Old 3rd February 2007, 03:39   #81  |  Link
Eretria-chan
Well, seeing as it stores files in the temp folder and it's regularly cleaned, there's nothing there now, so I'll do a new encode tomorrow and see what the results are.
Eretria-chan is offline   Reply With Quote
Old 3rd February 2007, 03:41   #82  |  Link
Sirber
retired developer
Sirber's Avatar
try another output folder. Are you running on vista again?
Detritus Software
Sirber is offline   Reply With Quote
Old 3rd February 2007, 14:00   #83  |  Link
Eretria-chan
Nope, regular XP Prof.
"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 29.970 -new "F:\Downloads\Temp\[#YuGiOh!]Yu-Gi-Oh!_-_001_-_The_Bloodcurdling_Blue-Eyes_White_Dragon(3696EC70).mp4 " -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4"
Cannot open destination file F:\Downloads\Temp\[#YuGiOh!]Yu-Gi-Oh!_-_001_-_The_Bloodcurdling_Blue-Eyes_White_Dragon(3696EC70).mp4: I/O Error
"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "F:\Downloads\Temp\SonicX 01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4"
Cannot open destination file F:\Downloads\Temp\SonicX 01.mp4: I/O Error
Old 4th February 2007, 06:40   #84  |  Link
Sirber
retired developer
Sirber's Avatar
something's wrong.
try other folder or shorther filenames.
Detritus Software
Old 4th February 2007, 21:29   #85  |  Link
Eretria-chan
It doesn't matter where I put it. The same thing happens.
"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "F:\SonicX 01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4"
Cannot open destination file F:\SonicX 01.mp4: I/O Error
Old 4th February 2007, 22:37   #86  |  Link
Sirber
retired developer
Sirber's Avatar
how about not using F:?
Detritus Software
Old 5th February 2007, 14:44   #87  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
try also removing the space in the output filename
Old 5th February 2007, 15:59   #88  |  Link
Sirber
retired developer
Sirber's Avatar
writing to C: works, but it seems that using F: doesn't work so well.
Detritus Software
Old 5th February 2007, 16:41   #89  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
uhm, write permissions?
Old 5th February 2007, 19:28   #90  |  Link
Eretria-chan
Does not work:
C:\Documents and Settings\Shizuka>"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "C:\test\SonicX 01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4"
Cannot open destination file C:\test\SonicX 01.mp4: I/O Error
C:\Documents and Settings\Shizuka>"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "C:\test\SonicX01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4"
Cannot open destination file C:\test\SonicX01.mp4: I/O Error
Does work:
C:\Documents and Settings\Shizuka>"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "C:\SonicX01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4"
C:\Documents and Settings\Shizuka>"C:\x86 Apps\Bencos\MP4Box.exe" -add C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/video.264 -fps 23.976 -new "C:\SonicX 01.mp4" -add "C:\DOCUME~1\Shizuka\LOKALA~1\Temp/bencos/audio.mp4"
Now that's just stupid. I don't want to output to C:\. C:\ is write protected anyway. File permissions are correct (using NTFS).
Old 5th February 2007, 19:31   #91  |  Link
Sirber
retired developer
Sirber's Avatar
Seems to be a file permission problem. Nothing we can fix on our side
Detritus Software
Old 5th February 2007, 21:34   #92  |  Link
Eretria-chan
File permissions? There's nothing wrong on my side. It's the software that screws up.
I can, for example, merge with mkvmerge to F:\Downloads\Temp. Bencos cannot, so it's on your side...
Old 5th February 2007, 21:37   #93  |  Link
Sirber
retired developer
Sirber's Avatar
Bencos only launch mp4box, and mp4box fails on your system. File a bug report to gpac team, since it has issues only for you on your machine. Nothing we can do.
Detritus Software
Old 5th February 2007, 21:45   #94  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
as sirber said the error comes from mp4box, so it has nothing to do with bencos code.
theres no way we cant fix it.
Old 5th February 2007, 21:54   #95  |  Link
Eretria-chan
Mp4box, huh?
OK, so I have no idea where to report that error, but maybe you do?
Oh and, I think I need to know what version you're using also? It might help. Maybe.
Old 5th February 2007, 21:57   #96  |  Link
Sirber
retired developer
Sirber's Avatar
http://gpac.sourceforge.net/home_support.php
Google is your friend
Detritus Software
Old 6th February 2007, 01:33   #97  |  Link
Sirber
retired developer
Sirber's Avatar
posted a new version
http://www.detritus.qc.ca/forum/view...php?pid=11#p11
MKV output on it's way.
Detritus Software
Old 6th February 2007, 22:22   #98  |  Link
Sirber
retired developer
Sirber's Avatar
new version again. Celtic Druid made some discoveries on drop duplicate frames.
So, I posted a new build reflecting this new approach. Please test and feedback!
Detritus Software
Old 7th February 2007, 14:54   #99  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Just a warning. The Debug profile is very fast but has a VERY LOW quality.
Dont use it unless for debugging...
Old 7th February 2007, 14:57   #100  |  Link
Sirber
retired developer
Sirber's Avatar
I think I'll put it down the list, so we can put it and remove if whitout too much code change.
On my todo list:
* Add MPEG4 ASP
* Add AAC HE
* Add AAC LC
* Add MP3
* Add AVI, if MP3 is selected
Detritus Software
aac, bencos, gui, webm, x264
