Old 11th March 2009, 14:13   #1121  |  Link
~bT~
н∂-ƒαиαтι¢
^ move anywhere forward, then move backward frame by frame.
~bT~ is offline
Old 11th March 2009, 14:15   #1122  |  Link
In what, DGAVCIndexNV or playing the script? If the latter, post the script.
Guest is offline
Old 11th March 2009, 14:21   #1123  |  Link
~bT~
н∂-ƒαиαтι¢
in dgavcindexnv
~bT~ is offline
Old 11th March 2009, 14:25   #1124  |  Link
The SPS/PPSs in the stream are not suitable for seeking. This is like another case I saw. It's OK on the bluray because the bluray navigation system controls the seek points.
Lucky for you, this won't happen in the video served through DGAVCDecodeNV, because at that point the SPS/PPSs are indexed and known.
I probably won't do anything about this.
Guest is offline
Old 11th March 2009, 14:35   #1125  |  Link
~bT~
н∂-ƒαиαтι¢
^ no probs. cheers for taking a look at it tho.
~bT~ is offline
Old 11th March 2009, 20:44   #1126  |  Link
ultratoto14
Hi neuron2, as it has been discussed here several times, is there any progression in a cuda resizer in DGAVCDecodeNV ?
Thanks for your work, each time i use DGAVCDecodeNV, VC1 version or MPG, I appreciate the quality of the sources.
ultratoto14 is offline
Old 11th March 2009, 21:21   #1127  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
About that CUDA resizer, with Arcsoft TotalMedia Theatre you can resize to 1080p while playback. Would be a great feature for DGMPGIndexNV (resize DVDs to 1080p with better quality). Here's a comparison.
Deinorius is offline
Old 11th March 2009, 22:17   #1128  |  Link
deets
ive just ordered myself a cheap ATI 4870 and i just realised this means the end of my use! im quite gutted, ive been using the nvidia deinterlacing option a lot on my itv hd conversions
any chance of an ati version anytime soon?
deets is offline
Old 12th March 2009, 03:15   #1129  |  Link
Zero. Zip. Nada.
Guest is offline
Old 12th March 2009, 03:27   #1130  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
that reminds me....
is the combining of the DG*DecNV tools into an all-in-one filter still in the plans for the future?
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline
Old 12th March 2009, 04:50   #1131  |  Link
onesloth
Can the NV tools not be used with an Nvidia card that isn't the primary display adapter? i.e. installed in a second PCI-E slot with an ATI card as the primary display adapter.
onesloth is offline
Old 12th March 2009, 06:18   #1132  |  Link
Combining is still planned.
I don't know about the secondary adapter idea. I doubt it, though.
Guest is offline
Old 12th March 2009, 10:29   #1133  |  Link
deets
well i cancelled the order, this was a contributing factor i do a lot of encoding and hardware deinterlacing speeds things up considerably. 260 it is then, seems to be getting slightly better benchmarks in dx10 games anyway.
deets is offline
Old 13th March 2009, 08:49   #1134  |  Link
Clumpco
Clumpco's Avatar
Originally Posted by Clumpco View Post
Link fixed, apologies.
Also so far with 1.0.13/1.0.4 I have BSOD (IRQ_NOT_LESS...) or just hanging during the x264 second pass.
I have rolled back to 1.0.11/1.0.3 to see if it is any better.
If not, then I'll have to start running memtest etc.
UPDATE - Encoded fine with 1.0.11/1.0.3
I tmight have encoded fine... but since then I have had BSOD with xvid (not a CUDA in sight). This time it would appear that it was a seized fan on the hard drive bay that just happened to coincide with driver/DGAVCIndexNV update.
Before I get classed as a total time-waster please point me in the direction of the nearest self-flagellation club.
ME
Clumpco is offline
Old 13th March 2009, 13:51   #1135  |  Link
Don't beat yourself up about it. Anyone would have thought the same thing. Thanks for notifying me before I invested a lot of encoding time. I hope you get your HW sorted so you can continue providing useful feedback.
Guest is offline
Old 13th March 2009, 20:02   #1136  |  Link
harissa
i got this msg many times cuvidMapVideoFrame() error
while i m using Megui
always in a diffrent moment during the encoding
harissa is offline
Old 13th March 2009, 21:27   #1137  |  Link
I can't help you without a lot more information than that.
What graphics card? How much memory on it? What Nvidia driver version? Using the correct nvcuvid.dll? What OS? Does it happen for all source streams? Your script? Your x264 command lines?
Guest is offline
Old 13th March 2009, 21:55   #1138  |  Link
harissa
windows xp sp3
nvidia gforce 8400GS
driver vr 6.14.11.8208
loadplugin("DGAVCDecodeNV.dll")
avcsource("000000.dga")
loadplugin("Decomb.dll")
decimate(5)
LanczosResize(1280,720,0,0.75)
it happend in megui , in the first pass or second pass , never at the same time , with the same movie
sometime it never happend ,
i encoded the same movie like 10 time to check
sometimes it happend when i m not even usin the pc at 4 am
when this happend cuvidMapVideoFrame() error
encodin stop/abort and CUVIDServer.exe has to be closed and restared
harissa is offline
Old 13th March 2009, 22:19   #1139  |  Link
How much memory on your graphics card?
Upgrade to the latest Nvidia drivers and try again.
Guest is offline
Old 14th March 2009, 01:10   #1140  |  Link
harissa
it s 512 meg , and it sthe lastest driver on nvidia website
harissa is offline
