Go Back   Doom9's Forum > Hardware & Software > PC Hard & Software
Old 25th September 2012, 20:32   #1  |  Link
Pra7ul
King of Pirates
MPC-HC madVR not working.
please, I need help with the setup of my MPC-HC player to play Hi10p video to it's best,but i am getting serious problem setting it up.
Refer Here i've mentioned all of what my Problem is.
Pra7ul is offline   Reply With Quote
Old 26th September 2012, 07:37   #2  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
This happens with Hi10P only?
Don't have much ideas either, make sure your GPU drivers and DirectX and madvr itself is up to date... Especially if you say it worked before.
Also just want to mention that while madvr is a good renderer, you're not getting much compared to any other renderer if Hi10P is your only concern. LAV does very good job dithering, not any worse than madvr.
Issue with mpc-hc not closing maybe bug in mpc-hc discovered after recent madvr change but this shouldn't affect playback.
Edit: just out of curiosity you can try this and see if it makes any difference...
Edit2: i noticed you use LAV audio and video. enable LAV splitter too. and in MPC-HC filters page disable all source filters and decoders. You have MPC-splitters disabled for mkv/mp4 but does LAV spliter works when you play stuff?
Old 27th September 2012, 18:56   #3  |  Link
Pra7ul
King of Pirates
Please help !!
Old 1st October 2012, 13:49   #4  |  Link
Chug a Bug
This this guide. If that doesn't work and VLC player doesn't either I guess you're out of luck.
Chug a Bug is offline   Reply With Quote
Old 2nd October 2012, 22:06   #5  |  Link
Pra7ul
King of Pirates
I tried the guide no luck.
when i select Playback > Output > DirectShowVideo > madVR
MPC-HC completely stops responding to Play,Pause,Stop,Forward&Backward... nothing plays just blank screen.
when i close Player, it still remains in taskmanager so i had to use "End Process" to close it and run it again.
currently using "EVR (custom presenter)"
i searched a lot and doesn't seems to find an solution, i guess i'll give up on madVR
______________________________________________________
Thanks for your reply !!
hi10p, madvr, mpc-hc
