24th September 2019, 11:59 | #17341 | Link |
Just use Process Hacker and save process priority for ffmpeg.exe and x264.exe/x265.exe
24th September 2019, 22:05 | #17342 | Link |
Hello,
I am a long time user/reader, first time poster. Great program, have been using it for a very long time. I just got the recent update and after processing a movie, I have no video, just a cover picture, and audio only. I have tried using both of the 2 new encoders and set them across the board for the options. Has any one had this happen or reported yet? I haven't seen anything in the last few pages. Also, when i tried to use DE, it failed on all of my video conversion attempts. Unfortunately i didn't screen shot or see any error logs to provide. Error Log: D:\>"D:\Blu Ray Tools\RipBot264v1.24.0\EncodingClient.exe" "D:\Temp\RipBot264temp\job1\job1_EncodingClient.meta" D:\>"D:\Blu Ray Tools\RipBot264v1.24.0\tools\mkvtoolnix\mkvmerge.exe" -o "D:\video.mkv" --compression 0:none --title "video" --default-duration 0:24000/1001fps "D:\Temp\RipBot264temp\video.265" --compression 0:none --language 0:eng --aac-is-sbr 0:0 "D:\Temp\RipBot264temp\job1\Encoded_Audio_1.aac" --chapters "D:\Temp\RipBot264temp\job1\chapters.txt" mkvmerge v37.0.0 ('Leave It') 64-bit Error: The file 'D:\Temp\RipBot264temp\video.265' could not be opened for reading: open file error. ------------------------- Elapsed Time: 02h:58m:03s Manually combine the chuncks, ran Job1_MuxFiles.bat, found output video at expected location, opened to find no video at all but has audio. RB Ssettings: MPEG-2 and Other set to LSMASH, the others are set to FFMS2. Last edited by silentstrife; 25th September 2019 at 02:02. Reason: update with error log |
25th September 2019, 09:55 | #17343 | Link |
Try again with new fresh job .
25th September 2019, 12:19 | #17344 | Link |
Hey Atak,
thank you for the suggestion, didnīt know that process hacker can do that. A first quick try didnīt help though. Still dropping CPU Usage when left alone.. For some reason I cannot change the power scheme permanently, Windows always reverts it after a few hours. Seems to be a standard behaviour, since I discovered this on several WIN10 machines which are completely different (win64/32/home/pro/etc, different CPUs..). I will have to do more investigation on this. |
25th September 2019, 12:22 | #17345 | Link |
I hope you left process hacker running in background because otherwise those processes will run with standard normal priority.
25th September 2019, 23:04 | #17346 | Link |
Hi Atk,
Yes that was a fresh job. The only thing i know happened was the update from version 1.24 to 1.25. I might just go back to 1.24 and disable the auto-update. If you can think of any info i can provide to help fix this issue please let me know. RB Job Settings - Profile - MA10 X.X 10 bit progressive HEVC, CQ 20, Denoise - MDegrain2 + KNLMeansCL, audio 2.0 Basic System info: Windows 10 Pro V.1903 CPU - i7-5960x RAM - 32GB GFX - RTX 2070 Last edited by silentstrife; 25th September 2019 at 23:08. |
26th September 2019, 09:02 | #17348 | Link | |
26th September 2019, 12:33 | #17350 | Link |
Have you verified that process in fact gets higher priority?
26th September 2019, 16:30 | #17352 | Link |
ByteShare
New x265 3.2
https://bitbucket.org/multicoreware/...leasenotes.rst Code:
Version 3.2 =========== Release date - 25th September, 2019. New features ------------ 1. 3-level hierarchical motion estimation using :option:`--hme` and :option:`--hme-search`. 2. New AQ mode (:option:`--aq-mode` 4) with variance and edge information. 3. :option:`selective-sao` to selectively enable SAO at slice level. Enhancements to existing features --------------------------------- 1. New implementation of :option:`--refine-mv` with 3 refinement levels. Encoder enhancements -------------------- 1. Improved quality in the frames following dark scenes in ABR mode. API changes ----------- 1. Additions to x265_param structure to support the newly added features :option:`--hme`, :option:`--hme-search` and :option:`selective-sao`. Bug fixes --------- 1. Fixed encoder crash with :option:`--zonefile` during failures in encoder_open(). 2. Fixed JSON11 build errors with HDR10+ on MacOS high sierra. 3. Signalling out of range scaling list data fixed. 4. Inconsistent output fix for 2-pass rate-control with cutree ON. Known issues ------------ 1. Build dependency on changeset cf37911 of SVT-HEVC. Last edited by byteshare; 27th September 2019 at 21:58. |
28th September 2019, 17:41 | #17353 | Link |
ByteShare
I have been having some slowness issues when doing any filters with my GPU, such as KNLmeans.
Looking at Process Explorer a bit more I realized that FFMpeg didn't show any GPU usage (GPU, GPU System Bytes, GPU Dedicated Bytes, GPU Committed Bytes) If I run the RipBot script in AVSPmod I do see GPU System Bytes, GPU Dedicated Bytes, and GPU Committed Bytes showing usage. The AVS Meter also behaves strangely, where the text fields go over the line and I have to scroll down to see all of the data. The script runs in RipBot (just using the Adaptive KNLMeansCL in RipBot to test with) and a job will complete. The output looks like I expect just very slow to get it. When running a job using KNLmeans I can't get a lot of CPU usage because my guess is the decoder (FFMpeg) can't supply enough to process). If I use a non-GPU filter the CPU can basically max out. Using non-DE mode at the moment. Any ideas what is happening? |
28th September 2019, 18:12 | #17354 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 28th September 2019 at 18:23. |
29th September 2019, 04:11 | #17355 | Link | |
ByteShare
Hmmm...now to figure out why I'm getting ~1-2FPS with a Geforce 980 and Ryzen 1700. I get without the GPU filter ~20FPS with the same x265 settings. I'm using about 1.7GB of GPU memory (of 4GB) from FFMpeg but the GPU core load (using Open Hardware Monitor) bounces between 0-13%. I've been working "around" it by using other encoders to use more CPU on sources that don't need filters. I would use DE mode but the second server usually never starts. I don't have an older version of RB to try, I think 1.23 but up to some point in 1.24 before something was changed. Is the one linked on the first page the first version of 1.24? I recall getting 8-12FPS with the same settings, granted different sources, but getting 1-2FPS on several sources with the most recent version of RBk./. I'll try updating my drivers for now. update: didn't seem to make a different. I also changed the following to no avail: my power profile to high performance and same for the Nvidia Control Panel "Power management mode" to "Perfer maximum performance". Last edited by byteshare; 29th September 2019 at 07:07. |
29th September 2019, 09:35 | #17356 | Link |
How many FPS do you get in avsmeter with only knlmeans enabled? 2fps on 1920x1080 is indeed very slow. I also get 2fps but on GeForce 710 (99% gpu usage)
30th September 2019, 01:18 | #17357 | Link | |
ByteShare
KNLmeansCL h=2 27FPS 90-95% GPU KNLmeansCL Adaptive h=2 ??FPS 80-90% GPU (AVSMeter shows the information scrolling so I can't see true FPS) KNLmeansCL Adaptive + MD2 h=2 ??FPS 0-20% GPU (AVSMeter shows the information scrolling so I can't see true FPS) In the OpenCL setup, I have x264 OpenCL acceleration set to no (none) device and KNLMeansCL set to Geforce GTX 980 Turning that on for x264 doesn't seem to help, but it does seem worse getting ~0.7 FPS. Running same HEVC (not with AVSmeter) with just these filters: `FastLineDarkenMOD4().LSFmod()` (video is in the actual script, so I didn't forget that ) I'm getting ~12 FPS Last edited by byteshare; 1st October 2019 at 19:15. |
30th September 2019, 10:05 | #17358 | Link |
Mdegrain2 running on CPU is a real bottleneck in your case. How many FPS do you get with mdegrain2 only?
30th September 2019, 16:31 | #17359 | Link |
I'm having an issue encoding audio to AC3 at the moment.
For some reason, RipBot produces an error any time I re-encode the audio to AC3. The error report states that the encoded audio file cannot be found. My sources are either full disc structure or MKV. Sometimes with DTS audio and sometimes Dolby Atmos. It always used to work perfectly so I'm not sure what has changed or whether it may be a local problem for me. Any ideas Atak? |
30th September 2019, 17:12 | #17360 | Link | |
