Old 7th March 2014, 04:46   #221  |  Link
kolpotoru
I have found a very useful article about joining video using ffmpeg here - http://trac.ffmpeg.org/wiki/How%20to%20concatenate%20%28join,%20merge%29%20media%20files
Please conciser adding video joining function in TEncoder.
kolpotoru is offline   Reply With Quote
Old 20th April 2014, 08:37   #222  |  Link
Ryo94
Hi ozok, is it possible to join/merge video segments (same AR, bitrate, codecs, etc) in direct copy (no losing quality) with tencoder? If not is there any chance to implement this in a near future? thanks in advance.
Ryo94 is offline   Reply With Quote
Old 20th April 2014, 13:32   #223  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
I probably will add it as a tool.
edit: To make it more clear, not as a separate tool but as a function under "Tools" menu.
ozok is offline   Reply With Quote
Old 20th April 2014, 19:17   #224  |  Link
Ryo94
That would be great! thanks a lot ozok!
Old 22nd April 2014, 15:06   #225  |  Link
ozok
ozok's Avatar
New version 3.9.0:
-Added: A tool to merge an image and audio to video
-Added: A tool to dub video with an external audio file
-Added: Many skins
-Added: MP4 muxing while using MEncoder will be done with MP4Box
-Added: File list now shows more information
-Added: "Copy date from source" will now copy last modified date too
-Added: An option, under "Help" menu, to create log archive in the desktop
-Added: Main window is now a bit larger as default
-Fixed: Program would crash when muxing to mp4 using MEncoder as encoder
-Fixed: Subtitle and audio delay values weren't saved properly
-Fixed: Applying a profile didn't update video size option
-Fixed: Video size option wasn't saved
-Fixed: Profile editor would ask to save profile even if nothing was changed/added
-Fixed: Scroll bars in logs window weren't visible
-Fixed: Enabling skins didn't apply hue and saturation options
-Fixed: Enable/disable skin options was not saved
-Fixed: Profiles created by the user couldn't be deleted
-Fixed: "Copy date from source" option wasn't saved
-Fixed: "'' is not a valid integer value." error
-Fixed: Couldn't add files without an audio stream
-Fixed: A few UI related problems
-Updated: FFMpeg
Download
Old 23rd April 2014, 02:11   #226  |  Link
Ryo94
New version rocks ozok, thanks! Just a little detail,
image&audio windows shouldn't look in this way?
Old 23rd April 2014, 11:45   #227  |  Link
ozok
ozok's Avatar
No it shouldn't. I suggest you disable skins altogether if they are causing this sort of trouble.
Old 23rd April 2014, 12:43   #228  |  Link
mbcd
Feature Request
Thanks for this good tool ozok,
but I have a feature request for it.
Does it make sense to set audio and subtitle tracks for all selected files?
I mean, i loaded a folder with lots of files. But I dont want to use the first audiotrack, but the second. So I select all files and change audio to second track. But the change is only applied to one single file, not to all selected. For batch conversation this is not very comfortable.
Maybe you can add a function to select the tracknumer, or language (languese would be the better one i think) an make it possible to apply this to all files together.
Would that make sense ?
mbcd is offline   Reply With Quote
Old 23rd April 2014, 13:30   #229  |  Link
ozok
ozok's Avatar
It makes sense and IIRC there was a feature like this in the first releases of TEncoder (it's been a while!). I plan to make a few changes to audio and subtitle track selection (ability to add subtitle files etc.) but I don't know if that feature will be added. For the time being however, you can use "export to script" and edit the bat file (replace all "-map 0:1"s to "-map 0:2"s for example) to get the result you want. Not ideal I know, but it might work.
Old 23rd April 2014, 19:34   #230  |  Link
Ryo94
I was talking about the stream order (in the screenshot I switch them) not about the skin look
Old 23rd April 2014, 20:47   #231  |  Link
ozok
ozok's Avatar
Sorry, I get complaints about skinning sometimes. Image is passed as the first input to ffmpeg. Their locations in the UI shouldn't make a difference.
Old 24th April 2014, 02:38   #232  |  Link
Ryo94
I know, I point it out just as aesthetic detail and in some way like a logic order in the UI,
(1)Image&(2)Audio To (3)Video
(1)Image
(2)Audio
(3)Output
Old 24th April 2014, 18:49   #233  |  Link
ozok
ozok's Avatar
I understand what you mean, I'd just thought there was something more serious I missed.
Old 27th April 2014, 00:56   #234  |  Link
duplakappa
Hello Ozok, I just encoded a video(mkv with .ass soft subs) to a mp4 with harcoded subs... i got that but the subtitles were HUGE, the mkv file had attached fonts and i installed them before encoding of curse so i dont know why that happened. Is there a way to make Tencoder respect the subtitle styles??? Thanks
duplakappa is offline   Reply With Quote
Old 27th April 2014, 12:33   #235  |  Link
ozok
ozok's Avatar
"Default scale" under "Subtitle" tab controls the size of the subtitle. I don't have that much experience with ass subs but IIRC they are treated like srt subs. Also, use preview function to see how changes to subtitle option works for you before running the actual encoding.
Old 27th April 2014, 13:56   #236  |  Link
Where did you get your MKV source file?
Old 27th April 2014, 14:23   #237  |  Link
duplakappa
From here: [link deleted]... why you deleted all the message??? You could just delete the attachment. Now I have to write all again. If you have a problem with the subtitles you can tell me...
Old 27th April 2014, 14:36   #238  |  Link
Discussion of downloaded content is not allowed here. Further violations will lead to strikes. Follow up to PM if you need to, don't discuss it here.
Old 12th May 2014, 00:36   #239  |  Link
whiskey
Drunken munky
I've just discovered this application and have one question. Is there option to base output bitrate on file size or only preset bitrates so far ?
whiskey is offline   Reply With Quote
Old 12th May 2014, 01:16   #240  |  Link
ozok
ozok's Avatar
TEncoder doesn't have such options. It is asked often, I will add file size option one day.
ffmpeg, gui, mencoder, multithreaded, subtitle
