3rd May 2009, 23:45 | #842 | Link | |
Playing in PowerDVD7 with DXVA was the only thing I could get smooth playback from. When you're running at 2.7GHz, are you just getting smooth playback? E.g. you're running at 90,95% CPU usage? I'm starting to think that the E5200 at its stock 2.5GHz was maybe just too slow, as I've seen people saying they're getting smooth playback on 2.7, 2.8GHz Dual-Core machines. I've just tested Apocalypto again now that I'm running at 3.7GHz though. (296×12.5) I let it run for about 5/6 minutes to get a decent graph of CPU usage. (set to fastest update speed) http://img72.imageshack.us/img72/4629/apoc.png This is just running the m2ts file straight off the disc in MPC-HC with CoreAVC (software) and madVR enabled with no 3DLUT and Bilinear resampling. No subtitles or anything else running. (though you would need them for this film…) As you can see, there are peaks there which are around 85, 90% which means a 3.2, 3.3GHz machine would be required to play it back smoothly? I hope I'm not taking things too far off topic here. Last edited by 6233638; 4th May 2009 at 00:05. Reason: typos |
4th May 2009, 00:06 | #843 | Link |
3 eyed CRT supporter
I have a Q6600 Quadcore overclocked from 2.4 to 3.0ghz, and I can play all AVC material, including Apoc, with about 35% CPU usage (using CoreAVC). One core will be a bit higher than the others however...balancing is the tricky part.
I have enough CPU left over I can apply sharpening filters, resample the audio to 96khz with libsamplerate, run Digital Room Correction on 6 channels.....ok, depending on the sharpening filter that starts to push it too far...but just "playing a Bluray" in software is a trivial task. Aim high as you can (and stick the PC in the next room to the HT!!). |
4th May 2009, 00:44 | #845 | Link |
Ok, thanks. I should point out that it's the UK disc I played, but I don't think that will make any difference. (the main m2ts file is 32.2GB on the disc)
This has been running stable at 3.7GHz for a good few hours now, so I think I'm ok to leave it running at that, and it seems to have fixed things as far as CPU usage is concerned. (Apocalypto has been the most demanding disc I've found so far) I'm not getting perfectly smooth playback yet, but that's probably a madVR issue as CPU usage isn't going over 90% even at the most stressful bits. (with it typically being in the 60-80% range) Last edited by 6233638; 4th May 2009 at 00:47. |
4th May 2009, 00:45 | #846 | Link |
Broadband Junkie
I can confirm that madVR doesn't work with the NVIDIA MPEG2 decoder when I tried playing some 1920x1080 and 1440x1080 transport streams (black screen, no stats or anything). DVDs on the other hand play fine with madVR and the NVIDIA decoder.
4th May 2009, 01:18 | #847 | Link | |
As for comparison v. 3.1GHz c2d (E8500) here. I've just tried mVR playing native 1080p avc content from bluray. I don't have 40mbps, however it is still quite good, 25mbps stream AVC High Profile. No DXVA/CUDA anything as my gfx doesn't support it yet. 50-60% CPU usage with mVR and 30-40% with Haali (so roughly 20% CPU consumption difference). |
4th May 2009, 02:07 | #848 | Link |
No problem, thanks.
Yes, VMR and EVR CP both play fine in D3D mode. The only problem I have is I can never have any UI elements, but that's another thread. I'll keep hammering on it as new versions come out.
Chumbo |
4th May 2009, 02:24 | #849 | Link | |
Nvidia -> ffdshow -> madVR in Zoom Player results in a corrupt picture (luma and chroma don't match up or something like that) with HD material. However Nvidia -> ffdshow -> any other renderer results in no picture at all. Again there were no problems with SD. I think the Nvidia decoder is fussy in some way when it comes to HD, but this is either a decoder oddity or a problem with my pc. Presumably the former as others have had issues with this decoder. Certainly the problems I've found with it aren't exclusive to madVR, and everything works fine with madVR when using DScaler5, ffdshow or PowerDVD filters to decode instead. |
4th May 2009, 02:49 | #850 | Link |
Broadband Junkie
The thing is, madVR is the only renderer that has issues with the NVIDIA decoder playing high-def content (VMR9, Overlay, EVR, & Haali are all fine). Since that is the case, you would assume madVR is at fault. On my machine NVIDIA -> ffdshow -> any other renderer (VMR9, Overlay, EVR, & Haali) and I get a perfect picture. NVIDIA -> ffdshow -> madVR gets misaligned luma and chroma, as you mentioned.
4th May 2009, 03:17 | #851 | Link |
With all other renderers (and software decoding) it connects using YUY2. Perhaps it's a HD YV12 connection that causes the problem? Mind you, connecting the Nvidia decoder with YUY2 instead of YV12 to ffdshow and AviSynth doesn't make any difference for me so perhaps not.
I wonder why I don't then? Might be my ffdshow version (revision 2527). To be honest I don't ever use the Nvidia decoder except for odd occasions like now. Interestingly I remember that I stopped using it when I first came across an HD MPEG-2 stream because I ran into some problem. Unfortunately I can't remember what the problem was... |
4th May 2009, 03:46 | #852 | Link | |
I have had the Nvidia decoder working with the Arcsoft filters in the past for DXVA acceleration on BR content, so it is possible. This is with MadVr for final output. I don't bother with HD content as I have about 600 SD DVD's which I scale to 1366 x 768. It is the panels native resolution, so I am stuck with this for now. The new 09 renderer works quit well as long as I do not push the resampling to hard. With resampling at default values I can turn off the anti tearing option. If I resample with lancoz 8 and tearing off I then get tearing on the top of the screen. Just my .02 MAK |
4th May 2009, 06:42 | #853 | Link | |
So for MadVR 0.7 and 0.9: avr gpu 0.9 - upd text 0.9 <> (?) avr gpu 0.7 ? |
4th May 2009, 06:59 | #854 | Link | |
4th May 2009, 10:47 | #855 | Link |
MPC-HC Project Manager
@Everyone discussing CPU for AVC decoding.
The samples mentioned are relatively easy to decode and do not require a C2D @ 3ghz. For smooth playback you need a peak cpu usage of no higher than 75%, above this value dropped frames and/or jitter (might) become a problem. Really difficult movies (of which very few exist) will only meet this limit on a 3ghz+ C2D or any Quadcore CPU worth its salt. I must admit that some pretty cool updates have been made to both ffdshow and coreavc since i saw the last benchmarks and i can image the required CPU power having come down a bit since then. I know of 2 really difficult samples that drop frames even on cheaper standalone players. 1. The "killa" or "killer" sample (have never been able to find it myself though) 2. A scene from i believe BBC's planet earth. This scene involves a pan over a heavily forested mountain range, a large group of birds fly by. The changes from one frame to the next are so large that almost none of the optimisations help out here and each and every frame needs to be completely decoded, the AVC also maxes out all the legal bluray specs. But like i said, most AVC files don't even come close to this level of complexity/difficulty to decode and it's these scene's that require the 3ghz CPU. Last edited by tetsuo55; 4th May 2009 at 10:50. |
4th May 2009, 10:54 | #856 | Link |
@Madshi:
Bugreport: Settings are not saved when madVR is run from a protected directory. I reported earlier that the .bat install method does not get the required admin rights needed to install madVR. I found a new problem related to installing madVR to a protected directory like "program files" Because the filter is not run with admin rights i am unable to save the settings (because obviously "program files" is read only to any non-admin application) madVR does not show an error that saving settings failed (i think it just assumes it will always work) To work better in the future madVR should be limited user aware, and should ask for admin rights when saving settings. I can also confirm the DVD decoding problem. I will try to make a small (couple of MB) fake dvd and see if that produces the error.(which i can then upload for you to test with) P.S. If anyone else want's to make a small dvd sample, please go ahead, it will take a while before i will be able to do so. any dvdmastering software could be used for this with a small free-to-distribute sample, like big buck bunny Last edited by tetsuo55; 4th May 2009 at 10:57. |
4th May 2009, 11:38 | #857 | Link | |
It should read ~95.904hz (it's interlaced, but that's irrelevant). Display 2 is right. Display 3 reads 130+hz fullscreen, and 105+hz in a window. Not sure if you are worried yet, but v0.9 is not smooth like v0.8 was. Thanks Mark |
4th May 2009, 16:39 | #858 | Link | |
As for the 75% CPU consumption, that is the reason for my worries, as with mVR 1080p bluray video is just a bit below that threshold, 60% CPU on the OP scene. With Haali it is typically around 40% so if I watched blurays I'd choose Haali over current version of mVR due to less CPU power. As for the different CPU-only codecs, you must be wrong. I even rechecked it again with that 1080p video and as expected there's little to none difference in CPU amongst MPC internal, ffdshow or CoreAVC. They use different cpu% on different scenes so hard to say, but as a stab most of the times cpu load difference is within 5%. As for the absolute values, 1080p AVC high-profile rendered and downscaled to 720p by mVR (shader math only) takes about 30-45% CPU. Which is substantially less than rendering same video without any rescale that takes about 50-60%. Very roughly, the codecs may be ranged as follows: CoreAVC, MPC internal, ffdshow in the order of CPU load but again the difference is so small that can be discarded (for instance I don't even use CoreAVC nowadays since no CUDA gain for me anyway). |
4th May 2009, 18:13 | #859 | Link |
I can confirm that cpu usage when using madvr is much reduced. I tested 720p h.264 as its the only source resolution i can play on my system. And its playable now! I get similar result with evr actually. Tested with MPC HC 1093 on ati 3450.
Softcubic is very smooth but at least cause no ringing and jaggies. Another nice scene to test is very begining of "Flushed away" with dreamworks title appearing from balloons. Edit: Ok i was too enthusiastic madvr still takes about 20% more cpu than evr. But is better compared to constant 100% in previous versions. Last edited by littleD; 4th May 2009 at 19:00. |
4th May 2009, 19:17 | #860 | Link | |
I have yet to actually encouter a problematic movie in real life, so far everything has worked just fine on a c2d mobile 2,6 ghz(although i have seen cases go over 75% for a second) |
