Old 8th September 2008, 14:34   #6141  |  Link
sehgal.v7
Again, you are sounding tough// c'mon bro, if were in ma city, would have take you to for the drink.. Chill!!
Everything thing has a way of explaining..
sehgal.v7 is offline
Old 8th September 2008, 14:38   #6142  |  Link
McFlipp
Originally Posted by xkodi View Post
madshi, how i can use the AGM write support, doing:
eac3to input_file output.agm
gives me
Works fine here:
eac3to v2.62
command line: eac3to  E:\truehd.flac D:\audio.agm
FLAC, 5.1 channels, 2:32:39, 24 bits, 7620kbps, 96khz
Decoding FLAC...
Writing Agm...
Creating file "audio.agm"...
This audio track has a constant bit depth of 24 bits.
eac3to processing took 9 minutes, 36 seconds.
Done.
edit: Disregard this post... I was being a blind fool....
McFlipp is offline
Old 8th September 2008, 14:41   #6143  |  Link
xkodi
thank you, McFlipp!
works fine here too:
http://forum.doom9.org/showthread.ph...93#post1180993
xkodi is offline
Old 8th September 2008, 16:00   #6144  |  Link
madshi
Originally Posted by sehgal.v7 View Post
Why you guys heating up so much??
I jus asked// if you knew, you shared.. thn wht's being arrogant of this??
We're not heating up. We're just pointing out that some of the questions you're asking don't belong here while others were not really necessary at all (a simple google/wikipedia check would have answered them). You seem to take it for granted that you get good replies to all funny questions for free. Ever thought of that maybe I have a job? And that every minute I spend on answering questions here means that I give up money which I could have earned otherwise in my job? Please limit your questions to those which belong here and which haven't been asked before and where wikipedia and google don't help you. That would show respect to the worth of my time. Thanks.
madshi is offline
Old 8th September 2008, 16:03   #6145  |  Link
sehgal.v7
@Madshi
I'm sowwie for my neglection bro// I apologise!!
Regards,
Sehgal.
Old 8th September 2008, 16:10   #6146  |  Link
Encoder888
Encoder888's Avatar
@madshi
I have trouble demuxing the MPEG-2 stream from VOB files. Here's what I get:
eac3to v2.62
command line: D:\eac3to\eac3to.exe vts_02_1.vob+vts_02_2.vob 2: Video.mkv
VOB, 1 video track, 4 audio tracks, 5 subtitle tracks, 0:43:15
1: Joined VOB file
2: MPEG2, 480p24 /1.001 (16:9) with pulldown flags
3: AC3, 5.1 channels, 384kbps, 48khz, dialnorm: -25dB
4: AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -25dB
5: AC3, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB
6: AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
7: Subtitle
8: Subtitle
9: Subtitle
10: Subtitle
11: Subtitle
[v02] This doesn't seem to be a valid MPEG2 stream.
Aborted at file position 1713938432.
I tried it with an earlier version of eac3to (I think it was 2.51) and it worked fine. Please, fix it if possible
Encoder888 is offline
Old 8th September 2008, 16:33   #6147  |  Link
piratburner
It's should be a DREAM if this fantastic SW could make a m2ts output :-) :-) :-)
Then it would be the ultimate SW, Just think ..... take the movie stream, and a sound, subtitle you like from the BD source and output a new m2ts file ..... but I'm perhaps only dreaming ;-) but it's nice to dream :-)
piratburner is offline
Old 8th September 2008, 17:20   #6148  |  Link
Inventive Software
Turkey Machine
Keep dreaming. That's the job of the authoring tools, like TSRemux and TSmuxer.
@madshi: HDCD decoding is PERFECT! The 2 HDCDs I have ripped to FLAC and re-encoded to FLAC via eac3to sound different, so I'm assuming the decoder's more or less perfect. Thank you.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 8th September 2008, 18:08   #6149  |  Link
madshi
eac3to v2.62
1: Joined VOB file
7: Subtitle
8: Subtitle
9: Subtitle
10: Subtitle
11: Subtitle
Hmmmm... That is extremely strange. The code which outputs this MPEG2 error message is meant to run at the beginning of a file, but I see that the processing aborted at 1.7GB, which is WAY after the beginning of the file. How big are the two vob files?
I hope the decoded files sound better, not just different? Unfortunately I don't have any way to check whether the decoder is working correctly or not. But I assume it does.
madshi is offline
Old 8th September 2008, 18:40   #6150  |  Link
xkodi
i was thinking about the same - Windows Media Player has build-in HDCD decoder, because Microsoft acquired HDCD company in 2000. so, WMP decoder can be used for reference. the problem is how to make bit-perfect capture of the WMP decoder output (AFAIK, it is not DirectShow filter)?
xkodi is offline
Old 8th September 2008, 18:54   #6151  |  Link
Encoder888
Encoder888's Avatar
@madshi
It's a LOST episode, the two files are 1GB+0.7GB so it must have aborted at the end. It didn't even start demuxing, the line just ran across very fast and I got the error message. I've gotten the same error with about 3/4ths of whatever other movies I've tried, so I don't think it depends on the number or size of VOBs. I just use an older version of eac3to for those, I cant tell you for sure in which version the problem started, but 2.51 works fine.
Old 8th September 2008, 20:34   #6152  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
I just made an attempt at using a TrueHD track on a HDDVD-->Blu-ray conversion using eac3to input.thd output.thd+ac3, and the end result was a choppy AC3 track, however I did use a DTS track in there as well and it played fine, as did the video. I used vc1conv for the video and tsMuxeR for BD muxing.
Does this command work for HDDVD-->BD conversions?
odin24 is offline
Old 8th September 2008, 21:29   #6153  |  Link
yonta
eac3to v2.62 crashes on this dtswav file.
sample
Tried v2.52 and it works just fine.
yonta is offline
Old 8th September 2008, 22:01   #6154  |  Link
nautilus7
nautilus7's Avatar
2.60 also works. Crash report says something about HD CD decoder. I believe DTS/AC3-WAV support is broken due to HD CD support.
nautilus7 is offline
Old 9th September 2008, 00:37   #6155  |  Link
JustABDFan
1) I noticed that the libFLAC.dll that comes with Eac3to is 151,552 bytes and is dated 7/22/2007 while the one that comes in MadFLAC is 258,048 bytes and is dated 10/7/2007. I wanted to put Eac3to and Madflac into one "tools" folder so which I should use OR do I just make a folder for each and keep em separate?
2) Any chance of Eac3to using arcsoft decoders for (E)AC3 instead of Nero 7? Nero 7 Ultra isn't being sold by Ahead anymore and I don't want to risk buying the Blu-ray plugin to use with an OEM version then it not work properly.
JustABDFan is offline
Old 9th September 2008, 07:24   #6156  |  Link
hdpete
Is there anyway I can remux a blu-ray keeping the TrueHD track to fit on a BD25 for playback via a surround amp connected using HDMI. I know from a couple of costly BD-R's that tsMuxer won't allow the remux of TrueHD. I see that the latest version of eac3to can extract TrueHD as is, but how do I get it onto a blu-ray as I can't use tsMuxer?
I want to keep lossless audio, is the only way to use eac3to to convert the TrueHD to PCM 5.1?
Thanks
hdpete is offline
Old 9th September 2008, 07:51   #6157  |  Link
Beastie Boy
Beastie Boy's Avatar
@hdpete, I have written a post in the tsMuxeR thread that may help you. Please keep tsMuxeR questions there.
Cheers, Beastie.
Beastie Boy is offline
Old 9th September 2008, 13:26   #6158  |  Link
tebasuna51
tebasuna51's Avatar
Thanks madshi for your new version, for me the standard dts is all ok decoded but:
2/2.1 - ArcSoft output is FL FR FC Empty LF BL, the BR channel is missing and need remap -0,1,3,4,2,5
And using -dtslog with Samples_dts-es encoded with DTS PRO SERIES SURROUND ENCODER (thanks Elektra999) seems there are a detect problem:
                     3/3.0 m   3/3.1 m   3/3.0 d    3/3.1 d
+ DTS-Core           -------   -------   -------    -------
  - frameSize        2013      2013      2013       2013
  - DTS-ES           +         +         +          +
  - channelNo        5         5         5   (?)    6
  - lfe              0         1         0          1
  - channelDescr     5.0       5.1       5.0 (?)    6.1
  - samplingRate     48000     48000     48000      48000
  - bitDepth         16        16        16         16
  - bitrate          1536000   1536000   1536000    1536000
  - extAudio         -         -         XCh        XCh
  - samplesPerFrame  512       512       512        512
  - copyHistory      1         1         1          1
With libav
3/3.1 DTS-ES 6.1 Discrete, output 5.1 with BC mixed in BL-BR, ok but need remap -1,2,0,5,3,4
And ArcSoft problems:
3/3.0 DTS-ES 6.0 Discrete, detected like 5.0 and decoded 5.0 with BC channel mixed in BL-BR like 6.0 Matrix.
3/3.1 DTS-ES 6.1 Discrete, all ok but FL and FR channels broken (missing 99% of samples)
tebasuna51 is offline
Old 9th September 2008, 19:04   #6159  |  Link
piratburner
Just a Q
What exactly can I expect when doing this command
eac3to BDMV k:\output.mkv ?
a complete mkv with all sound,subs ? or ?
Old 9th September 2008, 21:00   #6160  |  Link
hdpete
TrueHD to LPCM
If use eac3to "D:\input.thd+ac3" "D:\output.wav" -nero -24, will the resulting wav file have all the lossless date of the trueHD source?
Thanks for your advice
hdpete is offline
eac3to
