Old 31st July 2009, 02:20   #9161  |  Link
leeperry
Kid for Today
righty, I'll do my homework and come back w/ a proper sample...maybe ffdshow's mixer is playing tricks on me after all
I use my own stereo downmix Logic7 matrix, and this one works fine on all movies...except FLAC'ed DTS-HD
leeperry is offline
Old 31st July 2009, 12:14   #9162  |  Link
Revgen
Originally Posted by xkodi View Post
1) TMT2 installs dtsdecoderdll.dll version 1.1.0.0
2) TMT3 installs dtsdecoderdll.dll version 1.1.0.1
3) TMT 3.0.1.133 Patch installs dtsdecoderdll.dll version 1.1.0.5
http://www.arcsoft.com/downloads/dig...update_all.exe
you need to have installation of TMT2 on which eac3to recognize the dtsdecoderdll.dll, i.e. "eac3to -test" returns:
then just replace dtsdecoderdll.dll version 1.1.0.0 with version 1.1.0.1 or version 1.1.0.5 from TMT3 and then when you run "eac3to -test" you should get:
or
4) TMT 3.5 installs dtsdecoderdll.dll version 1.1.0.10, but it doesn't work with eac3to.
BTW, there is also new CinemasterAudio.DLL version 4.3.0.236 from the new version 2.6.3 of SONIC CineVision, which works good with eac3to. if you look here:
http://forum.doom9.org/showthread.ph...14#post1158014
and here:
http://forum.doom9.org/showthread.ph...81#post1212881
you will see that this is the first new version of CinemasterAudio.DLL from very long time that works good with eac3to
I'm having no luck getting arcsoft to work either. Am I screwed if I can't install TMT 2.0?
I bought TMT version 3.0 with the 1.1.0.5.dll and it will not work with EAC3 no matter what steps I take. Only the regular asdecoder.ax works in graphedit. Is there a way I can get a hand on a previous dtsdecoder.dll version?
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline
Old 31st July 2009, 15:06   #9163  |  Link
xkodi
look here:
http://forum.doom9.org/showthread.php?t=148324
xkodi is offline
Old 5th August 2009, 19:34   #9164  |  Link
tebasuna51
tebasuna51's Avatar
Bug decoding dts 384 Kb/s with libav
The spanish audio from Blu-Ray movie La Cosa is :
Bitrate 384Kbps
Sample Rate: 48KHz
Channels: 2
299MB, 1h 48min
Without problem when use ArcSoft decoder, but is buggy when use libav.
Audio sample
Using ffmpeg to decode (or Foobar2000 or MeGUI/BeHappy) is also OK.
tebasuna51 is offline
Old 6th August 2009, 07:13   #9165  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
When you encode with Surcode use the .cpt (compact) format instead the .dts (padded) format. After rename to dts.
I tried searching, but no luck, I even searched through google. I was curious as to what exactly is "DTS zero padding"?
odin24 is offline
Old 6th August 2009, 09:21   #9166  |  Link
Octo-puss
is Madshi still MIA?
Octo-puss is offline
Old 6th August 2009, 09:48   #9167  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by odin24 View Post
I tried searching, but no luck, I even searched through google. I was curious as to what exactly is "DTS zero padding"?.
These 4 dts files (20 sec long) was encoded with Surcode, the padded ones add 0's bytes after the core frame to reach the 2048 boundary (to easy write and search on hardware)
File ........: D:\Test\dts\Jap_padD.dts ... 3840000 bytes
----------------------------------------- First Frame Info
Primary Frame Byte Size .....: 2012 ( 2013 bytes/frame)
Transmission Bit Rate .......: 24 (1536 Kb/s)
--------------------------------------------- Revised Info
Total Frames ......: 1875
Duration ..........: 20 seconds. ( 0 h. 0 m. 20 s.)
Pad Bytes min./max.: 35 / 35 (bytes between frames)
------------------------------------------------- End Info
Real frame = Core frame + pad bytes = 2013 + 35 = 2048
Real bitrate = 3840000 x 8 / 20 = 1536 Kb/s
File ........: D:\Test\dts\dJap_cptD.dts ... 3774375 bytes
Real Bitrate = 3774375 x 8 / 20 = 1509.75 Kb/s
File ........: D:\Test\dts\Jap_pad7.dts ... 3840000 bytes
Primary Frame Byte Size .....: 1005 ( 1006 bytes/frame)
Transmission Bit Rate .......: 15 (768 Kb/s)
Pad Bytes min./max.: 1042 / 1042 (bytes between frames)
Real frame = Core frame + pad bytes = 1006 + 1042 = 2048
File ........: D:\Test\dts\Jap_cpt7.dts ... 1886250 bytes
Real bitrate = 1886250 x 8 / 20 = 754.5 Kb/s
Old 6th August 2009, 17:08   #9168  |  Link
Pho3n1x
I have one Question,is there a Decoder for TruHD wich decodes all 7.1 channels with eac3to to mono waves or is the only way 5.1 channel with the Nero or the libav decoder?
Pho3n1x is offline
Old 7th August 2009, 01:32   #9169  |  Link
tebasuna51
tebasuna51's Avatar
Eac3to decode TrueHD 7.1 to 8 wavs with libav without problems
Old 8th August 2009, 03:54   #9170  |  Link
SomeJoe
Don't use -keepDialnorm never with ac3 or dts (I don't know with TrueHD), let eac3to work.
For my AV receiver (Pioneer VSX-1018AH-K), TrueHD will not play properly unless it is extracted with eac3to using -keepDialnorm.
Have never had a problem letting eac3to remove it with ac3 or DTS, however.
- SomeJoe
SomeJoe is offline
Old 9th August 2009, 00:27   #9171  |  Link
Snowknight26
You sure you're using the latest version? Even when its removing dialog normalization, its setting the value to -31dB. In some earlier versions, it set it to 0dB, which might be causing your issue.
Snowknight26 is offline
Old 9th August 2009, 08:11   #9172  |  Link
Revgen
Madshi is currently fighting Krell on Altair IV. He'll be back next month.
Moe: Why?
Revgen is offline
Old 9th August 2009, 14:23   #9173  |  Link
M-Blaster
Hi, by downcoding Renaissance HD-DVD comes the following error.
eac3to l:\mainevo.evo e:\ren
EVO, 1 video track, 2 audio tracks, 1 subtitle track, 1:45:09
1: VC-1, 1080p24 /1.001 (16:9) with pulldown flags
2: DTS Master Audio, German, 5.1 channels, 16 bits, 48khz
   (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48khz)
3: DTS Master Audio, English, 5.1 channels, 16 bits, 48khz
4: Subtitle (DVD), German
Track 2 is used for destination file "Ren".
This audio conversion is not supported.
even the option -core does not help.
DOes somebody have an idea how to strip this movie evo?
M-Blaster is offline
Old 9th August 2009, 15:56   #9174  |  Link
yesgrey
I don't know if you can simply use e:\ren to specify the directory for the demuxed files.
Try switching to e:\ren directory and then run from there eac3to l:\mainevo.evo -demux
yesgrey is offline
Old 9th August 2009, 16:06   #9175  |  Link
tebasuna51
tebasuna51's Avatar
Try with:
eac3to l:\mainevo.evo e:\ren.*
Old 9th August 2009, 17:27   #9176  |  Link
M-Blaster
how stupid I was
Now it runs with
"eac3to l:\mainevo.evo e:\ren.mkv"
Old 9th August 2009, 19:58   #9177  |  Link
SomeJoe
I normally use v3.14 because latest version has some type of problem where the last line of output to stdout is not present, so my front end cannot parse certain data.
But I have also tried v3.16 and get the same issue.
Apparently, my AV receiver is highly sensitive to a TrueHD stream. Unless -keepDialnorm is used, TrueHD output is very distorted.
It is no big deal, I have dialogue normalization turned off on the AV receiver anyway.
- SomeJoe
SomeJoe is offline
Old 11th August 2009, 14:30   #9178  |  Link
pascalwil
Hi
Anyone knows if/where eac3to source code is available? Thanks.
Cheers.
pascalwil is offline
Old 11th August 2009, 15:01   #9179  |  Link
kypec
User of free A/V tools
kypec's Avatar
AFAIK the source code to eac3to has never been released by madshi. Considering how long he's not been around this thread it seems rather disturbing. Development of such a great tool should continue because even revision 3.16 is still not "perfect" I think and many things can be improved on it.
kypec is offline
Old 11th August 2009, 18:02   #9180  |  Link
leeperry
Kid for Today
I don't see why he should go GPL, he's very busy IRL...be glad he made it public in the first place!
leeperry is offline
eac3to
