3rd April 2012, 07:20 | #42 | Link |
Hi henryperu77:
For my tests (for now) I have found it best to use DeCelluloid after IVTC (I have only tested for that case, anime content). Otherwise one should use, I suppose, something like this: AssumeTFF () SeparateFields () DeCelluloid () Weave () Somebody correct me if not for interlaced content. In any case you should preview in VirtualDub how you remaining in both cases and make processing test with small pieces of video. |
15th January 2013, 02:41 | #43 | Link |
[EDIT FIXED]
Odd, I CANNOT get RemoveGrain to work anymore. It used to work, and I can load the plugin with either LoadPlugin or just autoloading from the plugin folder - no apparent problems there. However, a call to DeCelluloid complains about missing functions - like BackwardClense. It like RemoveGrainS.dll doesn't get loaded at all. I need to fix some glue (or celluloid) in an old Anime. This is on Windows 7 x64. Anyone know what the problem could be? Ps. Tried reinstalling Avisynth obviously. No luck. [WHAT WAS WRONG] I'm missing some DLLs, and I can't figure out which. The wiki page (http://avisynth.org/mediawiki/Removegrain) contains broken links, and the info is pretty sparse (the RemoveGrain docs are no better). I fixed it by getting the entire removegrain package, and only using the statically linked files (those ending on "S"). Note: I miss out on all the SSE3 optimizations though, which is a shame. [EDITx] Finally figured it out... was missing AvsRecursion.dll I really really wish this was mentioned somewhere. Spent the better half of 12 hours looking trying to get it to work. Oh well, all is good now. Last edited by Space Hopper; 16th January 2013 at 06:37. |
17th January 2013, 01:43 | #44 | Link | |
I like the idea though. But I guess one has to face the fact that this is hard to fix automatically. |
17th May 2013, 23:58 | #45 | Link | |
This script is a start, there is still no magic formula for dealing with these cases. |
7th April 2018, 20:21 | #46 | Link |
Just thought I'd throw out my concept for how to fix this. Needs someone more experienced than me to implement.
First, use scene change detection to define scenes - focus on the whole rather than just the separation point. Ignoring the first 4 and last 4 frames of the shot, Average the remaining frames. Compare the difference between the resulting "Average" and the Middle frame of the shot. Set a maximum difference value (even better if you can find a way to only average static portions). If the difference value is low enough, the shot is static. Otherwise, assume a pan. On static shots, use the average found earlier. Working backwards, check the difference of frame 4 and 5. If 4 is a bad frame, use image registration to align. Otherwise skip to 3, etc. When all 4 frames are checked and aligned, a small clip is created, essentially In frame order for that shot, 8,7,6,5,4,3,2,1,2,3,4,5,6,7,8 (provides continual motion to better calculate vectors. Use this clip to generate the mask to be applied to the bad frames. For Pans, the previous clip will be examined to determine whether it is static. If so, the final two frames of the previous shot will be run through QTGMC to generate 2 motion compensated extra frames. If both shots are pans, the previous longer step will be applied to both. |
25th May 2021, 18:09 | #48 | Link |
Hi, I am having trouble with my DeCelluloid script (see post #40), some greenish frames appear, here is a sample:
Sample2 The culprit is RemoveDirt 0.9.3 and SCSelect, I had to reuse the old RemoveDirt SSE2 1.0 Last edited by GMJCZP; 26th May 2021 at 14:08. |
anime |
