Old 17th May 2005, 01:01   #201  |  Link
Flashmeister
codec of file that won't open with MPEG4 Modifier
According to GSpot and VirtualDubMod, the files are XviD. See attached screenshot from VDM. I didn't see a convenient way to log or screenshot the info from GSpot.
So, MPEG4 Modifier should open it, no?
Thanks,
Greg
Flashmeister is offline   Reply With Quote
Old 17th May 2005, 12:02   #202  |  Link
bond
if its really xvid than yes
Ogg Theora | Ogg Vorbis
Old 17th May 2005, 12:43   #203  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
...unless the file is an OpenDML AVI, which is currently biting me in the rectum...
np: Metamatics - Rapala Shad (From Death To Passwords Where You're A Paper Aeroplane)
Leak is offline   Reply With Quote
Old 24th May 2005, 12:36   #204  |  Link
Infirmus
Infirmus's Avatar
My player (Zensonic Z330) just got a firware upgrade that allows it to play packed bitstream! Yay! Dont need to use MPEG4 Modifier anymore..! Thanks for the very usefull tool while I still needed it Moitah.
Infirmus is offline   Reply With Quote
Old 29th May 2005, 15:59   #205  |  Link
BigJim
Can someoe tell me how the use this prog?
I have an AVI standalone player (yamada DVX 6600) and the XVID support isn't that good.The XVID movies are played back jerky.
This programm could fix the jerky playback except I don't know excactly what to change or modify.Should I just unpack the film?
Is there a tutorial somewhere??
Sincerely
Simon
BigJim is offline   Reply With Quote
Old 30th May 2005, 21:08   #206  |  Link
Birdy1
[Browse...] for the file, check the [unpack] checkbox, [save...] the file
Birdy1 is offline   Reply With Quote
Old 31st May 2005, 17:53   #207  |  Link
derevo
i tried to modify xvid's aspect ratio, but it does not change. when i modified file by this program and i open this file in mpeg4 midifier and see video info there aspect ratio is changed, but when i watch it in any player aspect ratio is same that it was in non modified file. where is problem??
derevo is offline   Reply With Quote
Old 31st May 2005, 18:04   #208  |  Link
Birdy1
The only player I know of that supports the aspect ratio is VLC media player
Old 31st May 2005, 18:05   #209  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Originally Posted by derevo
... but when i watch it in any player aspect ratio is same that it was in non modified file. where is problem??
What "direct-show" decoder filter are you using with your software media player?
If you can try these 16:9 AR Signalling Test Encodes and these 4:3 AR Signalling Test Encodes please!
EDIT:
So does Nero's ShowTime 2 Player. And so do 3ivx's, XviD (newest beta) and DivX's (5.3.0.1461) DSdec filters...
Cheers
Old 31st May 2005, 18:20   #210  |  Link
derevo
i don't know what is direct-show decoder filter.
where i can look it and change??
Old 31st May 2005, 19:10   #211  |  Link
SeeMoreDigital
If you are using say, Windows Media Player, it's stated under: "Files" then "Properties"... And you should see it here: -
Cheers
Old 31st May 2005, 19:30   #212  |  Link
derevo
in my file it is also "XviD MPEG-4 Video Decoder".
in file wich come from satellite resolution is 720x576 and aspect ratio is 3:4,
but when i compress it in xvid aspect ratio becomes to 5:4.
here is screenshots:
http://www.saunalahti.fi/isos/5.4.gif
http://www.saunalahti.fi/isos/4.3.gif
mpeg4 modifier does not change it.
Old 31st May 2005, 20:15   #213  |  Link
SeeMoreDigital
When you visit XviD's "Configure Decoder" settings, does the GUI look similar this one?
Cheers
Old 31st May 2005, 20:50   #214  |  Link
derevo
not, it is an other.
here is screenshot:
Old 31st May 2005, 21:04   #215  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
That's the encoder screen. you can access the decoder config in Start Menu -> Programs -> Xvid -> Configure Decoder.
ChronoCross is offline   Reply With Quote
Old 31st May 2005, 21:05   #216  |  Link
SeeMoreDigital
That's XviD's "decoder" panel, which is available via the "encoder"!
The "decoder" GUI I'm talking about is accessable via the "Start" button... Then, Programs/XviD/Configure Decoder (or something similar)
Cheers
Old 31st May 2005, 22:01   #217  |  Link
derevo
yes, encoder is same as that on your screenshot.
Old 31st May 2005, 22:08   #218  |  Link
derevo
i tried to change options in there windows and now aspect ratio is right
thanks for answer.
it is very difficult to use computers.
Old 9th June 2005, 02:53   #219  |  Link
Vladdy
Will we see a version that supports the openDML format?
I have some 2+ gb avi's that have an embedded AR and can't use this app
Vladdy is offline   Reply With Quote
Old 9th June 2005, 10:27   #220  |  Link
dimitrik
OpenDML DML support would be greatly appreciated.
I also have a lot of older files that I would like to convert. I guess openDML was very popular at one time
for the great tool!
dimitrik is offline   Reply With Quote
