Old 5th May 2012, 12:35   #21  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
high10 profile does not generate 10 bit video file. output is still 8bit.
Old 6th May 2012, 22:58   #22  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
I was planning to add 10bit support but looks like i forgot to remove these from UI.
ozok is offline   Reply With Quote
Old 13th May 2012, 16:00   #23  |  Link
ozok
ozok's Avatar
Update:
-Added: Audio filters (resample, normalize, volume, channel)
-Added: Option to set source folder as output folder
-Added: Temp files that could not be deleted will be shown in the log
-Added: New UI layout
-Added: Support for wmv files
-Fixed: Resize method was not passed
-Fixed: NeroAACEnc quality value could not be changed
-Fixed: Some files may not be deleted
-Removed: FFMpeg as video encoder
-Removed: Skin
-Updated: MediaInfo to 0.7.57
Old 16th May 2012, 10:11   #24  |  Link
ozok
ozok's Avatar
Update:
-Fixed: A problem that prevented audio encoding in XP systems
-Fixed: "Same as source" option is saved now
-Fixed: Minimum form height was wrong
-Fixed: A few minor problems
Old 16th May 2012, 17:22   #25  |  Link
Link in 1st post dont work (https?, "Server Not Found").
EDIT:
http://"https://sourceforge.net/projects/tx264/"
try
http://sourceforge.net/projects/tx264/
PS, your link to homepage via working link above dont work, "http://tx264"
On features list on that page, Still support ffmpeg.
Old 16th May 2012, 21:45   #26  |  Link
prijatelj.v
I have no doubt that this program works well, but I can not run.Obviously something is missing.
Windows 7 (32bit) throws an error:
prijatelj.v is offline   Reply With Quote
Old 17th May 2012, 09:30   #27  |  Link
ozok
ozok's Avatar
@StainlessS thx link should work now. And also removed FFMpeg info.
@prijatelj.v is there a bugreport.txt file in the program folder? And can you click "View problem details" and post what it shows? Also some info about your PC's hardware wouldn't hurt either.
Old 17th May 2012, 19:01   #28  |  Link
prijatelj.v
If you think bugreport.txt on file in the program (TX264),does not it,or I can not find it.Details of the problem info in the picture:
besides microsoft explanation,there is a(erofflps)txt info you can look at(epicpaste)the link:
http://epicpaste.com/index.php/view/9efbd439
honestly,I'm not clear.
directories of my basic hardware you see in the following picture:
Your answer will probably be that low cpu or slightly ram-s,but I do with this configuration, a solid work with some programs,I only conversion process takes longer.Your professional response we will definitely use.No matter what,thank a lot.
Old 18th May 2012, 19:56   #29  |  Link
hdboy
I wrote a post but it seems to have disappeared so I'm rewriting.
This is a very nice program, attractive and easy to use. Maybe not for power users, but excellent for others. Thank you.
What would be cool is making the queue editable while encoding, so you can add files. What happens is I add some files, click start, then say oops, i want to add another one, but now I have to wait for it to finish. I guess you'll need two windows or integrate the encoding window into the main one somehow.
Another possible enhancement is to make the settings adjustable for each file. Different crf, container, resize option, etc. Click on each file or select multiple files, change the settings below, and it only applies to selected files. In the queue list, you can add, beside the filename a summary of major options (crf, codec, etc.) You can have an additional Settings menu: apply settings to all files, save settings as default, save settings as ... (name), load settings ... (name).
I think these will be nice to have w/o making the UI too much more complicated.
thanks.
Win 7 x64, AMD Phenom II X6 1075T, nvidia 430GT, mpc-be x86
hdboy is offline   Reply With Quote
Old 18th May 2012, 23:15   #30  |  Link
ozok
ozok's Avatar
@prijatelj.v AFAIK delphi sometimes produces binaries that have problems with AMD CPUs and again AFAIK that goes back to Delphi 3. I'll try to tweak compiling settings to overcome that problem. If you agree, I'll send you newly compiled exes.
@hdboy one of my friends complained me about that too. But thing is all the encoding parameters are generated at once for all the files in the list. So editing queue during encoding process is rather difficult for now. Maybe a different approach is the solution. If you know of any tools with that capacity, let me know so i can have a general idea.
I aimed TX264 to be a batch encoding tool but you seem to have a fair point, I'll look into that.
Old 19th May 2012, 00:38   #31  |  Link
prijatelj.v
If you think you'll be able to use the TX264,of course I agree with the proposal to send"newly compiled exes"),but it's not clear,so if you can with it and an explanation.Thank you for your interest in the solution to my problem.
Old 19th May 2012, 00:40   #32  |  Link
ozok
ozok's Avatar
@prijatelj.v I'm going to send you TX264.exe that may work.
Old 19th May 2012, 00:53   #33  |  Link
hdboy
I kinda assumed you invoke the tools separately for each file, so it's no problem doing something like
x264 --crf 18 --output "a.mp4" "a.wmv"
x264 --crf 20 --output "b.mp4" "b.wmv"
but I guess it's not that simple.
Editing the queue while encoding is a bit complicated. (Obviously, you don't allow changes to files already done or currently encoding.) Maybe you can just do the easy case of allowing adding to the queue. If user drags and drops on the encoding window, ask "add to queue y/n?" and use whatever the current settings are. But this means you can't just generate all the commands at the start. is it that much harder to generate the commands for each file once the previous file is finished?
well, something to think about
Old 19th May 2012, 01:02   #34  |  Link
ozok
ozok's Avatar
@hdboy editing options for each file separately doesn't look difficult, i think i can add that.
about editing queue during process, your post made me think and a solution can be formulated based on your suggestion, i suppose.
thanks.
Old 25th May 2012, 18:35   #35  |  Link
ozok
ozok's Avatar
Update:
-Added: Option to add files during encoding
-Added: Option to select between multiple audio tracks
-Added: File adding progress
-Added: Option to stop file adding process
-Added: Invalid files will not be added to the list
-Added: Add folder tree option
-Added: Option to play files with default player
-Fixed: 0 sec duration problem
-Fixed: A few UI problems
-Updated: x264 to rev 2200
Old 28th May 2012, 14:40   #36  |  Link
ckmox
@ozok
nice GUI, can this encode in x264 10-bit-depth?
ckmox is offline   Reply With Quote
Old 28th May 2012, 18:58   #37  |  Link
ozok
ozok's Avatar
@ckmox thx.
no, not at the moment. But you can replace 264.exe in Tools folder with 10-bit one and see what happens. Try tweaking profile, presets and tune.
Old 28th May 2012, 21:19   #38  |  Link
ozok
ozok's Avatar
Update
Update
-Added: Audio formats Mp3 (lame) and WAV (FFMpeg)
-Added: Options to copy audio or disable audio encoding
-Added: Progress for Mp4Box and mkvmerge
-Added: Process summary and progress list
-Fixed: FFMpeg audio decoding progress was not shown
-Fixed: Adding folder could not be stopped
-Updated: FFMpeg to N-41074-g9c27f29
Old 12th June 2012, 22:39   #39  |  Link
ozok
ozok's Avatar
Update
Update:
-Added: 64 bit versions of x264, ffmpeg, oggenc and lame
-Added: Post-encode actions
-Added: Time passed/left
-Added: Support for files with no audio tracks
-Fixed: Audio channel problems (ffmpeg instead of sox)
-Fixed: Avs files could not be added
-Fixed: Files could be drag&dropped during encoding
-Updated: FFmpeg to N-41416-g718607b
-Updated: MediaInfo.dll to 0.7.58
Old 14th June 2012, 15:34   #40  |  Link
Mr. Monte
Clicking on link on page one errors out..does not goto download page
Mr. Monte is offline   Reply With Quote
faac, mkv, mp4, neroaacenc, x264
