Old 3rd May 2019, 05:28   #21  |  Link
SilSinn9801
Chiptuner & VapourSynther
SilSinn9801's Avatar
Originally Posted by poisondeathray View Post
vfx[1] should be black and white
Yes, it was binary black and white (monochrome).
If you're loading as an array of RGB + alpha, you need to specify if it's using [0] or [1] . Those newer versions require alpha = True to load the alpha. So just omit that for the RGB background
If you're loading both (it will be a "dummy" alpha) . Since you want the RGB background, it should be [0]
rawlogoframe = core.std.AssumeFPS(rawlogo[0],fpsnum=60000,fpsden=1001)
I now get a new, different error when applying HolyWu’s Overlay:
Avisynth open failure:
Python exception: List index out of bounds
Traceback (most recent call last):
File "src\cython\vapoursynth.pyx", line 1927, in vapoursynth.vpy_evaluateScript
File "src\cython\vapoursynth.pyx", line 1928, in vapoursynth.vpy_evaluateScript
File "C:\(fakepath)\Script.vpy", line 134, in <module>
finallogo = haf.Overlay(logo,vfx[0],mask=vfx[1])
File "src\cython\vapoursynth.pyx", line 1402, in vapoursynth.VideoNode.__getitem__
IndexError: List index out of bounds
SilSinn9801 is offline   Reply With Quote
Old 3rd May 2019, 05:32   #22  |  Link
poisondeathray
If you're loading the alpha for "logo" you need to specify [0] or [1] . You want [0] for RGB
finallogo = haf.Overlay(logo[0],vfx[0],mask=vfx[1])
Old 3rd May 2019, 05:35   #23  |  Link
SilSinn9801
I am not using alpha for logo.
Old 3rd May 2019, 05:36   #24  |  Link
poisondeathray
Then don't load it. Use alpha=False or omit it for ffms2 for the logo
Use alpha=True for vfx ffms2 loading
Old 3rd May 2019, 05:49   #25  |  Link
SilSinn9801
Even with alpha=False for logo and alpha=True for each vfx image, I get the same error, and I am suspecting why:
Did you see above on my original script that I was repeating each VFX frame by either 2, 3, or 4 (using the * operator) and then concatenating all repeated frames together (with the + operator)? When trying separately vfx00[0].set_output(), vfx01[0].set_output(), vfx02[0].set_output(), … and vfx00[1].set_output(), vfx01[1].set_output(), vfx02[1].set_output(), …, I am not getting repeated frames, but rather single frames at the output. Is there some other way to repeat a frame without using the * operator?
Last edited by SilSinn9801; 3rd May 2019 at 05:50. Reason: alpha=True for each vfx on original script at the start of the thread
Old 3rd May 2019, 05:59   #26  |  Link
poisondeathray
Loop
http://www.vapoursynth.com/doc/functions/loop.html
Old 3rd May 2019, 06:08   #27  |  Link
SilSinn9801
Using Loop:
vfx00 = core.std.Loop(vfx00, times=118)
I get error:
Python exception: Loop: argument clip is not of array type but more than one value was supplied
Old 3rd May 2019, 06:15   #28  |  Link
SilSinn9801
Apparently, for Loop not to crash, I have to issue the Loop command individually for both [0] and [1]:
vfx00[0] = core.std.Loop(vfx00[0], times=118)
vfx00[1] = core.std.Loop(vfx00[1], times=118)
So my code will get more tedious since I have to deal with 88 different VFX frames.
Old 3rd May 2019, 06:16   #29  |  Link
poisondeathray
You have to divide up the RGB, and alpha
eg.
clip = core.ffms2.Source(r'VFX__172.PNG', alpha=True)
clip2rgb = clip[0] * 30
clip2alpha = clip[1] * 30
clip2rgb.set_output()
#clip2alpha.set_output()
Old 3rd May 2019, 06:18   #30  |  Link
poisondeathray
I must say that avisynth handles it much better from a user standpoint...
There might be some 'python magic' that can simplify this
Old 3rd May 2019, 06:23   #31  |  Link
SilSinn9801
Yes, I was originally an avisynth user, but got tired of it being non-Unicode-aware (and tired of having to either rename my sources to ASCII only or move them to ASCII-only filepaths).
Old 3rd May 2019, 07:01   #32  |  Link
SilSinn9801
Originally Posted by HolyWu View Post
Since we are in python scripting, you can simply define a helper function for convenience.
def loop_vfx(c, times):
    c[0] = c[0] * times
    c[1] = c[1] * times
    return c
vfx00 = loop_vfx(core.ffms2.Source('VFX__000.png', alpha=True), 118)
vfx01 = loop_vfx(core.ffms2.Source('VFX__118.png', alpha=True), 8)
vfx02 = loop_vfx(core.ffms2.Source('VFX__126.png', alpha=True), 18)
Thanks. And I imagine I would have to do something similar for concatenating the various vfx## clips together with the + operator.
Finally got the result I desired. Thankee for all your support.
overlay, transparency, transparent, vapoursynth, vsutils
