Old 8th October 2011, 22:03   #1  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
TEncoder 4.5.2 - Multithreaded GUI for FFMpeg and Mencoder
TEncoder is a multithreaded gui for ffmpeg, mencoder and mplayer.
Features:
-Run up to 16 simultaneous processes and/or make FFMpeg and Mencoder to do internal multithreaded encoding.
-Hard-code subtitles with same name as video using Mencoder
-Rip unprotected DVDs
-Do two passes to improve quality
-Download video from YouTube etc
-Pass custom options to encoders
-Extract audio or video
-Extract parts from file
-Convert audio files (mp3 to aac etc)
-Select audio track from files with multiple audio tracks
-Extract jobs to .bat file so they can be run later
-Preview files with all options applied
-Edit/create presets
-Works under Wine
-64bit support (FFMpeg only)
Screenshot:
Downloads:
You can download it from here: http://www.downloadbestsoft.com/TEnc...Converter.html
TEncoder downloads version file from Dropbox. No information is sent during that process.
Any suggestions, criticisms etc are welcome.
ozok is offline   Reply With Quote
Old 9th October 2011, 10:06   #2  |  Link
Selur
Selur's Avatar
some suggestions:
- connect the container and codec selection or warn the user when a combination is chosen that will cause mencoder to write to another container than selected (mpeg2+mp3+wmv container -> avi(mpeg2+mp3))
- if input par != output par this should be respected during resize
- add (auto) crop support
- allow users to keep the current resolution
- preview for subtitles + font selection might be a good idea
- combobox for the audio track selection for streams with multi audio input
... (there are so many features one could add,.. )
Cu Selur
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 9th October 2011, 13:20   #3  |  Link
ozok
ozok's Avatar
@Selur thanks for suggestions.
Container changes according to selected video codec, but a warning could be shown if user selects a problematic combination.
Do you mean video size? If you select "Original" as video size, video size should be kept. But i dont know if that is what you mean by resolution.
Old 9th October 2011, 13:30   #4  |  Link
Selur
Selur's Avatar
yup, overlooked the 'Original' option
Old 29th November 2011, 13:17   #5  |  Link
ozok
ozok's Avatar
Hi all
There is a new version 1.4.
What's changed:
-Moved: Custom options, two pass and subtitle options to "Extra Options" window
-Added: Deinterlaceing
-Added: TEncoder will remember its last position and state
-Added: Custom audio and video options
-Added: Total progress is now updated smoothly
-Added: Open output folder option to post-encode options
-Added: Files that do not exist will be removed from list before encoding starts
-Fixed: Temp. folder could not be cleared if encoder log keeping was off
-Fixed: Flv, m4v and m2v files could not be opended sometimes
-Removed: Some of the skins
-Updated: AlphaControls to 7.55
-Updated: MediaInfo to 0.7.51
Old 23rd December 2011, 13:07   #6  |  Link
ozok
ozok's Avatar
Hi all!
There is a new version 1.5
--1.5 BETA
-Added: 5.1 channel support
-Added: Option to preserve aspect ratio
-Added: Encoder changes according to selected video codec
-Added: Options to select between multiple audio and subtitle tracks for each file
-Added: Option to specify encoding range (in sec.) for each file
-Added: Encoder output is shown during encoding process
-Added: Skins
-Fixed: AAC encoding problems with MEncoder
-Fixed: A few minor bugs
-Improved: Properties windows shows more info now
-Improved: Some UI changes
-Updated: AlphaControls to 7.57
-Updated: MediaInfo to 0.7.52
-Updated: FFmpeg to N-35966-g1d0ae92
-Updated: MPlayer and MEncoder to Sherpya-SVN-r34401-4.6.2
-Updated: libfaac to 1.28
PS Please note that this version BETA which means it has experimental features that may not work properly.
Old 21st January 2012, 13:03   #7  |  Link
ozok
ozok's Avatar
Hi all
There is a new version 1.6
-Added: Option to select audio or video only encoding
-Added: Support for audio encoding (mp3 to aac etc.)
-Added: Support for Webm (VP8 + OggVorbis)
-Added: Splash Screen
-Added: Option to apply range settings to all files in the list
-Fixed: FFMpeg encode range misscalculation
-Fixed: Command lines were not shown in logs
-Fixed: Default skin was not Ubuntu
-Fixed: FFmpeg Mpeg4+AAC+Mp4 problem
-Improved: Encoding screen is merged with main screen
-Updated: AlphaControls to 7.59
Old 9th February 2012, 18:14   #8  |  Link
ozok
ozok's Avatar
Hi all,
There is a new version 1.7
-Added: Player
-Added: Range Editor
-Added: Option to specify subtitle delay for each file
-Added: Option to specify audio delay for each file
-Added: Audio and video bitrates can be entered manually
-Added: 4 more aspect ratio options
-Added: Installer can create folder group in start menu
-Added: MPlayer log
-Added: Two new skins Lucy and Air
-Fixed: MEncoder encode range miscalculation
-Fixed: MEncoder no audio problem
-Fixed: None as video and audio codec warning
-Fixed: Subtitle and audio problems if file removed because it doesn't exist
-Fixed: Drag and drop did not work
-Fixed: Encoding time was not accurate
-Removed: Splash screen because it causes problems with drag and drop
-Improved: Some minor UI changes
-Updated: MediaInfo to 0.7.53
-Updated: AlphaControls to 7.60
-Updated: FFMpeg to git-6833fe4
Old 11th February 2012, 20:46   #9  |  Link
ozok
ozok's Avatar
Hotfix
Hi all,
There is a new version 1.7.1 Hotfix.
-Added: Support for m2ts files
-Fixed: FFMpeg two pass problem
-Fixed: FFMpeg aspect ratio problem with VP8
-Improved: A few minor UI improvements
Old 13th February 2012, 20:55   #10  |  Link
DJ-1
I`ll give this a try...
Does this use Nero AAC+ ? as far as i know thats the latest, i usually use HDConvertox `just for audio` then MUX it all together....
as Vidcoder`s AAC isnt as good.
cheers.
DJ-1 is offline   Reply With Quote
Old 13th February 2012, 23:29   #11  |  Link
ozok
ozok's Avatar
@DJ-1 no it doesn't use Nero AAC, it just uses FFMpeg and Mencoder as backends. But i might add support for other tools in the future.
Old 19th April 2012, 13:37   #12  |  Link
VoXHD
Nice piece of work, pretty fast encoding and good result quality.
But:
- a custom resize would be very useful. I mean, I want to convert from 1080p>720p (1280x544/536) and there are only standard sizes for downscaling. I need 1280x544 with "keep aspect ratio-Original".
- estimate filesize of converted file would be nice, also, before start the conversion
- a pause/resume function/button.
Hope you take a look !
VoXHD is offline   Reply With Quote
Old 19th April 2012, 14:15   #13  |  Link
ozok
ozok's Avatar
Custom video size option is coming up with next release.
I'll look into others as well.
Old 19th April 2012, 14:24   #14  |  Link
ozok
ozok's Avatar
There have been two new releases:
--1.8.1 Hotfix
-Fixed: New resolution values were not effective
-Fixed: Total progress value would exceed 100
-Added: Option to use source folder as output folder
-Added: Hue for skins
-Added: Post-encode option to settings window
-Added: New resolutions
-Added: New fps values
-Improved: Settings window UI layout
-Fixed: 29.99 is corrected to 29.97
-Fixed: Icon resolution problems
-Fixed: Portable version would delete wrong txt files
-Updated: MediaInfo.dll to 0.7.56
-Updated: AlphaControls to 7.63
-Updated: JVCL to 3.45
-Updated: FFMpeg to N-39664-g6bfb304
-Updated: MEncoder and Mplayer to svn-34401
Old 19th April 2012, 17:05   #15  |  Link
cengizhan
change apply button caption to load. it is confusing. also save/edit button should copy current settings from main window, should not display default settings.
cengizhan is offline   Reply With Quote
Old 19th April 2012, 21:36   #16  |  Link
VoXHD
i think you made a mistake.
should be "Custom" at size, not "Original", and let me chose my desire size. I've made some short tests with "Original", but my "1280x..." custom size and no changes.
Format : AVI
Format/Info : Audio Video Interleave
File size : 61.5 MiB
Writing application : MEncoder Sherpya-SVN-r34401-4.6.2
Writing library : MPlayer
Video
Format : MPEG-4 Visual
Codec ID : FMP4
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Take a look:
Size should be not Original, but Custom 1280x536.
And where is that MPEG4 settings window from previous version? Trellis, Constant Bitrate, ClosedGOP....
Old 19th April 2012, 22:08   #17  |  Link
ozok
ozok's Avatar
i think apply applies there better. Profile editor shows values from selected profile. Shouldn't it be that way?
I think there is a misunderstanding here. From now own, values that'll be passed to encoders are the values of the boxes you indicated with red. List is just some sort of suggestion. In short, everything except "Original" is "Custom".
I'll change texts around them to prevent further misunderstanding.
It was a mistake I made, that feature was not finished then and I'm still working on it. I'll make sure it comes with new release.
Old 19th April 2012, 22:11   #18  |  Link
ozok
ozok's Avatar
Update
There is a new version 1.9
-Added: Option specify custom video width and height values
-Added: Audio extraction now produces valid files
-Added: A new skin: LightBoard
-Fixed: 1440x1080 resolution was passed wrong to the encoders
Old 19th April 2012, 22:25   #19  |  Link
VoXHD
Yap, my bad. I got it in the and. It must be choose an approximated Custom size from that list (in my case - 1280x720) and then my size 1280x536 in the boxes below.
Another problem with this Custom resize: it seems to let artefacts after conversion. A green line (that green line...) up the movie screen, and some strange lines at the bottom of the screen:
http://i39.tinypic.com/1znq3k0.jpg
http://i41.tinypic.com/o8e7hi.jpg
http://i40.tinypic.com/2gwrhiw.jpg
Old 20th April 2012, 03:41   #20  |  Link
cengizhan
Also i never got a successful output with (mkv, ffmpeg, h264,aac). Always breaks after first pass resulting with a 0 byte file.
ffmpeg, gui, mencoder, multithreaded, subtitle
