#161 | Link | |
It would be great if DGAVCIndexNV contained a check, so that people don't accidentally decode unsupported streams. |
#162 | Link |
Yeah people create all kind of complexitys that are just to much for sane Hardware Decoders
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 15th September 2008 at 01:04. |
#163 | Link |
I see the artifacts now. Thank you.
I have a directory where I am collecting bad streams for CUDA. This has joined the collection. I'll be sending them to Nvidia for analysis. They've already fixed one bug exposed by some of my streams. |
#166 | Link |
Posted one day ago:
http://forum.doom9.org/showthread.ph...58#post1183558 What do you want, hourly updates? I do have a life, you know. ![]() It's basically working but there are some hangs on seeking that I am working on. If I don't sort it out in a few days I'll put out an alpha that at least does straight linear encode so that you can assess the effectiveness of the entire process when transcoding. Last edited by Guest; 16th September 2008 at 00:58. |
#168 | Link | |
#169 | Link |
I've just now found and fixed the problem with random access. I haven't coded anything for end of file yet so it just blows up. That shouldn't take me long. Looks good for an alpha tomorrow. The CUDA engine is a finicky beast and you have to get all your ducks in a row to reset it gracefully for a seek.
#174 | Link |
We have a problem, Houston.
Everything was looking good. I could open my indexed stream in VirtualDub, play and preview, and seek around.
Then I decided to try an encode. I fired up HCEnc and started an encoding. As the second pass began, HCEnc started reporting a mismatch in the number of frames between the first and second passes. Hmm, that's odd. And the resulting M2V was garbage. Then I tried a simple HUFFYUV encode in VirtualDub. Worked great. Then a Cedocida DV encode. Worked great. Note that these are one-pass codecs. Then I tried MeGUI with CE-Baseline. It crashed when I added the job to the queue. Then I tried DivX. It crashed. So now I'm thinking, these guys are opening the AVS file twice or something, creating multiple instances of AVCSource(). So I opened the script in VirtualDub. Fine. Then I opened it again in VirtualDub, leaving the first one open too. Oops. The timeline looked just like the garbled M2V from HCEnc. So the situation now is that I will try to verify my theory about the multiple opens and see if there is any mitigation for it (floating CUDA contexts?). But be aware this has a strong potential to be a deal killer. |
#175 | Link |
Compiling Encoder
so there's a restriction that can only have one instance of the script open at once?
that shouldn't stop you from continuing to develop it, many encoders encode to lossless (ffvh, ffv1, lags, etc.) first then encode the lossless in their lossy encoder of choice, so they wouldn't have problems using it. |
#176 | Link |
Mr. Sandman
neuron2 cant you just fake the instances? i mean if the AVCSource() is using the same input, just redirect the second or nth instance to the first...
#177 | Link | |
Meanwhile, do you know how MeGUI works inside? Am I correct that it opens the script several times? Why would it crash when I just add the job to the queue? |
#178 | Link |
Mr. Sandman
yes, it opens several times coz before enqueuing the script is alredy open for displaying the preview. also megui stores 2 custom variables in the avs script for AR.
so when you hit enqueue the script is opened again for reading those vars and other stuff. however the lack of multi-tasking (or multi-instancing) in cuda is quite a limiting factor.
#179 | Link | |
After more thought, I don't think you can redirect an open filter instance to another one. I'd have to ask IanB about it, but I don't think Avisynth has that capability. |
