Old 3rd March 2009, 02:17   #1041  |  Link
~bT~
н∂-ƒαиαтι¢
@neuron2
I re-ripped the disk again, indexed it again, but it didn't help.
The <cuvidDecodePicture() error> is reproduced.
Is there an easy way to extract the critical segment out of the 30GB file, so I coud upload the sample?
i also had that problem with the matrix. unfortunately, the only way was to not use nvtools to decode.
~bT~ is offline
Old 3rd March 2009, 04:18   #1042  |  Link
Well, boys, if you give me a sample, there's a good chance to get it fixed.
Guest is offline
Old 3rd March 2009, 10:50   #1043  |  Link
~bT~
н∂-ƒαиαтι¢
^ its too much trouble splitting a 24GB file for a 50MB sample
i wish i could give u a sample...
~bT~ is offline
Old 3rd March 2009, 15:04   #1044  |  Link
What do you mean "too much trouble"? It would take only a few minutes. You only need to write the 50MB, not the entire stream. You could set a range and then demux, or you could use DGSplit in segment mode.
Guest is offline
Old 3rd March 2009, 23:38   #1045  |  Link
Sharc
Here we go:
http://www.mediafire.com/download.php?jjqwnejomqn
Sharc is offline
Old 4th March 2009, 03:24   #1046  |  Link
rack04
I'm having problems getting the Command-Line Interface to work. For example, if I run the following Command-Line, a DGAVCIndexNV window opens but doesn't actually index the stream. Am I doing something wrong?
rack04 is offline
Old 4th March 2009, 04:50   #1047  |  Link
@rack04
Probably your input file spec is wrong. The window that opened shows nothing in the title bar.
@Sharc
I'm not seeing any problem with that stream. What are you drawing my attention to?
Guest is offline
Old 4th March 2009, 05:58   #1048  |  Link
rack04
@rack04
Well I did some testing and here's what I found. When I restart my computer and run the same command line it works. If I try to run it again, without restarting, it doesn't process the input like described previously. I think the file gets locked.
Here's another observation:
Even though nothing shows in the title bar if you go file->open it shows in the file list. If I hit ok it proceeds.
rack04 is offline
Old 4th March 2009, 07:26   #1049  |  Link
Sharc
@Sharc
- Index it with DGAVCIndexNV (.dga)
- Playback via avs Script and CUVIDServer
- see for example post 1029 and 1033
Don't you get a crash and the <cuvidDecodePicture() error> ?
Sharc is offline
Old 4th March 2009, 15:34   #1050  |  Link
@rack04
I can't duplicate that. Can you please re-download DGAVCIndexNV and try again. There have been some silent updates.
@Sharc
It works fine for me. Thinking what to do...
Guest is offline
Old 4th March 2009, 15:46   #1051  |  Link
rack04
@rack04
I'll update and perform some more tests tonight when I get home. Thanks for investigating.
rack04 is offline
Old 4th March 2009, 16:20   #1052  |  Link
laserfan
Aging Video Hobbyist
I dl'ed your clip and indexed and it played fine, then I tried your exact .avs w/resize and all is perfect, no errors, no blocks on that frame you cited.
I'm running XP Pro x64 and of course latest DG and CUVID and Avisynth 2.5.8.5/Vdub 1.8.6.
Oh, and also Nvidia 182.06 with its dlls in sysWOW64, and of course the ncuvid.dll from the DG package is with the DG executable.
laserfan is offline
Old 4th March 2009, 16:22   #1053  |  Link
~bT~
н∂-ƒαиαтι¢
^ did u try encoding it?
~bT~ is offline
Old 4th March 2009, 16:23   #1054  |  Link
rack04
Has anyone else experienced issues with the Command-Line Interface as I described above?
rack04 is offline
Old 4th March 2009, 16:52   #1055  |  Link
laserfan
I hadn't (why do you ask?) but I just did encode using x264. The output was a thing of beauty, no glitches:
General
Complete name                    : D:\Temp\video.264
Format                           : AVC
Format/Info                      : Advanced Video Codec
File size                        : 5.41 MiB
Video
Format                           : AVC
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Bit rate                         : 4 301 Kbps
Width                            : 720 pixels
Height                           : 576 pixels
Display aspect ratio             : 5/4
Frame rate                       : 25.000 fps
Standard                         : PAL
Resolution                       : 24 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.415
Writing library                  : x264 core 66 r1115M 11863ac
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 /
psy_rd=1.0:0.2 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 /
chroma_qp_offset=-3 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=0 /
b_bias=0 / direct=3 / wpredb=1 / keyint=24 / keyint_min=1 / scenecut=40(pre) / rc=2pass / bitrate=4301 /
ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=17500 /
vbv_bufsize=14500 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
laserfan is offline
Old 4th March 2009, 19:56   #1056  |  Link
Sharc
@Sharc
When I play the script by stepping linearly forward frame by frame it jumps back and forth a few times just before it crashes.
Windows Vista Home Premium / nvidia Geforce 9600GS / GPU codename G94GS / latest updates of DGtools / nvidia driver version 7.15.11.8206 - nVIDIA ForceWare 182.06
Sharc is offline
Old 5th March 2009, 02:40   #1057  |  Link
~bT~
н∂-ƒαиαтι¢
^ i tried your sample mate. no probs here. even encoded the sample.
can i ask what u are using to play it?
~bT~ is offline
Old 5th March 2009, 18:46   #1058  |  Link
Sharc
As I said, the file as such has no problems at all. The problem comes only when I index the file with DGAVCindexNV.exe and play the script on any player. The cuvid server fails, not the player. It's the same for all players (mpc, mpc-hc, WMP, VirtualDub ...). Maybe something is weird with my system?
Sharc is offline
Old 6th March 2009, 02:23   #1059  |  Link
~bT~
н∂-ƒαиαтι¢
^ i tried diff players. no probs.
~bT~ is offline
Old 6th March 2009, 20:26   #1060  |  Link
Sharc
^ Good for you then. Something must be odd with my system/GPU I guess, but I have no clue what it could be.
Sharc is offline
