21st January 2013, 20:02 | #13982 | Link | |
Basically, I'm postulating that in the bass range (and only in the bass range), the same signal coming from two equidistant acoustic sources in a typical room will be coherent at the listening position, meaning that they will add up to +6dB, not +3dB. You seem skeptical, and it is true that right now I only have my microphone measurements to back that up. I should probably search for some authoritative reference to put an end to the speculation. One thing I'm 100% sure, however, is that +6dB *is* the right number if you're using a 2.1 system with bass management: indeed, in such a system bass from the two channels are summed electrically (as opposed to acoustically), and electric (voltage) sum of two identical signals definitely *is* +6dB. |
22nd January 2013, 08:21 | #13983 | Link |
Considering LAV fixed a crash when moving to extended display. Could the problem of MPC-BE >1596 auto pausing when a video is opened on an extended display when LAV and madvr 85.x is used?
Changing one of those things makes it play like it should. Reporting it to madvr and mpc-be has led to dead ends. |
22nd January 2013, 16:53 | #13984 | Link |
I'm having a odd problem. I've got a DVD rip into an .mkv via MakeMKV. It's MPEG video.
Using the latest LAV with MPC-HC and madVR it does not play using None as the Hardware Decoder but does play using Intel QuickSync (HD4000 graphics). Anything I can look at to see why this would be the case? |
23rd January 2013, 08:03 | #13986 | Link |
I have a problem when using LAV Splitter playing one MKV file as shown below. LAV Splitter loads both audio and play both of them at the same time... how do I select just the audio track from mka and disable audio track in the mkv file?
a.mkv (video+mp3) a.mka (flac) |
23rd January 2013, 08:14 | #13987 | Link |
LAV Splitter has no such feature, it is your player loading both files.
23rd January 2013, 08:27 | #13988 | Link |
unfortunately, MPC-HC doesn't see any audio track, but I got two instance of LAV Splitter. one loads the mkv file, the other loads just the mka file. would be good to be able to disable audio in one of the LAV Splitter instance.
23rd January 2013, 11:01 | #13991 | Link | |
MEDIASUBTYPE_ADTS_FOURCC = '{53544441-0000-0010-8000-00AA00389B71}'; //ADTS LAV Splitter
Bye |
23rd January 2013, 11:18 | #13992 | Link |
TBH, IAMStreamSelect.Info is hardly the correct function to try to probe for a media subtype, especially because it doesn't let you provide more then one, which is a very common use-case to support different filters that expect different things.
In any case, i cannot change this without sacrificing some functionality in LAV Audio, so i will not.
23rd January 2013, 18:30 | #13993 | Link |
Will the LAV Splitter support MKV Segment linking/Ordered chapters sometime in 2013?
It's the only feature I miss before I can uninstall the Haali splitter. Or is this a feature that you nevcairiel will never work on, and it's up to someone else to write the code for this to be implemented?
(i have a tendency to drunk post) |
23rd January 2013, 18:57 | #13995 | Link | |
Thanks... no need to reply to my other post then.
23rd January 2013, 20:52 | #13997 | Link |
Because turning it off should never be required, or its a bug.
24th January 2013, 06:57 | #13999 | Link |
Then don't use ICL builds.
If it works everywhere except in one specific build of one player, maybe you should look there and not here?
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 24th January 2013 at 07:50. |
