Old 10th August 2010, 21:41   #1  |  Link
The Brighter Writer
Posts: n/a
DVD/DV file stutters when deinterlaced?
Hello, dear community.
I've got a really annoying problem bringing a DV file to DVD.
The DV file is interlaced and has been captured with a Sony camcorder. When I play the file in VLC or the Windows Media Player, it runs fine ... as long as deinterlacing is not activated. When I turn deinterlacing on, the playback stutters heavily.
Now I've transcoded the file with AVStoDVD to a DVD image.
When I mark the title (my DV file) as interlaced and create a DVD image, this ISO features no interlacing but stutters in VLC and WMP.
When I don't mark it as interlaced, the ISO is interlaced but runs smoothly in VLC and WMP. But when I put it into my standalone DVD player, it stutters again. Maybe because the player tries to deinterlace it?
Your help would be very appreciated. I'm slowly freaking out.
The Brighter Writer
Old 11th August 2010, 01:47   #2  |  Link
Eric69
I dont get it. If it plays fine interlaced why are you deinterlacing? If you feel you must interlace the file first, are you encoding progressive?
Eric69 is offline   Reply With Quote
Old 11th August 2010, 02:25   #3  |  Link
mp3dom
It could depends by a lot of things:
- When you mark the file as interlaced, are you encoding as topfield or bottomfield. Generally DV is bottomfield. If you set the wrong field, the playback will be jerky
- Other interlaced files plays smooth on VLC and WMP?
- Setting an interlaced file as progressive, it's an error. The standalone players will assume the file as progressive so the playback will stutters (this explain your latest statement)
So first of all you need to check if your DV file was correctly encoded (bottomfield interlaced?).
Old 11th August 2010, 08:18   #4  |  Link
Ghitulescu
Ghitulescu's Avatar
It's because the normal deinterlacing process assumes TFF while DV is BFF.
Besides, have you used search, because this topic was discussed in the past, also there are guides how to transfer DV to DVD.
It stutters because of the deinterlacing. Leave it deinterlaced for DVD player (but remember the BFF issue).
Old 14th August 2010, 19:53   #5  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
You can find a very very very similar issue here.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
deinterlace, deinterlacing, dvd, interlaced
