3rd October 2011, 13:02 | #9961 | Link | |
- Change Pixel settings and reboot within 30 seconds. After reboot the Pixel setting does not switch back anymore. |
3rd October 2011, 18:43 | #9962 | Link |
What does 'run presentation in a separate thread' and 'limit rendering times to avoid glitches' do exactly?
I get quite a lot of presentation glitches while playing back DVDs. Every 5 min or so the motion will be noticeably choppy for a few seconds. Of those two options, the latter reduced the amount of glitches much more. |
4th October 2011, 02:09 | #9963 | Link | |
Edit: Just some settings you might want to try messing around with.. they helped with playback for me. I've noticed personally that in rendering -> Exclusive mode settings unchecking delay switch to exclusive mode and increasing the amount for 'how many video frames shall be presented in advance' helps with playback immensely, so I'd recommend messing around with those a bit to see what works better for you. In rendering -> windowed mode settings increasing 'how many backbuffers shall be used' may also help, but if I remember correctly I only did it by one so try changing that and see how it works out. I also noticed that for the 'when and how shall the GPU be flushed:' changing flush to 'flush & wait (sleep)' in the 2nd drop down list in windowed mode settings and exclusive mode settings helps. Last edited by golagoda; 4th October 2011 at 02:27. |
4th October 2011, 02:34 | #9964 | Link |
Thanks for the tips golagoda
Do you mean to change windowed and exclusive to: flush & wait (sleep) flush & wait (sleep) don't flush don't flush By default "...after intermediate render steps" is Flush |
4th October 2011, 04:18 | #9965 | Link | |
General settings - http://i.imgur.com/wVV62.jpg (The 'delay playback until render queue is full' setting would probably help you more if it was enabled but I have it disabled.) Exclusive mode - http://i.imgur.com/pN5f9.jpg ( Having 'present several frames in advance' set to disabled would also probably help you more if it was disabled but I have it enabled.) Windowed mode - http://i.imgur.com/DcMaJ.jpg I also use LAV CUVID (Which has since been merged into LAVFilters) since I have a Nvidia GPU which helps immensely, so if you aren't using that already and have a Nvidia GPU definitely use that. Last edited by golagoda; 4th October 2011 at 04:23. |
4th October 2011, 06:26 | #9966 | Link |
What I've done...
Backbuffers 3 --> 4 Frames presented in advance 4 --> 6 enabled: 'limit rendering times to avoid glitches' This seems to have eliminated 95% of presentation glitches. Why is enabling that certain option not recommended? I have to wonder Using a GT240 (GDDR5) fyi Last edited by JarrettH; 4th October 2011 at 20:15. |
4th October 2011, 17:34 | #9967 | Link | |
I posted the question about whether it should be enabled by default before, but I think it got overlooked. Because I have plenty of RAM, I just set the maximum number of buffers available, and that option combined with the DX11 rendering path fixed all the presentation glitches for me. I used to have to mess around with the flush settings on my old build (Nvidia 9400) to get smooth performance, but since the exclusive mode was added (and a few builds later) the default settings seem to work best. Before the "limit rendering times" option was added, the flush settings did nothing to fix the presentation glitches with my GTX570. Last edited by 6233638; 4th October 2011 at 17:36. |
4th October 2011, 17:49 | #9968 | Link |
I actually get glitches if i use 16 buffers, 12 seems to be the sweet spot for me right now.
Combined with "use a separate device for presentation" (but not DX11), flushing: dont/flush/flush/dont and "limit rendering times to avoid glitches", its pretty much perfect now. Default settings used to glitch on non-matched refresh rates, be it 25p at 50Hz, or even 24p at 60Hz, but these are perfect. The only problem i have right now is that after playing some files consecutively without closign the player, exclusive mode fails. Restarting the player fixes it ... This is on a GTS450
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 4th October 2011 at 17:52. |
4th October 2011, 18:04 | #9969 | Link |
I'll have to try that, Nev. I'm still getting some glitches with my settings on my 450. Sounds like you found the "magic".
4th October 2011, 19:30 | #9970 | Link |
I'm on a GTX460 768MB, with 258 drivers Win 7-64. I have to enable "limit rendering times" and "overshoot max frame latency" to avoid glitches, but if I enable "run presentation on a separate thread", I get a lot of dropped frames after seeking sometimes. Luckily the other two settings are sufficient to avoid glitches for most content. On some content though (it was a 30p file played at 60Hz) my present queue drops slowly and after that I still had periodic glitches, until I enabled D3D11 and the present queue stays full then.
4th October 2011, 19:33 | #9971 | Link |
D3D11 works for playback for me as well, however its somewhat unusable because exiting FSE doesnt re-draw the desktop or the player properly.
I've had the queues dropping low problem as well with some settings, but the current setup is working just nice.
4th October 2011, 22:38 | #9973 | Link |
Im sure hes reading, but just not answering or doing any more than making notes
5th October 2011, 05:20 | #9974 | Link | |
QB the Slayer
QB
5th October 2011, 07:18 | #9976 | Link | |
QB the Slayer
QB
5th October 2011, 08:23 | #9977 | Link |
He's certainly posting in other threads more than here and he's not dead so that counts as active to me
Perhaps your interpretation of active is a lot more active than mine, but when you've seen projects go months or years without developer input your view on what's active or not changes a lot! Anyway best not to let this thread degenerate into chaos due to a few measly weeks without a post from Madshi, let us remain calm :P Agreed, they've really improved the HTPC experience a lot, I would be happy to pay for their software. Last edited by ryrynz; 5th October 2011 at 08:27. |
5th October 2011, 11:18 | #9978 | Link | |
5th October 2011, 12:43 | #9979 | Link |
Hmm... while we're somewhat on the topic of settings what scaling algorithms do you all use for madVR?
I'm currently trying out 'SoftCubic' with softness set to 60 for each option, I honestly don't notice that much difference between different scaling algorithms and haven't tested it out too much but there's always room for improvement and testing out other settings has helped me find ways to improve playback greatly, for example the settings nev said earlier work amazingly |
5th October 2011, 12:54 | #9980 | Link |
I use Lanczos 4-taps for both Luma variants, and SoftCubic 60 for Chroma.
Lanczos produces a bit sharper image when watching SD content, which i've been doing alot lately.
