26th May 2006, 17:22 | #1041 | Link | |
BeHappy/MeGUI developer
try to get AAC info via fresh foobar2000 (add file to playlist and choose "properties" in popup menu)
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
26th May 2006, 18:07 | #1042 | Link | |
Mr. Woof
So I have to queue up video then audio separately in order to get an aac file in .mp4 wrapper that is functional at all. |
27th May 2006, 20:54 | #1046 | Link |
Squeeze it!
I just compiled the actual CVS 0.2.3.2155 and I did recognise a hughe bug in the provided SAR out of the script.
1.) In the Globals which are stored in the Script you did set "DAR" values, as an anamorphic keeping test of mine did result in ... global MeGUI_darx = 199 global MeGUI_dary = 100 So far in case of DAR that is almost ok. as it was almost my wanted DAR (anyway ITU was not taken into account of my DVD source but thats not the point now) 2.) Now the Problem: These 199:100 have been set as -sar parameter to x264's commandline. So as these 199:100 actually are DAR values and you can assume how stretchy the playback resulted. 3.) In the Preview Window below it says "PAR" but actually calculates to the preview resizing a "DAR" when choosing "Show PAR". Solution: Keep in MeGUI internally the calculations "PAR/SAR" based and not DAR based. By this in my case a PAR of i.E. 64/45 (here non ITU) should be inserted in my script which will also be interpretd well by x264.exe. And finally in the auto-Preview window do calc the image-preview-resize when choosing "Show par" out of a PAR and not a DAR. I did a test and applied in a script of mine where 720x576 are cropped to 640x400 (trashy original incl. hughe big le+ri borders) global MeGUI_darx = 64 global MeGUI_dary = 45 .. and everything played back fine. Last edited by Inc; 27th May 2006 at 21:07. |
27th May 2006, 22:50 | #1047 | Link | ||
27th May 2006, 23:30 | #1048 | Link |
Squeeze it!
DAR = DisplayAspectRatio = The total Image aspect ratio at final playback calculated out of width/height.
Means in case of 768/576 = GCD --> 4/3 = 1.33333p PAR = PixelAspectRatio which equals SAR. In Case of ISO/IEC 13818 Mpeg2 : Code:
height*(DAR) ISO MPEG PAR = ---------------- width So in ISO Mpeg 720x480 do result in ... 480*(4/3) = 640 --- = 8/9 (GCD) 720 And here counts the ITU (a simple way to get the PAR is as followed): Code:
TV_Mhz ------------ Playback_Mhz Code:
14,769230 (PAL TV) --------- 13.5 (Playback of 720 width's ) = 1.09402 = 128/117 Code:
14,769230 --------- = 1,641026 = 128/78 9 Last edited by Inc; 28th May 2006 at 00:03. |
28th May 2006, 14:45 | #1049 | Link | |
I'm not sure if it's a bug in meGUI, but I'm letting u guys know anyway. I encoded a mpa file to CT AAC at 48 kbps using meGUI.
When I opend it in MPC, it's properties shows its a "AAC 22050Hz Mono 48Kbps". In CoreAAC's Info Panel it says "AAC+SBR 44100Hz Stereo 93kbps!!! Both infos confused me a bit so I checked it with foobar2000. Foobar2000 showd this: Quote:
i7-2600 | GA-B75-D3V | Tempest EVO | VX450 & XMS3 16GB | SanDisk Extreme 120GB | U2311H | MK520 | MSI GTX750 Ti Gaming | CM Hyper 212+ | APC 1KVA | Xonar DG | SoundSticks III | Win 7 x64 Last edited by Avish; 28th May 2006 at 14:53. |
28th May 2006, 15:25 | #1051 | Link | |
And how could u say "Everything is fine" when MPC & CoreAAC both are showing different & wrong infos! MPC says its a Mono file, while it's a stereo. And CoreAAC says its 93kbps, while it's a 48kbps!!! Well, what I want finally is that, when I'll put it in mkv & will view it in MPC, I want it to show the correct info in its properties. That's all.
i7-2600 | GA-B75-D3V | Tempest EVO | VX450 & XMS3 16GB | SanDisk Extreme 120GB | U2311H | MK520 | MSI GTX750 Ti Gaming | CM Hyper 212+ | APC 1KVA | Xonar DG | SoundSticks III | Win 7 x64 |
28th May 2006, 15:35 | #1052 | Link |
Angel of Night
Support or lack thereof in AAC players isn't a MeGUI problem. But their only problem is in reporting, all the players you listed will decode it properly. (Technically, HE-AAC is 22khz "extended" to 44khz, and PS is mono "extended" to stereo, thus MPC's confusion. Talk to Gabest about it. Also CoreAAC is correct as well.)
If you put it in mkvmerge, read the manual and remember to signal HE! |
28th May 2006, 16:05 | #1053 | Link | |
29th May 2006, 02:51 | #1054 | Link | |
Sorry for write this so late! :P
2 upload files: http://www.easy-sharing.com (75MB/Fast) |
29th May 2006, 18:46 | #1055 | Link | |
Posts: n/a
29th May 2006, 18:47 | #1056 | Link |
Mr. Sandman
Sticked!
29th May 2006, 18:55 | #1057 | Link | |
The Internet: where men are men, women are men, and children are FBI Agents |
29th May 2006, 19:10 | #1058 | Link |
Posts: n/a
2 Carpo
Thanks.. If be I known English yet .. Because I didn't find it fast.. for all, I copied all libs, that man asked for megui. But I see simular troubles, what I saw on 22th page of this topic as soon as I begin to encode audio 2 mp4 audio with megui MeGUI.AviSynthException: Script error: there is no function named "DirectShowSource" at MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace, AviSynthScriptEnvironment env) at MeGUI.AviSynthAudioEncoder.encode() Aaaa.. exuse me.. I turned on directshow. without one all are ok... Last edited by EsTaF; 29th May 2006 at 19:22. |
30th May 2006, 21:55 | #1060 | Link |
Brazilian Anime Ripper
I did a encode in AVI / XVID container with autoencode and failed. I think the problem is with xvid_encraw, because I didn't have problem enconding by mencoder with megui 2132.
The job1-1 start and finish in 1 second. I can't start the encode with the command line below too. My guess is that xvid_encraw don't support AVS as input. Is there any way to force use mencoder instead xvid_encraw? I tried remove xvid_encraw directory but megui still try encode with xvid_encraw instead mencoder. Job completed successfully and deletion of intermediate files is activated job job1-1 has been processed. This job is linked to the next job: job1-2 Starting job job1-2 at 17:43:13 encoder commandline: -i "C:\encodes\ygh1.AVS" -pass2 "C:\encodes\ygh1.stats" -bitrate 606 -kboost 100 -overhead 0 -vhqmode 1 -closed_gop -imax 31 -max_bframes 2 -bmax 31 -threads 1 -avi "C:\encodes\Yu-Gi-Oh 178.avi" successfully started encoding Processing ended at 17:43:14 ---------------------------------------------------------------------------------------------------------- Log for job job1-2 xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 Trying to retrieve width and height from input header Couldn't open statsfile 'C:\encodes\ygh1.stats'!
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) |
