Old 9th July 2004, 07:50   #41  |  Link
eb
Thank you Moitah for nice tool, working good with 3ivx .avi and VLCplayer is reacting nicely for the changes done by Mpeg4Modifier.
Very interesting experiments can be carried out with anamorphic 2.35:1 pictures that are encoded with 3ivx with pixel matrix 720x576 and latter modified to 2.35:1 by Mpeg4Modifier.
eb
eb is offline   Reply With Quote
Old 9th July 2004, 12:55   #42  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Have you been cropping 2.35:1 images and encoding them using 720x480/576 pixels. And then MPEG4Modifier to correct the DAR back to 2.35:1?
If so it's quite nifty feature. And such is the power of DAR over PAR. But you can do it with XviD and DivX too!
Cheers
Old 9th July 2004, 14:16   #43  |  Link
eb
Yes, exactly croping then resizing to 720x576 and Mpeg4Modifier back to 2.35:1. All this tests are done on sattv records.
I see that you have SS2 card /my advice to you HotBird 13, 10911V, MCE radio, you can record simultaniously 10 (ten) MCE channels and every song or piece of music is recorded separately - it is only pity that MCE webpages with song titles and albums are not more working/.
Gretings
eb
Old 9th July 2004, 14:51   #44  |  Link
Zhnujm
Zhnujm's Avatar
Originally posted by Moitah
.... Also I plan to allow the field order flag to be modified for interlaced encodes.
That would be really useful as xvid does not offer such option during encoding.
Zhnujm is offline   Reply With Quote
Old 9th July 2004, 15:19   #45  |  Link
SeeMoreDigital
@SeeMoreDigital: I'm not really interested in messing with MPEG 1/2.
Oh well... Just a thought!
I would like to do some stats in the next version, including B-VOP/QPel/GMC information (yes, I believe I will be able to determine the number of warp points).
Great news!
This would be clever!
Have you got something up your sleeve that can half the frame rate (ie: throw out the duplicate frames) from 60fps 720p encodes?
Cheers
Old 9th July 2004, 16:23   #46  |  Link
Moitah
Nope, can't throw away frames since they are predicted from eachother. Why would a 60fps 720p encode have duplicate frames? Maybe if all the dupes were N-VOPs, but I don't think this would be reliable.
moitah.net
Moitah is offline   Reply With Quote
Old 10th July 2004, 20:23   #47  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
Re: MPEG4Modifier v1.1.0 Released (Updated 2004-Jun-24)
[*]Warns if the AVI is OpenDML
I got an opendml avi because my avi is over 2gb(backing up to dvd), can I split the file in half, modify the aspect ratio in both files and join the back together and have it work? or do I need to do something else?
10,000 Bullets
10,000 Bullets Forums
Exploring the world of Cinema from the Arthouse to the Grindhouse™
SiXXGuNNZ is offline   Reply With Quote
Old 11th July 2004, 00:11   #48  |  Link
Moitah
Re: Re: MPEG4Modifier v1.1.0 Released (Updated 2004-Jun-24)
I haven't tried this, but I think it will work fine.
moitah.net
Old 11th July 2004, 03:15   #49  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
Re: Re: Re: MPEG4Modifier v1.1.0 Released (Updated 2004-Jun-24)
yep, it works just fine, so that is good news
10,000 Bullets
Old 27th August 2004, 10:18   #50  |  Link
SeeMoreDigital
Hi Moitah,
Hey there best friend, buddy, Pal, demi-god....
Would it be possible to make a version of this tool that can support different containers... such as MKV and (my personal favourite) .MP4?
Just curious!
Old 1st September 2004, 13:08   #51  |  Link
Tanshu
Moitah, this is an excellent tools. Works wonders as far as changing the UserData of old XviD encodes is concerned (I had a few old ones which borked in the new decoder).
It may sound noobish, but I cannot get the AR changing to take place. I am using MPC and Koepi's Xvid 1.0.1 filter. It seems as though it ignores the AR set in the AVI file. I prefer using the XviD decoder, so is it possible or is it only possible with FFDShow?
And again. Thanks a lot for this gr8 tool and keep up the good work.
Tanshu is offline   Reply With Quote
Old 1st September 2004, 13:14   #52  |  Link
SeeMoreDigital
Unfortunately Koepi's 1.0.1 DSdec filter does not decode and display anamorphic streams. So that's why MPC does not work yet!
I've tried a pre-release of version of Koepi's 1.1.x DSdec filter and it works very well indeed....
So hang on in there a bit longer!
Cheers
Old 1st September 2004, 13:35   #53  |  Link
Tanshu
Didn't know about Koepi's 1.1.x .... and cannot wait for it now...
Thanx a lot for the info.
Old 1st September 2004, 13:55   #54  |  Link
SeeMoreDigital
My pleasure!
In the meantime, if you have the new version of Nero Vision Express installed, you could view your anamorphic encodes in their ShowTime player!
Cheers
Old 1st September 2004, 15:49   #55  |  Link
Tanshu
I have Nero installed, but I love MPC a bit too much and haven't been able to use anything since I first got hold of it. (Hope Gabest keeps up the updates, the good news is that he commited a few changes just a few days back. )
Old 1st September 2004, 18:02   #56  |  Link
bond
hm, doesnt the anamorphic resize in their filters work in any dshow based player, like mpc?
Ogg Theora | Ogg Vorbis
Old 1st September 2004, 18:11   #57  |  Link
SeeMoreDigital
Yes, Nero's new filters will (should) work now in all direct-show based players
That said users must either un-install, de-register or lower the priority of their any other Mpeg4 DSdec filters they may have installed, before Nero's kick in.
Or they could change the 4cc code of their entire collection of Mpeg4 .avi's
Jeez, I don't know which option I should do myself now
Have you got your PC/living situation sorted out now?
Cheers
Old 1st September 2004, 18:28   #58  |  Link
bond
or they could use .mp4
Old 1st September 2004, 18:58   #59  |  Link
SeeMoreDigital
Ain't that the truth!
Cheers
Old 14th September 2004, 16:16   #60  |  Link
Moitah
Version 1.2.0 released, first post has been updated.
moitah.net
