2292 | Link | |
Get the latest version here http://www.videohelp.com/tools/ffdshow |
1st April 2009, 04:17 | #2294 | Link |
Alright...
I installed the new update and tried to reencode WAR and I get the same thing: Here is the Command Window output: Code:
Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. Found PCM audio: 8 channels, 48000 Hz, 16 bits, 6180.220000 seconds. Warning: WAV file will be larger than 4 GB. Writing WAV file... input format: Microsoft WAVE Signed 16-bit little-endian 48000 Hz multi-channel Unsupported # of channels passed to aften_wav_chmask_to_acmod mismatch in channels, acmod, and lfe params Error: Could not write to the standard output. Any clues? |
1st April 2009, 09:43 | #2296 | Link | |
I had the same kind of problems. So what i did was REMOVE ALL CODECS FROM MY SYSTEM. REBOOTED. INSTALLED ONLY FFDSHOW , AVISYNTH V 258, AND HALI SPLITTER. I`ve now had no errors at all and all working fine. I`m running vista ultimate 32 bit. Hope this helps. Kind regards. |
1st April 2009, 17:01 | #2297 | Link | ||
BUG...
I'm doing a backup of Pirates of The Carribean, keeping HD audio. In this case LPCM. Here is a copy of my AUD_00001.meta file for 00001.m2ts (which will contain the main movie). Quote:
Which is incorrect, it looks like the HD audio retention switch hasn't worked as when I open the 00001.m2ts, instead of an LPCM track I am greeted by a 448k AC3 5.1 track. I have double checked and HD audio was selected, the same behaviour was exhibited on the sequel Pirates of The Carribean 2. The only thing that I did that might not be considered "normal", was to cancel the encode on the 1st pass and restart it from where it left off (after demuxing). EDIT I think I might have found why this is happening...and the bug is quite simple... If you look here, you can see 2 m2ts files. The 1st one in view is an EXTRA. The 2nd is the main movie m2ts, BD-Rebuilder is treating this 1st one in view as part of the main movie I suspect because it is over a certain size. But it IS an EXTRA. I can tell BD-Rebuilder is treating it as an extra because it is doing a 2pass encode on it when I have "quicker encoding for extras" turned on which should be 1pass. Also the m2ts's before this one that aren't visible in the screenshot were all encoded with 1pass as they should be. There is NO LPCM audio in this 1st one in view, so I suspect BD-Rebuilder is using the statistics of the extra's m2ts streams as the base for remuxing, and also as a base for setting the overall bitrate of the REAL main movie m2ts with this false assumption that the the audio streams are same. This shouldn't be too hard to correct as the bad juju that is happening is purely a knock on effect from the incorrect assumption that this 6GB extra is part of the main movie? Last edited by Furiousflea; 1st April 2009 at 19:45. |
1st April 2009, 18:17 | #2298 | Link |
Problms with Der ewige Gärtner
i've found an issue reencoding the blu ray der ewige gärtner. I'Ve done a move only backup using the following settings: Code:
[Options] MODE=1 QUICK_EXTRAS=0 PRIORITY_CLASS=1 RESIZE=0 AUDIO_TO_KEEP=ger; SUBS_TO_KEEP=gmh;goh; TRELLIS=1 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=0 KEEP_HD_AUDIO=1 AVCHD=1 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 TARGET_SIZE=23450 [Paths] SOURCE_PATH=C:\USERS\LIFESTYLE\DOCUMENTS\DVDFAB\ISO\GAERTNER\ WORKING_PATH=C:\USERS\LIFESTYLE\DESKTOP\GAERTNER\ Code:
----------------------- [06:15:52] BD Rebuilder v0.20.05 (beta) - Source: GAERTNER - Input BD size: 29,21 GB - Approximate total content: [02:08:29.743] - Target BD size: 22,90 GB - MOVIE-ONLY mode enabled [06:15:52] PHASE ONE, Encoding - [06:15:52] Extracting audio/subs [VID_00003] - [06:20:57] Reencoding: VID_00003 (1 of 2) - [17:47:08] Extracting audio/subs [VID_00005] - Audio/PGS sizing issue. Continued... - [19:05:38] Reencoding: VID_00005 (2 of 2) - [19:05:42] DoEncoding() 00009 8 Same movie works fine when using DVD Size as target Size |
1st April 2009, 18:37 | #2299 | Link |
Can someone give me an idea about the error:
CorrectMPLS() 00009 5 I have just done Mummy Returns Region B to bd-9 full disc and right at the very end I get this. I can't see anything obviously missing in the structure. |
1st April 2009, 19:54 | #2300 | Link |
Not doing too well today. I have done The Devil Wears Prada and everything was fine and I burned a bd-9. I played it on a standalone and thought I might have a disc fault as about half way throught the film the pictures freezes but the audio continues. I checked the image on the hard disc and that was the same, but as expected the original and rip were fine.
