1st March 2009, 19:33 | #8441 | Link |
Problem remuxing a bluray
eac3to v3.11 command line: "D:\utils\BLURAY\Tools\eac3to\eac3to.exe" "T:\SOURCE_BLURAY\THE_SIGNAL\THE_SIGNAL\" 1) 2: "T:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 4: "T:\temp\RipBot264temp\job1\audio.1.dts" -core 1: "T:\temp\RipBot264temp\job1\chapters.txt" -progressnumbers ------------------------------------------------------------------------------ M2TS, 1 video track, 3 audio tracks, 3 subtitle tracks, 1:43:16, 24p 1: Chapters, 12 chapters 2: h264/AVC, 1080p24 (16:9) 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) 4: DTS Master Audio, French, 5.1 channels, 16 bits, 48khz (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48khz) 5: AC3, English, 2.0 channels, 224kbps, 48khz 6: Subtitle (PGS), French 7: Subtitle (PGS), French 8: Subtitle (PGS), French [v02] The video framerate is correct, but rather unusual. <WARNING> Creating file "T:\temp\RipBot264temp\job1\chapters.txt"... [a04] Extracting audio track number 4... [v02] Extracting video track number 2... [v02] Muxing video to Matroska... [a04] Extracting DTS core... [a04] Patching bitdepth to 24 bits... [a04] Creating file "T:\temp\RipBot264temp\job1\audio.1.dts"... Added fps value to MKV header. Video track 2 contains 148699 frames. eac3to processing took 17 minutes, 45 seconds. Done. the framerate is not stable (speedup the video track is bad) a few moment there is shifting frames (lost frames) it s working with another movie whith 23.XXX thanks for you help Last edited by glood1; 1st March 2009 at 19:37. |
1st March 2009, 20:57 | #8442 | Link |
madshi,
say, can you add a "set progressive flag" option into eac3to for slowdown clips/movies? that would make some pal to ntsc conversions proper. here is why... source is 1080i50 (film) and doesnt show any interlacing. slowing it down to 23.976fps works fine but the output file is not 1080/24p, it's 1080i48/1001. this gives playback problems on the ps3 for example. it's all jerky, like frame-dropping. Last edited by zeropc; 1st March 2009 at 20:59. |
2nd March 2009, 04:48 | #8443 | Link |
I am having a problem and I cannot figure it out. I'm trying to encode a dts master audio file to wma pro 5.1 but the audio keeps coming out all garbled when I play it on my 360. I have arcsoft total media theater 2.1.6.125 installed, and nero 7 installed. It is coming from a .m2ts files, I have tried demuxing using both xport and tsmuxer, and then I even tried doing the ac3 audio that is in the .m2ts file so that the nero codec would be used but the resulting .wma file was still garbled. I also even tried using the sonic dts decoder but I still get messed up sounds. I'm running on Vista x64 sp1, and i'm using eac3to to change the dts-ma file into a single .wav (the resulting file is ALWAYS 4.50 gigs exactly, shouldnt it be bigger?) then i use tranzcode .40 to split it up into individual .wavs for each channel, then I combine them into a .avi using wavavimux, then i use csscript to convert it to a wma pro file. Please someone help me figure this out. I have been trying all day and its getting on my last nerve.
2nd March 2009, 13:03 | #8444 | Link | |
@madshi
To my request: Quote:
v3.09 ... * fixed: clipping removal 2nd pass was executed even for "stdout" The 2nd pass can't be started due to "stdout". And with the 'normalize' parameter (or '2pass', working ok before 2.09) now I get: Code:
eac3to v3.12 command line: "D:\Programa\eac3to\eac3to.exe" "D:\Test\VideoS\VDPrueba\10.ac3" stdout.wav -down2 -normalize ------------------------------------------------------------------------------ AC3, 5.1 channels, 0:01:00, 448kbps, 48khz The Nero decoder doesn't seem to work, will use libav instead. Decoding with libav/ffmpeg... Remapping channels... Downmixing multi channel audio to stereo... Writing WAV... Creating file "stdout.pass1.wav"... The 2nd pass can't be started due to "stdout". <WARNING> eac3to processing took 2 seconds. Done.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 2nd March 2009 at 13:13. |
2nd March 2009, 14:15 | #8445 | Link | |
eac3to input.m2ts(s) trackno: output.wavs Anyway, at what stage in your process does the audio become garbled? If the wav file produced by eac3to is ok then it's not an eac3to problem. What happens if you play it? |
2nd March 2009, 18:43 | #8446 | Link |
Sorry, but I have not understood how to use Eac3to to get the sequence in a seamless branching BD.
I write : eac3to folder/wall-e and I get various Mpls which show video info and ALL THE LANGUAGES. In effect I would like to know what is the correct sequence for one language to obtain one m2ts with only one language Many thanks in advance |
2nd March 2009, 21:13 | #8447 | Link | |
The difference is that tsMuxeR .sup Versions contain PTS and DTS timing (Bytes 5-8 after the "PG" identifier), while the eac3to .sup contains only PTS (Bytes 1-4 after "PG"), DTS info is always zero. I had one subtitle track from Day after Tomorrow (info tables, graphical bitmaps) which doesn't display without DTS info. |
2nd March 2009, 23:20 | #8448 | Link | ||
3rd March 2009, 08:30 | #8449 | Link | |
you could try Clown_BD GUI, ideal for newcomers. |
3rd March 2009, 09:46 | #8450 | Link |
Hi Madshi,
while copying my last few Blu-rays i saw something like this: Code:
sXX Subtitle stream XX contains XX normal and XX forced captions Thanks for your great work again! S. |
3rd March 2009, 11:22 | #8452 | Link | |
3rd March 2009, 15:16 | #8454 | Link | |
3rd March 2009, 18:28 | #8455 | Link |
Madshi
eac3to seems to occasionally use the wrong title number when it's specified in the command. For example I get the following results getting all titles with Twelve Monkeys on HDDVD: Code:
eac3to v3.12 command line: "D:\Vtemp\programs\eac3to\eac3to.exe" "E:\Vtemp\12_MONKEYS_HDDVD" -log=main.txt ------------------------------------------------------------------------------ 1) feature_01.EVO+feature_02.EVO, 2:09:32 "feature" - VC-1, 1080p (16:9) - E-AC3, English, 5.1, 48khz - E-AC3, Italian, 5.1, 48khz - E-AC3, Spanish, 5.1, 48khz - E-AC3, English, 2.0, 48khz 2) 12_monkeys_archives.EVO, 0:39:30 "Bonus3" - VC-1, 1080p (16:9) 3) MAKINGOF12MONKEYSN6LE_HD.EVO, 1:27:28 "Bonus1" - MPEG2, 480i (4:3) - E-AC3, English, 2.0, 48khz 4) 12MONKEYSTRAILERN4FE_HD.EVO, 0:02:24 "Bonus2" - MPEG2, 480i (4:3) - E-AC3, English, 2.0, 48khz Code:
eac3to v3.12 command line: "D:\Vtemp\programs\eac3to\eac3to.exe" "E:\Vtemp\12_MONKEYS_HDDVD" 3) -log=3.txt ------------------------------------------------------------------------------ EVO, 1 video track, 0:39:32 1: Chapters, 237 chapters 2: VC-1, 1080p24 /1.001 (16:9) with pulldown flags Is this related to this change back in 2.84? * title sorting criteria changed: resolution is more important than runtime It seems that when using eac3to to display all titles then it gives priority to resolution as per the change, but when specifying the title in the command line it's still sorting by runtime. Thanks. |
3rd March 2009, 22:50 | #8456 | Link |
seems like the "a remaining delay of Xms could not be fixed" message is missing when using -slowdown:
eac3to v3.12 command line: G:\eac3to\eac3to D:\movie.ts G:\movie.mkv ------------------------------------------------------------------------------ TS, 1 video track, 1 audio track, 1:29:41, 50i 1: h264/AVC, 1080i50 (16:9) 2: AC3, 2.0 channels, 384kbps, 48khz, dialnorm: -22dB, -2332ms [v01] The video track contains the (probably incorrect) "full range" flag. <WARNING> [a02] Extracting audio track number 2... [a02] Removing AC3 dialog normalization... [v01] Extracting video track number 1... [a02] Applying (E-)AC3 delay... [v01] Removing "full range" flag from video bitstream. [a02] A remaining delay of +4ms could not be fixed. [v01] Muxing video to Matroska... [a02] Creating file "G:\belle - 2 - AC3, 2.0 channels, 384kbps, 48khz.ac3"... [v01] Detected PTS overflow... [a02] Detected PTS overflow... [a02] The last (E-)AC3 frame is incomplete and thus gets skipped. <WARNING> Added fps value to MKV header. Video track 1 contains 269074 frames. eac3to processing took 3 minutes, 6 seconds. Done. Code:
eac3to v3.12 command line: G:\eac3to\eac3to D:\movie.ts G:\movie.mkv -slowdown ------------------------------------------------------------------------------ TS, 1 video track, 1 audio track, 1:29:41, 50i 1: h264/AVC, 1080i50 (16:9) 2: AC3, 2.0 channels, 384kbps, 48khz, dialnorm: -22dB, -2332ms [v01] The video track contains the (probably incorrect) "full range" flag. <WARNING> Disabling DRC for Nero (E-)AC3 decoding... [a02] Extracting audio track number 2... [v01] Extracting video track number 1... [a02] Removing AC3 dialog normalization... [a02] Decoding with DirectShow (Nero Audio Decoder 2)... [v01] Removing "full range" flag from video bitstream. [v01] Writing new framerate "24fps /1.001" to bitstream. [v01] Muxing video to Matroska... [a02] DirectShow reports 2.0 channels, 24 bits, 48khz [a02] Applying RAW/PCM delay... [a02] Changing FPS from 25.000 to 23.976... [a02] Encoding AC3 <448kbps> with libAften... [a02] Creating file "G:\belleslowed - 2 - AC3, 2.0 channels, 384kbps, 48khz.ac3"... [v01] Detected PTS overflow... [a02] Detected PTS overflow... [a02] The last (E-)AC3 frame is incomplete and thus gets skipped. <WARNING> Added fps value to MKV header. Video track 1 contains 269074 frames. eac3to processing took 5 minutes, 26 seconds. Done. |
4th March 2009, 10:37 | #8457 | Link |
3 eyed CRT supporter
Madshi, a little feature request:
I'm trying to convert a mono 32 bit IEEE Float, 96khz .pcm file generated from DRC (Digital Room Correction software), to a mono 32bit IEEE Float 96khz .wav file. Eac3to works, but only up to 24 bit (if I put "-32", it gives the specify info error). If I could get eac3to to do this, then I can incorporate it in a giant .bat file which measures all 6 channels in my HT, then processes the measurement files with DRC, then converts to .wav format, ready for use in Convolver directshow plugin (or ffdshow, or foobar). All I do is place the microphone, turn it on, double click the shortcut to the .bat file, and it would all just happen. I've been searching for ages for a program to do the conversion (other than Audition, which is major overkill), it just occured to me that the program I use to convert my BDs to MKV might do it But at the the moment it's close but no cigar.. If it's only a little change...please? If it's a biggie, no problems, I'll keep hunting for something else. Thanks Mark |
4th March 2009, 11:18 | #8459 | Link | |
Yes. I tried: sox leftspeaker.pcm leftspeaker.wav and got: "sox formats: no handler for file extension 'pcm' " (I would expect that sox, like eac3to would need me to specify the bit depth, etc, but it doesn't even seem to recognise pcm at all). Any other suggestions are welcome (and sorry for the kinda OT..well, it is an audio conversion). I tried Audacity (16 bit it seems). Cooledit pro/audition will do it, but I'd prefer opensource, and command line...not that I'm picky Mark |
eac3to |
