Old 25th April 2009, 12:35   #1201  |  Link
squid_80
neuron2: Are you aware that due to a limitation of the nvcuvid decoder, clips with 16 reference frames are not decoded correctly?
squid_80 is offline
Old 25th April 2009, 13:53   #1202  |  Link
I wasn't aware of that. Anyway, who would use 16 refs? Think of the massive DPB that would require.
Guest is offline
Old 25th April 2009, 14:07   #1203  |  Link
squid_80
I fully agree, FWIW. Unfortunately people still do it.
The problem isn't the total size of the DPB (although it can be on cards with only 256MB), it's mainly due to windows/DXVA only allowing a DPB made up of 16 frames. In theory this is ok since non-ref B frames can bypass the DPB but this isn't how the nvcuvid decoder works - every frame is decoded via the DPB and if there's no free slot (all filled with reference frames) artifacts show up.
squid_80 is offline
Old 28th April 2009, 07:40   #1204  |  Link
Manaka
Does DGAVCDECNV support x64 ? If yes I can try it on my Vista x64 with x264 x64. And I wonder about speed increase compare with ffdshow. thanks
forgive my bad english
Manaka is offline
Old 28th April 2009, 13:59   #1205  |  Link
People are running it successfully on x64, though I do not have an x64 machine.
Depending on your machine, you may get a performance increase for transcoding, but you also may get only a very small increase.
Guest is offline
Old 2nd May 2009, 02:28   #1206  |  Link
xopowo
Yes, it works very well on an x64 platform. I have tested with Xp, Vista, and Windows 7 64-bit Operating Systems.
xopowo is offline
Old 2nd May 2009, 20:44   #1207  |  Link
yesgrey
I was backing up a movie using DGAVCDecNV for frame decoding and today, in the morning, after several x264 hours, when I looked into the computer I had a dialog stating that there was some cuda error decoding the frame. Everytime I closed the dialog, a new one appeared. I had to abort the encoding. After this I have opened the Avisynth script in VirtualDub to see if there was any error decoding the frame in which the encoding stopped, but there was no problem, it worked flawlessly.
It was my first real encoding using DGAVCDecNV. Before this, I have tryed it with small video segments and worked good. Only now, during a full movie encoding, this happened.
Any idea what could have happened?
yesgrey is offline
Old 3rd May 2009, 01:09   #1208  |  Link
Originally Posted by yesgrey3
some cuda error
Next time write it down and report what it is.
Guest is offline
Old 3rd May 2009, 04:04   #1209  |  Link
squid_80
Try disabling your screen saver.
squid_80 is offline
Old 3rd May 2009, 13:45   #1210  |  Link
yesgrey
Is there any list of the possible errors available? If I see it, I can recognize it...
I think it was something like:
error.cuda.framedecoder()
Is disabled.
yesgrey is offline
Old 4th May 2009, 10:00   #1211  |  Link
yesgrey
I think I have discovered what happenned...
Yesterday I started the compression job again. At night, when I decided to go to bed and leave the PC running for the night, I was going to hit Ctrl+Alt+Del to keep the PC in locked mode. Then I remember the tip from squid_80, about the screen saver... I have it disabled, but when we hit Ctrl+Alt+Del to lock the PC, it enters a different state, covering the desktop with the login dialog.
I can not test it again right now because I don't want to mess up the encoding again, it already passed the critical point of yesterday.
I will test it and update here as soon as I could.
yesgrey is offline
Old 4th May 2009, 14:17   #1212  |  Link
Yes, that is very likely the reason. The video driver gets into a different mode.
Guest is offline
Old 5th May 2009, 22:29   #1213  |  Link
yesgrey
I confirm. It was it. We cannot lock our computers while frame serving with CUVIDServer.
When I unlock the computer I have this message on screen:
When I close this dialog, appears this other message:
When I close it, appears the first again, and it keeps like this, always showing both messages, one after the other.
I believe this should be a problem in CUVIDServer. Do you think it could be fixed? If not, I think it's a good idea put a warning in your guides, because it's a bit annoying to crash a long encoding job just because we locked our computers for security reasons...
yesgrey is offline
Old 5th May 2009, 22:42   #1214  |  Link
laserfan
Aging Video Hobbyist
Maybe I'm off-base w/this suggestion, but you might want to see if it works to run CUVIDServer as a service:
http://support.microsoft.com/kb/137890
I haven't tried it (yet) myself...
EDIT: Well I tried but was not successful in getting this to work. Maybe it's due to my XP x64 OS, or CUVIDServer itself, or maybe I didn't implement it correctly. Seems like a reasonable thing to attempt for a PC that uses it a lot though!? If anyone else can get it to work by all means please tell.
laserfan is offline
Old 8th May 2009, 17:26   #1215  |  Link
rack04
Is there a way to index only a specific number of frames?
For example:
I've set up a batch file which uses the WriteFile function in AviSynth to identify frame count, frame rate, width, and height of video streams. Currently, I index the entire h264 stream using DGAVCIndexNV, create a AviSynth script, and then feed the AviSyth script to ffmpeg to generate the WriteFile text file. Ideally, I'd like to specify just a few frames to index so this process is quicker. Though I don't know if this is even possible. Thanks.
"%DGAVCIndexNV_PATH%" -i "%INPUT_VIDEO%" -o "%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-output.dga" -e -h
Echo LoadPlugin("C:\Program Files\DGAVCIndexNV\DGAVCDecodeNV.dll")>"%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-analyze.avs"
Echo AVCSource("%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-output.dga")>>"%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-analyze.avs"
Echo WriteFile("%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-framecount.txt","Framecount")>>"%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-analyze.avs"
Echo WriteFile("%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-framerate.txt","Framerate")>>"%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-analyze.avs"
Echo WriteFile("%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-width.txt","Width")>>"%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-analyze.avs"
Echo WriteFile("%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-height.txt","Height ")>>"%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-analyze.avs"
goto ffmpeg
:ffmpeg
"%ffmpeg_PATH%" -i "%WORKING_DIRECTORY%\%OUTPUT_FILENAME%-analyze.avs"
goto end
rack04 is offline
Old 10th May 2009, 15:40   #1216  |  Link
yesgrey
Feature request: is it possible for you to include in the log file a small list (the higher 5) with the number of the frames that have the maximum bitrate? The higher the bitrate, the more complex the frames should be, so these frames should be a good reference when we are trying to find the apropriate encoding settings...
yesgrey is offline
Old 12th May 2009, 14:13   #1217  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
According to the doc for the command line use :
-o filename Name of output index file, including the .dga extension.
it seems that this is not the case with both DGAVCIndex(NV) tools...I tried:
DGAVCIndexNV.exe -i "E:\myfile.ts" -o "E:\myfile" -a -e -h
and dga file extension is missing. On the other hand, if I specify dga file extension for output,
DGAVCIndexNV.exe -i "E:\myfile.ts" -o "E:\myfile.dga" -a -e -h
audio streams extracted have this extension in their file names. This is not the case for DGindex...
Is this intentional ?
Kurtnoise is offline
Old 12th May 2009, 14:34   #1218  |  Link
You're supposed to include the .dga but if it then appears in the audio filename, then it's a bug. I'll fix it.
Guest is offline
Old 12th May 2009, 14:42   #1219  |  Link
Kurtnoise
Kurtnoise's Avatar
Just to be clearer about audio streams...I've got this by example :
myfile.dga PID bc5 L2 2ch 48 160 DELAY -424ms.mp2
Should be better like this:
myfile PID bc5 L2 2ch 48 160 DELAY -424ms.mp2
This occurs only using command line, of course.
Old 14th May 2009, 18:45   #1220  |  Link
D-Train
Has anyone got DGAVCDecNV working with an onboard video card?
I'm looking to pair a mobo w/ onboard GeForce 8200 with an X4 920 2.8GHz processor.
The Nvidia site seems to indicate it would be supported:
http://www.nvidia.com/object/cuda_learn_products.html
One of my requirements for the new build is to frameserve AVC content. A main source for my content are Dish Network captures and I always had problems with the PAFF encoding with DGAVCDec, although I admit I haven't checked for awhile. It sounds like DXVA has better PAFF handling than libavcodec.
Thanks!
D-Train is offline
