Old 12th February 2014, 17:32   #23001  |  Link
leeperry
Kid for Today
N3 and NL2 are close cousins but NL6 blows them both out of the water, the former are like watching through a window but the latter is opening the darn window and getting your head out
It's even more striking on 720p60 content than 1080p24, yay!
Old 12th February 2014, 17:35   #23002  |  Link
Shiandow
Yeah, quite interesting. Unfortunately it doesn't work this way for me. My code got more complicated and used more registers. Actually I'm a bit surprised that the performance hit is as small as it is with my code.
Anyway, does the change improve image quality in your tests, too?
The differences in image quality between the various versions are getting a bit too small for me to actually convincingly say which is better. I'm actually having trouble to tell them apart on some of the 'enhanced' images that were posted.
FWIW the new version does cause a 2%~3% increase in total GPU usage. Previously enabling error diffusion increased GPU usage by about 13%~14%, but with the new version this is closer to 16% so in my case the new error diffusion uses about 18% more GPU than the old one. This is on a Nvidia GTX560Ti.
Old 12th February 2014, 17:36   #23003  |  Link
Ver Greeneyes
N3 and NL2 are close cousins but NL6 blows both them both out of the water
Glad to see you have a strong preference again (I was wondering if the addition of the limiter would bring them closer together)
Old 12th February 2014, 17:46   #23004  |  Link
leeperry
Kid for Today
Me too, who needs 3D when you got NL6
Old 12th February 2014, 17:48   #23005  |  Link
madshi
Originally Posted by Shiandow View Post
newerror = (f(x) + error) - result;
Shouldn't it be: "newerror = (f(x) + error) - f(result);"?
high noise is random dithering.
Exactly!
Same here. The "limiter" did bring a visible improvement for me, though. At least it reduces/removes stray dots (from gray bars and pure black surfaces etc).
Old 12th February 2014, 17:52   #23006  |  Link
Shiandow
Yeah that should indeed be f(result), thanks.
Old 12th February 2014, 17:53   #23007  |  Link
bacondither
So many builds...
I used the 16-bit "gradient-perceptual.mkv" at the specific frame of "59, 29.970" and clipped the histogram at 4.
Just to give a little perspective i tested the "old" DC3 build and the new NoisyLimited. The improvement is doubleplus good!
DirectCompute3
NoisyLimited
I'm perfectly satisfied with the NoisyLimited build but will test the new randomised builds sometime in the weekend.
bacondither is offline   Reply With Quote
Old 12th February 2014, 17:59   #23008  |  Link
madshi
Originally Posted by bacondither View Post
So many builds...
Yeah, I know. And these are just the medium-noise builds. I still might offer a lower-noise option. But I'll work on that only after we've decided on the medium-noise builds.
Where can I get that MKV?
Old 12th February 2014, 18:02   #23009  |  Link
bacondither
Ver Greeneyes posted it earlier, here is is:
Old 12th February 2014, 18:02   #23010  |  Link
Ver Greeneyes
It's one I made a couple of days ago, link in my signature
By the way madshi, could you try the colored gradient with debanding? Looking at the horizontal bars adjacent to black (blue and white), even with debanding set to low I see the bars noticeably bleeding over into black. I'm using NL6 from your latest package, although I don't expect that to matter - if I turn debanding off the 'mist' on the black regions goes away.
Old 12th February 2014, 20:50   #23011  |  Link
XMonarchY
Posts: n/a
Yey! I like the latest "Noisy 2" ! I find it better than the old DC3, old ED2, and old ED4. I do see just a small amount of black dithering, but its acceptable.
I still dislike ED7 though...
I still see a lot of 3DLUT banding though - I guess that won't ever be helped...
Old 12th February 2014, 21:01   #23012  |  Link
6233638
I wonder if an option to apply debanding after the 3DLUT is applied rather than beforehand might be useful for this.
Old 12th February 2014, 21:02   #23013  |  Link
TheElix
Harry Potter and the Deathly Hallows Part 1 on Optoma GT760 720p DLP projector (around 10:00). Sitting close to a 84" screen so I see every little detail. +_+
My finalists are: NL1 and NL6. NL1 produces slightly cleaner image here in dynamic. I really can't tell be screenshots. But NL1 screenshot weights more. Does it mean it contains more information?
TheElix is offline   Reply With Quote
Old 12th February 2014, 21:24   #23014  |  Link
iSunrise
I was surprised, too. The key processing loop just consists of a lot of math stuff, like floating point multiplications, exp(), pow() etc instructions. I don't really understand why it's so much slower with DirectCompute(), either. Could be that DirectCompute doesn't understand the way the kernel uses shared memory. Anyway, I've not finished this yet. Maybe I'll find a way to bring this up to speed. But I'm not hopeful atm...
Would it make sense to write to AMD developer support and ask for help, providing them with the critical parts of your code (code snippets?)? Never done this myself, because I am still in the NV camp, but Iīve heard that some developers had success with it and AMD gave them some advices. Not sure if that would also help on NV hardware, though.
But there clearly is something either extremely non-optimized or unnecessarily slow (if you say itīs 10 times slower, thatīs a bit too much IMHO) within their DirectCompute compiler vs. OpenCL.
iSunrise is offline   Reply With Quote
Old 12th February 2014, 21:27   #23015  |  Link
DarkSpace
I'm not sure what to say or do about this. madVR tries to use OpenCL, and if it works, it works. If the OpenCL APIs error out, there's not much madVR can do about it.
I see, okay. It would be nice if there was a notice at least in the Debug OSD, though, so one can know without having to specifically test whether or not it fails.
DarkSpace is offline   Reply With Quote
Old 12th February 2014, 21:41   #23016  |  Link
nevcairiel
Debanding should probably only act on the source, and should in theory remove all kinds of banding before the 3DLUT is applied. It seems likely that the banding is caused by applying the 3DLUT after rounding the result to 8 bits, this could be solved by applying the 3DLUT before rounding to 8 bits but then you either need a Massive LUT (256 TiB) or you need to interpolate the 3DLUT, which is slow (and sort of defeats the point of using a LookUp Table in the first place).
IIRC, the 3DLUT is 8bit input and 16bit output through interpolation.
Old 12th February 2014, 21:41   #23017  |  Link
Ver Greeneyes
Eight lookups and seven calls to lerp() I guess (assuming a HLSL shader)? I wonder how much of a difference it would make visually.
Old 12th February 2014, 21:51   #23018  |  Link
Shiandow
I'm sort of confused on how this is done now, doesn't debanding increase the bitdepth of the original image? And if so how would you then use the 3DLUT? You'd either need a 16bit LUT which would be MASSIVE (256 TiB) or you'd need to interpolate the LUT, which sort of defeats the point of using a LookUp Table, or you'd need to round the image down to 8bits again which would make the debanding useless.
Old 12th February 2014, 21:55   #23019  |  Link
Shiandow
Sorry about that, I realized that I was probably mistaken about how the 3DLUT was used so I deleted that post, seems that I wasn't fast enough. Luckily your answers still make sense in the context of my other post.
Old 12th February 2014, 22:13   #23020  |  Link
Anime Viewer
Troubleshooter
Anime Viewer's Avatar
increased 3D effect
Me too, who need 3D when you got NL6
I have an LG tv that can convert 2d to 3d, and it appears with nl6 it may have more 3d enhancement compared to when I originally watched the same 2d->3d converted video using MPC-HC with MadVR back in December.
I'm all for anything that enhances 2d -> 3d given my TV, and if that is NL6 then it gets my vote.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV.
Last edited by Anime Viewer; 12th February 2014 at 22:16. Reason: forgot y in "my" :o
Anime Viewer is offline   Reply With Quote
