20th November 2011, 00:21 | #11021 | Link |
I'm a little new to this so please don't bite :P
When using fullscreen exclusive mode with PotPlayer I can't seem to get the seek bar to show. I have it enabled. The only thing that will appear upon mouse movement is the potplayer controls which takes the player back into windowed mode. Thanks! |
20th November 2011, 02:39 | #11022 | Link |
Continuous Beta Tester
a couple of questions to all,
Does dxva2 de-interlace work with VC1 1080i50? Which are optimal settings in CCC? (auto-deinterlace [on] / pulldown detection [on] all other video options disabled?) minimum hw requirements for ATI cards (from you experience?) |
20th November 2011, 03:29 | #11024 | Link | |
Everything is off, *except*: Dynamic Range (Limited) Automatic deinterlace Pulldown.. Enforce Smooth... Apply current video settings to Internet video In madVR, I just set the queues back to "managed". For deinterlacing to work, I have to make sure my CPU is running 1100Mhz (all four cores) for SD and 2300Mhz for HD. For progressive material (23.976) it runs at 700Mhz for SD and 1700Mhz for HD. Using an Athlon II X4 (and K10Stat). The lowest end ATI card I have is an HD2600XT, which I haven't tested yet for deinterlacing. |
20th November 2011, 04:47 | #11025 | Link | |
quack quack
It's been quite a while since I last saw the CCC. I install only the bare drivers and worked out how to tweak settings (all enhancements off, adjust the saturation down) via the registry. It's very stable, it stops me going into CCC and mucking it up by tweaking the settings too much. |
20th November 2011, 05:20 | #11027 | Link | |
quack quack
Anyway, I recorded my findings and progress HERE. |
20th November 2011, 08:35 | #11029 | Link |
BTW, ATI tray Tools gives me BSOD on my Win7 x64 + Radeon 6750.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
20th November 2011, 10:03 | #11030 | Link | |
But yeah, you generally want to disable all the settings in the Video section of AMD Vision Center (or whatever it's called). Last edited by rahzel; 20th November 2011 at 10:05. |
20th November 2011, 11:06 | #11031 | Link |
AV heretic
DXVAChecker is good tool to double check (and edit) CCC settings. For advanced users only!
I prefer to keep deinterlacing in VA. This way, if I see some judder I understand that I forgot to change EVR CP to EVR (I can't get HW decoding and deinterlacing with my 5450 and madVR). Otherwise it will be EVR CP with some ugly but easyest deinterlacing method. |
20th November 2011, 11:26 | #11032 | Link |
can you actually make more changes with the dxva checker you othewise cant do in ccc? e.g. enabling stuff which is otherwise unsupported by dvxa (like interlaced vc-1 support)?
20th November 2011, 12:22 | #11033 | Link |
Interlaced VC-1 is supported just fine by DXVA, its just MPC-HC and ffdshows DXVA codecs that dont support it.
20th November 2011, 14:45 | #11034 | Link |
so how could I get interlaced vc-1 stuff to play if ffdshow and mpc-hc dont support it (excluding products like tmt or powerddvd)?
20th November 2011, 14:55 | #11035 | Link |
very simple - use the Microsoft decoder provided with your OS
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
20th November 2011, 14:57 | #11036 | Link |
which one do you mean? the wmvvideo decoder dmo? or another one?
20th November 2011, 14:59 | #11037 | Link | |
I was able to get it to work with a opengl wrapper but only with the internal Display. So the question remains does madVR interpret 25 Hz Interlaced (madVR doesnt work) same as 50 Hz Interlaced (madVR works)? |
20th November 2011, 15:02 | #11038 | Link |
you guessed right - WMVideo Decoder DMO
20th November 2011, 15:35 | #11040 | Link |
It supports DXVA just fine, but only in WMP
