Old 12th April 2006, 23:16   #1  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Big DVD Noise
I have big trouble with some DVD. Encoding look so terible. I use x264 but with XviD is same thing maybe little whrose.
Screenshot of one original frame:
Vob Segment:
http://www.mytempdir.com/590279
Encoded segment:
http://www.mytempdir.com/590291
Script used:
DGDecode_mpeg2source("PadURaj.d2v",info=3)
ColorMatrix(hints=true)
crop( 4, 14, -4, -16)
LanczosResize(640,352)
Encoder Settings:
x264.exe --pass 2 --bitrate 970 --stats ".stats" --ref 5 --mixed-refs --no-fast-pskip --bframes 3 --b-pyramid --b-rdo --bime --weightb --subme 6 --trellis 1 --analyse all --8x8dct --direct auto --me umh --progress --no-psnr --output "PadURaj.mkv" "PadURaj.avs"
So why you suggest for denoisers and other things
Regards
Shon3i
shon3i is offline   Reply With Quote
Old 13th April 2006, 09:52   #2  |  Link
Serbianboss
Serbianboss's Avatar
The best noise reduction filter for me is Convolution 3d filter.
http://forum.videohelp.com/viewtopic.php?t=225951
Serbianboss is offline   Reply With Quote
Old 13th April 2006, 10:08   #3  |  Link
MrTroy
When you open the avisynth file in a media player, does it have good quality?
MrTroy is offline   Reply With Quote
Old 13th April 2006, 11:09   #4  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
@MrTroy Quality is ok but noise is present. is not always a big noise.
@Serbianboss I tried with Convolution3D but i am not happy with results i tried "MovieHQ" and "MovieLQ" but is not good. Did you have other settings for Convolution3D
Old 13th April 2006, 13:03   #5  |  Link
Serbianboss
try this parametar (1, 32, 128, 16, 64, 10, 0)
This is most agressive parametar and is very good.
Old 13th April 2006, 17:48   #6  |  Link
DarkNite
Almost Silent Member
DarkNite's Avatar
You might want to give FFT3DFilter a try. You could check it's thread for some ideas on usage for different sources.
Rethinking the "Why?" chromosome.
DarkNite is offline   Reply With Quote
Old 13th April 2006, 21:44   #7  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
@Serbianboss I Tryed but is not help, i get whery blur picture and noise on it
@DarkNite I tryed FFT but is very slow denoiser, so if you have some example please show me.
Aslo i try PixieDust(5) whit combination of LimitedSharpen i get good results but if i can get little on speed i can encode movie. I can reach 1.0fps. Thanks
Old 13th April 2006, 23:41   #8  |  Link
Serbianboss
First picture is your source, second is with Convolution 3d with agressive parametars.
Second picture is little blury but there is not noise.
Old 14th April 2006, 00:40   #9  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
If you want quality and dont care about speed, use FFT3D or FRFun!
RAW
FFT3D
FRFun
Bye
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 14th April 2006, 01:36   #10  |  Link
Backwoods
ReMember
Backwoods's Avatar
Originally Posted by Soulhunter
FRFun!
Have any links about FRFun?
Backwoods is offline   Reply With Quote
Old 14th April 2006, 01:49   #11  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Just -> My PC: C:\Program Files\AviSynth 2.5\plugins\frfun3.dll
But I can send you a copy if you want... ^^
Bye
Old 14th April 2006, 10:01   #12  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
@Soulhunter Can you send me frfun3.dll or host it on www.mytempdir.com. And can you post avs script which you use for both FRFun and FFT3D thanks, and did you use LimitedSharpen. And what you suggest if speed important to me. Thanks
@Serbianboss Maybe this frame don't have noise but whole scene have. Picture is so blurness
Old 14th April 2006, 10:13   #13  |  Link
mod
keep manzo
mod's Avatar
Question: any idea about the speed difference on your machines when processing with FRFun?
Thanks
10 categories of persons exist : those who know the binary system and those who do not know it
mod is offline   Reply With Quote
Old 14th April 2006, 10:30   #14  |  Link
Serbianboss
where FRFun can be downloaded?
Old 14th April 2006, 12:22   #15  |  Link
Alain2
What type of algorithm is frfun applying?
I'll be interested for a copy as well :P
Alain2 is offline   Reply With Quote
Old 14th April 2006, 16:20   #16  |  Link
techmule
you can even try this, is fast and does not take away many details from the video.
Removegrain(mode=2)
STMedianfilter(3,3,1,1)
techmule is offline   Reply With Quote
Old 14th April 2006, 18:14   #17  |  Link
DarkNite
DarkNite's Avatar
If you have a video card that supports DirectX 9 then there's also FFT3DGPU if you're concerned about speed.
Old 14th April 2006, 18:27   #18  |  Link
Mr. Brown
Step into the Light
Mr. Brown's Avatar
try this
mdata = DePanEstimate()
DePanInterleave(data=mdata)
degrainmedian(mode=1)
SelectEvery(3, 1)
it's fast and good
Mr. Brown is offline   Reply With Quote
Old 14th April 2006, 18:58   #19  |  Link
Leo 69
Soulhunter, would you please send me an FRFun plugin or host it somewhere ? My mailbox is leo.69.is@gmail.com
It looks like it has better processing algorithm than FFT3D.
Please, post the settings as well.
Thank you
Leo 69 is offline   Reply With Quote
Old 14th April 2006, 20:53   #20  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Thank you
I agree with you, so Soulhunter please share with us FRFun. Please
@DarkNite Yes my video card support DirectX 9 and i try tomorow becouse now i start encoding with normal FFT3D and encoding will be finished tomorow, i am now open this enocding with bsplayer and looks very clean and good, so maybe is FFT3D my answer but if that FFT3DGPU faster this can be cool
@techmule I try this tomorow but i try STMedianFilter with default settings and i not be happy with encoding. Thanks anyway
@Mr. Brown Looks like a god script, I will try and post results, Thanks
