Old 18th January 2017, 05:39   #42081  |  Link
the same?
Old 18th January 2017, 17:55   #42082  |  Link
Warner306
Originally Posted by 70MM View Post
Can someone clarify this for me please?
I play everything at 60Hz rather than 24Hz with my JVC X9000 proj. The reason you might ask is that have a film group and we screen mixed content, shorts, trailers etc before the feature. I set the 1080 video card to 60Hz as this way the horrible SLOW SYNC on the JVC is instant between shorts/trls.
I would like to run at 4K doubling, but each time I test I have issues even on low settings with any of the 30/60 material, I get skipped frames.
All other material is perfect 1080p etc when doubled, no problems at all, just 30/60 content I get skipped frames.
Is the problem due to me being on 60Hz rather than the normal that most would be using?
Can madvr not image double 30/60 fps material?
The image I have is out of this world so I can remain with everything upscaling to 1080p, but I just thought since many of the JVC forums are using 4K with madvr I too should.....
Interested in your thoughts???
Are you using profiles for different content (30 fps, 60 fps, etc.)? 30 fps material makes madVR work harder, so you need to have specific settings for that content alone.
Old 18th January 2017, 18:57   #42083  |  Link
70MM
X Cinema Projectionist NZ
Im not using profiles at all as I dont actually understand how they work.
As you know Warner I have to remain on 60Hz so the playlists I make up with mixed content 25/50/24/30/60 all sync instantly on my JVC X9000 proj.
So do profiles allow me to make a lower setting in image doubling just for the 30/60 content @60Hz. The all the rest (24/25/50 @60Hz) can have a higher setting in Image doubling?
If I can do that it would be fantastic!!!
70MM is offline   Reply With Quote
Old 18th January 2017, 19:21   #42084  |  Link
Warner306
Try reading here. There is some information on how to create profile groups (in the middle of the post). Follow the rules at the end of the post for 4K screens.
Don't worry about the settings posted. The guide needs to be updated.
Old 18th January 2017, 20:05   #42085  |  Link
70MM
Ive just read that Warner and it looks like I need to start using profiles, but it looks very difficult to set up
Old 18th January 2017, 20:28   #42086  |  Link
Warner306
It's not that bad. You can copy the rules I provided as a starting point.
Old 18th January 2017, 20:31   #42087  |  Link
70MM
Im sorry Warner but I still dont understand how to copy them in...Is there a tutorial how to do it?
Old 18th January 2017, 23:09   #42088  |  Link
cyberscott
If I run videos up scaled to 4K 60 Hz or 30Hz, dropped frames and the queues don't fill. If I run at 59 Hz and 29 Hz everything syncs and the queues fill. This is with a Nvidia GTX 1080. Try 59 Hz and 29 Hz and see if that helps.
cyberscott is offline   Reply With Quote
Old 18th January 2017, 23:11   #42089  |  Link
70MM
So you mean without using profiles?
Old 18th January 2017, 23:12   #42090  |  Link
Warner306
Follow the instructions in the post provided.
Copy the rules for a 4K display into the madVR control panel under "Scaling." Create profile groups for each profile and name it.
Old 18th January 2017, 23:14   #42091  |  Link
70MM
Can I still just leave the card at 1080 rather than 4K?
Old 18th January 2017, 23:21   #42092  |  Link
Warner306
You really need to read the link provided. It has all the answers.
Click on scaling algorithms. Create a new folder by selecting create profile group.
Each profile group offers a choice of settings to include.
Select all items, and name the new folder "Scaling."
Select the Scaling folder. Using add profile, create six profiles.
Name each profile: 1080p25, 1080p60, 720p25, 720p60, 540p25, 540p60.
Paste the code below into Scaling:
if (deintFps <= 25) and (srcWidth > 1280) "1080p25"
else if (deintFps <= 25) and ((srcWidth <= 1280) and (srcHeight > 720)) "1080p25"
else if (deintFps > 25) and (srcWidth > 1280) "1080p60"
else if (deintFps > 25) and ((srcWidth <= 1280) and (srcHeight > 720)) "1080p60"
else if (deintFps <= 25) and ((srcWidth > 960) and (srcWidth <= 1280)) "720p25"
else if (deintFps <= 25) and ((srcWidth <= 960) and (srcHeight > 540) and (srcHeight <= 720)) "720p25"
else if (deintFps > 25) and ((srcWidth > 960) and (srcWidth <= 1280)) "720p60"
else if (deintFps > 25) and ((srcWidth <= 960) and (srcHeight > 540) and (srcHeight <= 720)) "720p60"
else if (deintFps <= 25) and ((srcWidth <= 960) and (srcHeight <= 540)) "540p25"
else if (deintFps > 25) and ((srcWidth <= 960) and (srcHeight <= 540)) "540p60"
A green check mark should appear above the box to indicate the profiles are correctly named and no code conflicts exist.
Additional profile groups must be created for processing and rendering.
Note: The use of six profiles may be unnecessary for other profile groups. For instance, if I wanted Image enhancements (under processing) to apply only to 1080p content, two folders would be required:
if (srcWidth > 1280) "1080p"
else if (srcWidth <= 1280) and (srcHeight > 720) "1080p"
else "Other"
Profiles for 2160p displays:
if (deintFps <= 25) and (srcWidth > 1920) "2160p25"
else if (deintFps <= 25) and ((srcWidth <= 1920) and (srcHeight > 1080)) "2160p25"
else if (deintFps > 25) and (srcWidth > 1920) "2160p60"
else if (deintFps > 25) and ((srcWidth <= 1920) and (srcHeight > 1080)) "2160p60"
else if (deintFps <= 25) and ((srcWidth > 1280) and (srcWidth <= 1920)) "1080p25"
else if (deintFps <= 25) and ((srcWidth <= 1280) and (srcHeight > 720) and (srcHeight <= 1080)) "1080p25"
else if (deintFps > 25) and ((srcWidth > 1280) and (srcWidth <= 1920)) "1080p60"
else if (deintFps > 25) and ((srcWidth <= 1280) and (srcHeight > 720) and (srcHeight <= 1080)) "1080p60"
Change deintFps > 25 to whatever you deem necessary.
Old 19th January 2017, 02:33   #42093  |  Link
70MM
Thanks for that Warner, it certainly makes it easier to learn.
I will give it a go!
Can you tell me what uses more resources, 1080p @ 60 or 480 @ 60?
Old 19th January 2017, 03:31   #42094  |  Link
cyberscott
You can set that up under "Display Modes" in Madvr.
Old 19th January 2017, 09:23   #42095  |  Link
StinDaWg
The higher the resolution the more resources used.
At 4k... 1080p60 > 720p60 > 480p60
StinDaWg is offline   Reply With Quote
Old 19th January 2017, 10:47   #42096  |  Link
BluesFanUK
Also the higher the FPS the lower you're settings should be. 1080@30 you can use fairly high settings with most modern GPU's, 1080@60 and even a Titan X struggles when you start bumping up the settings.
BluesFanUK is offline   Reply With Quote
Old 19th January 2017, 12:05   #42097  |  Link
Mistery 73
curiosity ... madVR using the settings of the VPR / Tv affecting the image detail keep them to zero?
Mistery 73 is offline   Reply With Quote
Old 19th January 2017, 13:52   #42098  |  Link
koravei
Hello Madshi, is it possible to implement HLG (Hybrid Log-Gamma/ARIB STD-B67) in your HDR to SDR conversion?
Here is one demo in HDR - HLG: http://demo-uhd3d.com/fiche.php?cat=uhd&id=154
koravei is offline   Reply With Quote
Old 19th January 2017, 20:31   #42099  |  Link
steakhutzeee
steakhutzeee's Avatar
I'm experiencing strange issue with Madvr, a red vertical line, this happens fullscreen only with this movie, but with others i've it in th preview with MPC BE, if i disable Madvr red line disappears... what is causing the issue?
With this movie i'm experiencing lagging in the video, first time this happens with a movie. I'm on Intel i5-4590 and MSI R9 270X 2GB.
Any suggestion?
EDIT: Red line solved, problem was related to "Radeon Settings". I disabled 'Demo Mode' and problem solved, but why problem disappears if i disable Madvr too? Just curious...
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 20th January 2017, 01:43   #42100  |  Link
hannes69
Originally Posted by SweetLow View Post
1. Definitely, problem is inside streams
2. AFAIK, ffdshow or avisynt will help
I further investigated the problem. The videos have a resolution of 640x360. There seems to be a problem with display aspect ratio, stream aspect ratio, container aspect ratio. Iīm a little bit confused with the different areas where aspect ratios come into play. But I found out that one movieīs aspect ratio was declared as 1.772 in one place. When doing the math the other way leads to 361 lines when fixing the horizontal resolution to 640 (640 / 1.772 ~= 361). So there is no cropping needed, but a fix of the aspect ratio. I tried the setting in LAV video concerning the stream / container aspect ratio, but this didnīt change anything. Then I tried the settings in MPC HC -> View -> Video Frame -> Aspect Ratio and there I got success
The default DAR aspect ratio setting doesnīt work here. So I tried 16:9 and Assume square pixels (SAR). Both seem to work.
16:9 I assume is a kind of force, and the SAR setting uses the stream aspect ratio forced. I donīt understand what the difference is from the corresponding LAV video settings though...
But you were right SweetLow, didnīt forget that your first idea was mentioning a problem with the aspect ratio, you were absolutely right about that
Hannes.
hannes69 is offline   Reply With Quote
