Old 7th September 2008, 20:29   #6121  |  Link
tman24
I'm sure this has been asked a lot, but I would appreciate a quick answer.
Is is possible to extract just 'forced' subtitles from HD rips using eac3to? Primarily this will be for blu-ray. I can extract the whole subtitle stream and process it using SubtitleCreator, but forced subtitles seem to be harder (or maybe not, if anyone knows the best way!).
tman24 is offline
Old 7th September 2008, 22:07   #6122  |  Link
markrb
Old fart
markrb's Avatar
I just updated to 2.61 and now get this error.
eac3to v2.61
command line: "D:\HD\ea\eac3to.exe" "H:\BDMV\STREAM\" 1) 2: "E:\video.mkv" -seekToIFrames 3: "E:\audio.ac3"
M2TS, 1 video track, 3 audio tracks, 3 subtitle tracks, 1:52:02
1: Chapters, 17 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 7.1 channels, 16 bits, 48khz
4: AC3, French, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
5: AC3, English, 2.0 channels, 224kbps, 48khz, dialnorm: -27dB
6: Subtitle (PGS), English
7: Subtitle (PGS), English
8: Subtitle (PGS), Spanish
[a03] AC3 encoding only supports 6 channels. Will mix the surround channels.
[v02] Extracting video track number 2...
[a03] Extracting audio track number 3...
[v02] Muxing video to Matroska...
[a03] Mixing surround channels...
[a03] The channel mixer received channels with different attributes.
[a03] Decoding with ArcSoft DTS Decoder...
[a03] The channel modder didn't receive the format information.
Aborted at file position 32768.
It all worked fine with Live Free and Die Hard DTS-HD
Now I am trying Bank Job DTS-HD and get this error.
Any thoughts?
BTW 2.60 worked fine on this movie.
Oh no Mr. Bill!
markrb is offline
Old 7th September 2008, 23:37   #6123  |  Link
rebkell
Originally Posted by rica View Post
Why do you use another cutter while TSMuxer exists?
Cut while remuxing and merge the files with eac3to. (another tip, btw there is no VC1 cutter except TSMuxer afaik.)
This conversation is totally off topic for this thread, but I have no idea what you are talking about, unless you're talking about tsremuxer and if so, it is too hard to determine what I'm doing and also I've never been able to get it to even mux the aac audio of the recordings I make.
rebkell is offline
Old 8th September 2008, 00:16   #6124  |  Link
rica
I was talking about TSMuxer as i said. You didn't tell you are re-encoding to aac btw.
Anyway forget about it.
I have a different scenario than the majority in this thread(I suppose). I record with the HD-PVR, then reencode with x264(to get some better IDR frames for scenecut purposes) and then mux it back into a ts with tsmuxer, then I cut out commercials with h264ts_cutter and I used to occasionally get some a/v sync problems. So there is no telling what kind of audio overlaps and gaps end up in the cut file.
rica is offline
Old 8th September 2008, 07:36   #6125  |  Link
Beastie Boy
Beastie Boy's Avatar
Originally Posted by Beastie Boy View Post
This doesn't work for me. If I specify a bitrate, eac3to errors with 'This audio conversion is not supported'.
Please ignore this post by me regarding thd+ac3 output.
I was editing the command line produced by eac3to_and_more_gui, and put the bitrate inside the quotes. I feel so embarrassed.
Beastie Boy is offline
Old 8th September 2008, 07:36   #6126  |  Link
madshi
I think forced subtitles are usually contained in an extra subtitle track, or am I wrong? If I'm not wrong, you just need to find the right subtitle track and demux it. Or just demux all subtitle tracks and check which one is the smallest. That should be the "forced" one. But I guess not all movies have forced subtitles...
eac3to v2.61
Any thoughts?
Will be fixed in the next build.
madshi is offline
Old 8th September 2008, 07:37   #6127  |  Link
madshi
eac3to v2.62 released
http://madshi.net/eac3to.zip
* fixed: downmixing 16 bit 7.1 DTS tracks to 5.1 stopped working in v2.61
madshi is offline
Old 8th September 2008, 09:28   #6128  |  Link
xkodi
madshi, how i can use the AGM write support, doing:
eac3to input_file output.agm
gives me
This audio conversion is not supported.
xkodi is offline
Old 8th September 2008, 09:43   #6129  |  Link
3ngel
Madshi, is there a possibility you can develop the DPLIIx matrix for 7.1 channels downmixing? It's quite different from a standard DPLII
That's the config
The DPLIIx is the evolution of DPLII and can be used obviously on 5.1 too.
3ngel is offline
Old 8th September 2008, 12:04   #6130  |  Link
Inventive Software
Turkey Machine
Thank you madshi for adding HDCD decoding support to your program. I have been looking for a solution to play my HDCD back as intended, and you've provided it!
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 8th September 2008, 13:20   #6131  |  Link
sehgal.v7
@Madshi
Why doesn't TSMuxer accept RAW, LPCM, PCM converted from TrueHD??
eac3to Audio.thd Audio.raw
eac3to Audio.thd Audio.lpcm
eac3to Audio.thd Audio.pcm
It only accepts WAV File// is that which is specified in Blu Ray specifications??
eac3to Audio.thd Audio.wav
I used to thought blu ray uses LPCM/PCM// but in that it swaps channels.
sehgal.v7 is offline
Old 8th September 2008, 13:30   #6132  |  Link
sehgal.v7
@Madshi
eac3to v2.62
command line: eac3to audio.thd audio.wav
TrueHD, 5.1 channels, 48khz
Decoding with libav/ffmpeg...
Writing WAV...
Creating file "audio.wav"...
This audio track has a constant bit depth of 16 bits.
eac3to processing took 16 seconds.
Done.
It again gives 24bit file :-(
Old 8th September 2008, 13:32   #6133  |  Link
madshi
I've tested it with "eac3to source.wav dest.agm". Which was your exact command line?
Downmixing to 5.1 or to 2.0? I'd need the exact matrix to implement that.
Originally Posted by sehgal.v7 View Post
Why doesn't TSMuxer accept [...]
Why do you ask me? I have not written tsMuxer.
Will check that... You can probably fix it by doing "eac3to audio.wav audio2.wav".
madshi is offline
Old 8th September 2008, 13:43   #6134  |  Link
sehgal.v7
I just wanted to confirm whether acc to Blu Ray specifications, LPCM is correct or PCM or WAV??
Old 8th September 2008, 13:52   #6135  |  Link
madshi
Ever heard of wikipedia?
madshi is offline
Old 8th September 2008, 13:57   #6136  |  Link
xkodi
eac3to.exe 51.wav 51.agm
WAV, 5.1 channels, 0:00:14, 24 bits, 6912kbps, 48khz
[edit]the problem is solved, it turns out that i've messed my eac3to version and was using 2.60. thanks to nautilus7 for giving me the idea to double check that.
xkodi is offline
Old 8th September 2008, 14:03   #6137  |  Link
nautilus7
nautilus7's Avatar
Look sehgal.v7,
tsmuxer is a buggy and incomplete program. It's developer hasn't shown up since months...
This "problem" with pcm input in tsmuxer has been covered (in this thread) a while ago. In short, it doesn't accept "normal" pcm files, but pcm files in a very weird form. Tebasuna51 was kind enough to make a program (pcm2tsmu) that makes tsmuxer compatible pcm files.
Anyway, I 've seen a lot tsmuxer users asking here why this or that doesn't work with tsmuxer. I understand that they don't know what else to do, except than asking eacto's developer to help, since tsmuxer's developer has forgot them... but that's not proper for madshi.
@ xkodi
Are you sure your version is 2.61/2.62?
nautilus7 is offline
Old 8th September 2008, 14:26   #6138  |  Link
sehgal.v7
Why you guys heating up so much??
I jus asked// if you knew, you shared.. thn wht's being arrogant of this??
Old 8th September 2008, 14:28   #6139  |  Link
xkodi
you are right i messed my versions and was using 2.60. the problem is solved. thanks!
xkodi is offline
Old 8th September 2008, 14:31   #6140  |  Link
nautilus7
nautilus7's Avatar
Oh, really? Too bad i tried to explain the "situation".
You should have used search before asking then... (I guess you like this answer better, huh?)
eac3to
