Old 5th January 2005, 20:40   #41  |  Link
Ark
Aikidoka
Ark's Avatar
Originally posted by Didée
Hah, I found an even faster method than this aSharp().aWarpsharp() combo !!!
Try the following:
sharpen(0.2)
W00T!
But seriously. A method to *really* do a minimal version of LS was pointed out by kassandro, uses his RemoveGrain filter set, and was named ModerateSharpen():
#  a function by kassandro.
# (just made "repmode" a parameter / Didée)
function ModerateSharpen(clip input, float amount, int "repmode")
	repmode = default(repmode,1)
	sharpened = Sharpen(input, amount)
	return Repair(sharpened, input, mode=repmode)
This one should run above realtime without any problems. Practicable "repmode"s are 1 & 2. Maximal "amount" is 1.0, but one should use less, because of the aliasing problem.
I tried it some time ago and for me it's veeeery like an XSharpen without those "dancing" pixels seen in XSharpen used at high values, so it can be a nice candidate for "supersampled" use, from the simplest
Lanczosresize(x*2,y*2).Moderatesharpen(1.0).Lanczosresize(x,y)
to more the complicted ways *you* can think of .....
Xvid fan ;)
Ark is offline   Reply With Quote
Old 6th January 2005, 00:40   #42  |  Link
Socio
I tried it out and it is no LS-LS2 but does do a nice job and very light on resources.
BTW: If I go past 0.2 I will get similar edge jaggies that I get with LS2-Thresh above 0.5, very strange.
Socio is offline   Reply With Quote
Old 19th January 2005, 02:19   #43  |  Link
dvwannab
need more help
some help please. I am getting a VDmod error : "there is no function asharp" line 63.
script:
LoadPlugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\dgdecode.dll")
LoadPlugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\plugins\MaskTools.dll")
Import("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\plugins\limitedsharpen2.avs")
mpeg2source("D:\ReplayTV\Local_Guide\FraCro.d2v")
Limitedsharpen2(ss_x=1,ss_y=1,Smode=4,aSharpS=0.4,aWThresh=0.99)
__________________________________________
code:
# LimitedSharpen2()
# A multi-purpose sharpener by Didée, hacked by Akirasuto n' Soulhunter... ^^
function LimitedSharpen2( clip clp,
\ float "ss_x", float "ss_y",
\ int "dest_x", int "dest_y",
\ int "Smode" , int "strength", int "radius",
\ int "Lmode", bool "wide", int "overshoot",
\ bool "soft", int "edgemode", bool "special",
\ float "aSharpS", float "aWThresh", int "exborder" )
ox = clp.width
oy = clp.height
ss_x = default( ss_x, 1 )
ss_y = default( ss_y, 1 )
dest_x = default( dest_x, ox )
dest_y = default( dest_y, oy )
Smode = default( Smode, 4 )
strength = Smode==1
\ ? default( strength, 160 )
\ : default( strength, 100 )
strength = Smode==2&&strength>100 ? 100 : strength
radius = default( radius, 2 )
Lmode = default( Lmode, 1 )
aSharpS = default(aSharpS, 0.5)
aWThresh = default(aWThresh,0.75)
wide = default( wide, false )
overshoot= default( overshoot, 1)
overshoot= overshoot<0 ? 0 : overshoot
soft = default( soft, false )
edgemode = default( edgemode, 0 )
special = default( special, false )
exborder = default( exborder, 0)
xxs=round(ox*ss_x/8)*8
yys=round(oy*ss_y/8)*8
smx=exborder==0?dest_x:round(dest_x/Exborder/4)*4
smy=exborder==0?dest_y:round(dest_y/Exborder/4)*4
clp.isYV12() ? clp : clp.converttoyv12()
ss_x != 1.0 || ss_y != 1.0 ? last.lanczosresize(xxs,yys) : last
tmp = last
edge = logic( tmp.DEdgeMask(0,255,0,255,"5 10 5 0 0 0 -5 -10 -5", divisor=2)
\ ,tmp.DEdgeMask(0,255,0,255,"5 0 -5 10 0 -10 5 0 -5", divisor=2)
\ ,"max").levels(0,0.86,128,0,255,false)
bright_limit = (soft == true) ? tmp.blur(1.0) : tmp
dark_limit = bright_limit.inpand()
bright_limit = bright_limit.expand()
dark_limit = (wide==false) ? dark_limit : dark_limit .inflate.deflate.inpand()
bright_limit = (wide==false) ? bright_limit : bright_limit.deflate.inflate.expand()
minmaxavg = special==false
\ ? yv12lutxy(bright_limit,dark_limit,yexpr="x y + 2 /")
\ : maskedmerge(dark_limit,bright_limit,tmp,Y=3,U=-128,V=-128)
Str=string(float(strength)/100.0)
normsharp = Smode==1 ? unsharpmask(strength,radius,0)
\ : Smode==2 ? sharpen(float(strength)/100.0)
\ : Smode==3 ? yv12lutxy(tmp,minmaxavg,yexpr="x x y - "+Str+" * +")
\ : asharp(aSharpS,0,0).awarpsharp(3,1,bm=3,cm=0,aWThresh)
OS = string(overshoot)
Lmode == 1 ? yv12lutxy( bright_limit, normsharp, yexpr="y x "+OS+" + < y x "+OS+" + ?")
\ : yv12lutxy( bright_limit, normsharp, yexpr="y x "+OS+" + < y x y x - "+OS+" - 1 2 / ^ + "+OS+" + ?")
Lmode == 1 ? yv12lutxy( dark_limit, last, yexpr="y x "+OS+" - > y x "+OS+" - ?")
\ : yv12lutxy( dark_limit, last, yexpr="y x "+OS+" - > y x x y - "+OS+" - 1 2 / ^ - "+OS+" - ?")
edgemode==0 ? NOP
\ : edgemode==1
\ ? MaskedMerge(tmp,last,edge.inflate.inflate.blur(1.0),Y=3,U=1,V=1)
\ : MaskedMerge(last,tmp,edge.inflate.inflate.blur(1.0),Y=3,U=1,V=1)
(ss_x != 1.0 || ss_y != 1.0)
\ || (dest_x != ox || dest_y != oy) ? lanczosresize(dest_x,dest_y) : last
ex=blankclip(last,width=smx,height=smy,color=$FFFFFF).addborders(2,2,2,2).coloryuv(levels="TV->PC")
\.blur(1.3).inpand().blur(1.3).bicubicresize(dest_x,dest_y,1.0,.0)
tmp=clp.lanczosresize(dest_x,dest_y)
clp.isYV12() ? ( exborder==0 ? tmp.mergeluma(last)
\ : maskedmerge(tmp,last,ex,Y=3,U=1,V=1) )
\ : ( exborder==0 ? tmp.mergeluma(last.converttoyuy2())
\ : tmp.mergeluma( maskedmerge(tmp.converttoyv12(),last,ex,Y=3,U=1,V=1)
\ .converttoyuy2()) )
return last
dvwannab is offline   Reply With Quote
Old 19th January 2005, 02:33   #44  |  Link
Socio
You need to download aWarpsharp and aSharp plugins and load them as well.
Should look like this:
SetMemoryMax(96)
Import("C:\Program Files\AviSynth 2.5\plugins\LimitedSharpen2.avs")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MaskTools.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\WarpSharp.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\asharp.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\aWarpSharp.dll")
LimitedSharpen2( ss_x=1.0, ss_y=1.0,
\ Smode=4, strength=40, radius=2,aSharpS=1,
\ Lmode=1, wide=false, overshoot=1,
\ soft=false, edgemode=0, special=false,
\ exborder=0 )
Old 19th January 2005, 08:00   #45  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Trust me, you don't want to put any warpsharp.dll in the autoloading plugins folder. Just to be safe you know
Old 20th January 2005, 18:19   #46  |  Link
dvwannab
thanks
thanks guys, it worked. Looks good
Old 20th January 2005, 20:52   #47  |  Link
dvwannab
one question
what does SetMemoryMax() do and what is the purpose?
Old 20th January 2005, 22:38   #48  |  Link
DeepDVD
DVD Destroyer
Re: one question
It's a limitation of memory usage. Some buggy filters don't work without a limitation as i read in some threads before. Also you can handle the usage by yourself for whatever reason
DeepDVD is offline   Reply With Quote
Old 21st January 2005, 08:09   #49  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
I agree - but we're talking about aWarpSharp here, which I never had a problem with when it's autoloaded; it's the non-"a" warpsharp DLLs that cause trouble.
Leak is offline   Reply With Quote
Old 21st January 2005, 08:16   #50  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Yep, I should have been a bit more clear..I meant any of the warpsharp.dlls that are out there. I think there are several of which some seem to work and some don't
Old 5th February 2005, 03:08   #51  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Soulhunter,
how i can download files (plugins) noted in first post of the thread?
Old 5th February 2005, 10:06   #52  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Ok, I have updated the link in my first post...
Bye
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 5th February 2005, 10:51   #53  |  Link
Leak
Leak's Avatar
How about sharing it using http://www.rapidshare.de/en/main.html?
That'd be less awkward than using GMX for this...
np: Radiohead - I Might Be Wrong (Amnesiac)
Old 5th February 2005, 11:39   #54  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Thanks for the hint, here is the link... ^^
There should be a sticky with a list of free hosting like ImageShack or RapidShare!
Bye
Old 14th February 2005, 03:41   #55  |  Link
unimatrixzer0
I coped the code from the first page and downloaded the 2 dll's but I'm getting this error everytime I load my avs into vdubmod,
Script error: there is no fuction named "yv12lutxy"
unimatrixzer0 is offline   Reply With Quote
Old 14th February 2005, 06:18   #56  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
@ unimatrixzer0
Hrm, maybe you need the latest version of MaskTools!?
Bye
Old 14th February 2005, 09:01   #57  |  Link
Didée
Outdated link, Soulhunter
http://manao4.free.fr
Old 14th February 2005, 09:19   #58  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Doh! ^^;
Bye
Old 8th May 2005, 14:37   #59  |  Link
ADLANCAS
ADLANCAS's Avatar
How could I download files from the first post (including dlls) ?
Thanks,
Alexandre
ADLANCAS is offline   Reply With Quote
Old 8th May 2005, 15:13   #60  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Fresh link... ^^
Bye
