Old 8th August 2011, 08:56   #281  |  Link
videoFred
videoFred's Avatar
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
Originally Posted by Fizick View Post
Well, i am totally out of avisynth world now.
I'm sorry to hear this... why?
So, source Depan code is released today. But it was my first plugin, and probably the worst code ever written
Well, it's the best stabilizer for Avisynth and I got it perfect working now! After many tests, I have found that correct levels for the base clip are very important. So I'm feeding DePanEstimate with a special tweaked clip. I'm using colorUYV(autogain=true) for this. ColorYUV(autogain=true) is often wrong, but it works very good for DePanEstimate().
The trust parameter is very important too. It sets the scene change detection.
I have tested this on many different clips and the result is almost always 100%, with trust=1.5.
I will upload my new stabilizing script here today.
Fred.
About 8mm film:
http://www.super-8.be
Film Transfer Tutorial and example clips:
https://www.youtube.com/watch?v=W4QBsWXKuV8
More Example clips:
http://www.vimeo.com/user678523/videos/sort:newest
videoFred is offline   Reply With Quote
Old 9th August 2011, 23:38   #282  |  Link
fluor
I just discovered this fantastic plugin and it does wonders for my digital camera movies! by just cropping 20 pixels around I get a much more stable picture on many of my movies!
I use the following for some of my canon camera movies
loadplugin("C:\Util\canon2mkv\ffms2.dll")
FFVideoSource("c:\full-path\MVI_9766.avi")
loadplugin("C:\Util\canon2mkv\hqdn3d.dll")
loadplugin("C:\Util\canon2mkv\DePan.dll")
loadplugin("C:\Util\canon2mkv\DePanEstimate.dll")
i = ConvertToYV12()
mdata = DePanEstimate(i)
DePanStabilize(i, data=mdata,method=0,dxmax=20,dymax=20,rotmax=0)
crop(20,20,-20,-20)
hqdn3d()
-- fluor
fluor is offline   Reply With Quote
Old 30th October 2011, 18:18   #283  |  Link
SSH4
Hmm, i don't undestand why, but blur in DePanStabilize 1.101 not work for me.
Made it any size from 10 to 150 and don't see any difference
vectors = MSuper().MAnalyse(isb = false,blksize=8, overlap=4,search=5)
globalmotion = MDepan(vectors, pixaspect=0.911, thSCD1=500)
DepanStabilize(data=globalmotion, cutoff=0.5, mirror=15,rotmax=5,prev=0,next=0,blur=50, pixaspect=0.911,subpixel=2,method=1)
SSH4 is offline   Reply With Quote
Old 10th December 2011, 18:26   #284  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
SSH4,
sorry. Blur is not implemented for rotation in current version 1.10.1.
Try MDepan (..., rot=false)
Also I discovered, that blur was accidentally not implemented at left side for subpixel=1.
Old 23rd January 2023, 03:41   #285  |  Link
Hat3L0v3
Hat3L0v3's Avatar
Can somebody help me to figure out why depan filter crashing my Avs(AvsPmod)?
I want to use DePanStabilize from mvtools pack but it crashes.
system and others:
win10 x64
avs+ 3.7.3 r3825 x86-64
AvsPmod_v2.7.3.2_.Windows_x86-64
mvtools-2.7.45 (.dll`s x64)
vcredist last time installed from here (v0.64.0) (can't remember what versions I had before)
(libfftw3f-3.dll and libfftw3l-3.dll) from FFTW - 3.3.10
x64.dll into System32 folder (x32.dll on SysWoW64)
I remember before updating avs+ from 3.7.2 to r3825 I tried different stabilizers and depan was causing "access violation" error (same as TemporalDegrain2 with postFFT=2 option). Now they both just crashing without errors.
Hat3L0v3 is offline   Reply With Quote
Old 23rd January 2023, 03:56   #286  |  Link
libfftw3f-3.dll, but not libfftw3l,-3.dll
also can copy renamed libfftw3f-3.dll to system32/fftw3.dll
Some filters like one name, some the other, and some will accept either.
Failing that, post script.
Old 23rd January 2023, 04:01   #287  |  Link
kedautinh12
Change name x64 libfftw3f-3.dll to fftw3.dll and copy to system32. Don't need rename libfftw3f-3.dll already in system32. I had both libfftw3f-3.dll and fftw3.dll in system32, don't have error with both already in system32
Old 23rd January 2023, 04:07   #288  |  Link
Well, result is same thing. [provided those in system32 are same version as new ones]
Old 23rd January 2023, 11:10   #289  |  Link
Hat3L0v3
Hat3L0v3's Avatar
So I need just single libfftw3f-3.dll in my system32 folder if I using x64 version avs/avsp? I deleted all other .dll`s - still crashing.
Old 23rd January 2023, 11:12   #290  |  Link
kedautinh12
You need both libfftw3f-3.dll and fftw3.dll in system32 too. And fftw3.dll same with libfftw3f-3.dll (change name libfftw3f-3.dll to fftw3.dll)
Old 23rd January 2023, 11:32   #291  |  Link
kedautinh12
If still errors, you can check with dependencies, drag mvtools.dll, fft3dfilter.dll, neo-fft3d.dll to this app to check error
https://github.com/lucasg/Dependencies/releases
Old 23rd January 2023, 12:10   #292  |  Link
Hat3L0v3
Hat3L0v3's Avatar
after I drag it to app I don't really undestand where to look for errors. Like this one? the only red I found.
Old 23rd January 2023, 12:28   #293  |  Link
kedautinh12
Yes, you missing this .dll. You need download this x64 ver .dll and copy to system32
Old 23rd January 2023, 12:35   #294  |  Link
kedautinh12
My mistake. You need check depan.dll and depanestimate.dll too
Old 23rd January 2023, 12:46   #295  |  Link
Hat3L0v3
Hat3L0v3's Avatar
I have list of this .dll`s missings. Don't really know how it can helps and where to fix them (if it needed)
Old 23rd January 2023, 12:57   #296  |  Link
kedautinh12
You can search .dll missing and download here
https://www.solvusoft.com/en/files/m...und-error/dll/
Old 23rd January 2023, 13:14   #297  |  Link
Hat3L0v3
Hat3L0v3's Avatar
this site not work properly.
I open other .dll that works for test it have same .dll missing but it works fine. so maybe not all of them I need to repair.
Old 23rd January 2023, 13:45   #298  |  Link
kedautinh12
Ok, i use this fftw3.3.10 and didn't had error (you can copy all x64 .dll to system32)
https://drive.google.com/file/d/1PF9...w?usp=drivesdk
If error still exist, try search: add or remove program -> unistall all vc++ version and install abbodi1406's vc++ again
Old 23rd January 2023, 15:56   #299  |  Link
Selur
Selur's Avatar
Just as a side note:
Instead of copying fftw dlls into the system folder you could also load it inside the Avisynth script using LoadDLL.
Here's an example:
# LoadPlugin("I:\Hybrid\64bit\Avisynth\avisynthPlugins\LoadDll.dll") # only needed when auto-loading is disabled.
LoadDLL("I:\Hybrid\64bit\Avisynth\avisynthPlugins\fftw\libfftw3f-3.dll")
(Hybrid uses this for ages. Hybrid disables the auto-loading and loads everything explicitly for more control over what is used.)
Cu
Selur
Old 23rd January 2023, 20:35   #300  |  Link
Found this on TechNet
https://social.technet.microsoft.com...nServerPreview
Question
Sign in to vote
0
Sign in to vote
Thank you for the pointer to the VC++ 2015-2019 v14.23.27820.0 runtime files that will start and run on Win 10 v1903. Obviously these have been compiled with different dependencies than the VC++ 2015-2019 v14.21.27702.2 runtime files that I have had since v1803 of Win 10.
Although, installing these 2015-2019 C++ runtimes has not solved the issue.
I have read elsewhere on this forum:
"You are not missing those DLLs.
Those DLLs are Windows's implementation detail and are subject to change at anytime. Basically Microsoft started moving around APIs starting from Windows 8. For example, APIs in Windows 8's api-ms-win-core-file-l1-2-0.dll got moved to api-ms-win-core-file-l1-2-1.dll in Windows 8.1. Old software still work because the dlls developer linked to are now just placeholders redirecting calls to the actual implementation. But nobody should link to the implementations directly, as that would be defeating the purpose of having such a redirection. Any software that report those dlls are missing are failing to accommodate the redirection (e.g. reporting a delay-loaded dependency as hard one)."
that v1903 has replaced the direct calls to all of those DLLs with a handful of stub DLLs that now must be called to be redirected to the corresponding function provided by the original DLLs.
In my opinion, it was very rude of Microsoft to make this change to v1903, with no workaround, as it ruins several years of programs that were created using VC++.
Including Microsoft's own VC++ runtime installation files which were obviously recompiled with new dependencies to now function correctly on v1903.
If anyone knows of a workaround other than regression to v1803 of Win 10, please reply.
Thank you in advance.
Looks like M$ ****'ed it up a bit.
Those error messages you have [missing dll's], might be bogus.
Near end of that technet thread, seems that something you downloaded, might not have been installed correctly (maybe the AIO runtimes updater),
due to M$ preventing it from running properly because it was downloaded from an 'unknown' computer. (ie internet).
Also [YOU MUST] see here:- https://forum.doom9.org/showthread.p...09#post1872609
EDIT: to do with this stuff [see above D9 link]:
EDIT: Added a Regedit fix for 'unknown' computer file blocking thing at above D9 link.
There is also a GpEdit.msc fix at above link (Windows Pro only).
Suggest [YOU MUST] get the NirSoft AlternateStreamsViewer mentioned at above link. and search for blocked files over your whole system
(I had hundreds of files blocked without knowing, when I first discovered problem).
