Old 28th June 2007, 05:32   #421  |  Link
adrianmak
Please post a link to the file or a fragment thereof.
Not only just my h264 file, I tried a clip posted by others are having the same problem.
The is a clip posted by other (on page 15 of this thread)
http://rapidshare.com/files/32723790/test.264.html
adrianmak is offline
Old 28th June 2007, 09:05   #422  |  Link
lucassp
that file is garbage, don't use it. it a h264 stream demuxed from a MKV file with mplayer. the same thing worked ok when I replaced mplayer with the MKV tools that come with MeGUI!
lucassp is offline
Old 28th June 2007, 12:30   #423  |  Link
adrianmak
My h264 files are demuxed from mkv thru mkvextract.
Old 28th June 2007, 12:37   #424  |  Link
Inventive Software
Turkey Machine
Then post the file you had that was causing problems.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 28th June 2007, 14:35   #425  |  Link
adrianmak
This is my h264 clip
http://www.divshare.com/download/1103616-217
Old 28th June 2007, 18:33   #426  |  Link
crapz0rs
Originally Posted by adrianmak View Post
I can playback/index this track perfectly fine with dgavcdec alpha 5 & 6
crapz0rs is offline
Old 29th June 2007, 00:23   #427  |  Link
adrianmak
Then Why dgavcindex crach while reading a h264 file ?? Any other factors casuing this problem ?
Old 29th June 2007, 00:39   #428  |  Link
Did you try the libavcodec from ffdshow?
Try putting the file in c:\ and opening it there (to rule out path problem).
Guest is offline
Old 29th June 2007, 01:20   #429  |  Link
adrianmak
I tried reading the h264 file where put under c:\ but DGAVCindex still crash.
ffdshow ??? I ve ffdshow installed but not the tryout version mentioned in this thread.
Old 29th June 2007, 03:53   #430  |  Link
adrianmak
I guess there are some software conflicts on Windows XP and I can't figure it out.
Is it possible to trace out which software conflict with dgavcindex without reinstalltion of OS
ps. I'm able to open h264 file on another PC.
Old 29th June 2007, 10:10   #431  |  Link
Inventive Software
Turkey Machine
Only things I can think of are Dependancy Walker, and Process Explorer. Run both and see what's conflicting. Dependancy Walker should be able to tell you if there's a DLL missing; open DGAVCIndex.exe and libavcodec.dll to find out. Process Explorer is good to find the DLL that the program's missing while it's running so that you can diagnose what's causing the problem.
Old 29th June 2007, 10:43   #432  |  Link
adrianmak
How to use dependencywalker for investigation ?
I opened the dgavcindex.exe and show an warning
"Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module."
This is the screen cap
Old 29th June 2007, 13:31   #433  |  Link
Inventive Software
Turkey Machine
OK, give us this info if you would be so kind.
Scroll down both lists and give us the names of the offending item(s) (they have exclamation marks next to them). Hopefully, we can nail this lil bugger.
Old 29th June 2007, 14:06   #434  |  Link
adrianmak
I can't see any item with an exclamation marks.
Old 29th June 2007, 14:59   #435  |  Link
Inventive Software
Turkey Machine
OK, I'll have to do some digging on my system then and see if I have the same issue.
Old 3rd July 2007, 21:28   #436  |  Link
Seba-
Any news with implementing PAFF support?
Seba- is offline
Old 3rd July 2007, 21:37   #437  |  Link
I'm working on transport stream support right now. I'll let you know if and when I start working on that.
Guest is offline
Old 3rd July 2007, 22:01   #438  |  Link
dorati
deblock=false
What mean this parameter?
When i must use deblock=false and when not?
dorati is offline
Old 3rd July 2007, 22:03   #439  |  Link
If you want to see the effect of turning off the AVC in-loop deblocking. It's not recommended to encode that way but it is interesting to be able to see the effect of this AVC feature.
Guest is offline
Old 4th July 2007, 00:27   #440  |  Link
adrianmak
Any findings of my problems ??????
