16th January 2017, 10:38 | #42061 | Link |
Projectors will obviously take longer more bucks to be made with other Price Category
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 16th January 2017 at 11:33. |
16th January 2017, 10:47 | #42062 | Link | |
or this: http://www.avsforum.com/forum/139-di...libration.html |
16th January 2017, 12:25 | #42063 | Link | |
16th January 2017, 13:17 | #42064 | Link |
Guys, I'm having problems with getting HDR to work.
I have an HDR capable TV (Panasonic dx780) and I have set madVR to passthrough HDR to my display but the colors are washed out and HDR mode isn't triggered. I'm using HDR demos and they work when played through USB. What am I doing wrong? |
16th January 2017, 14:12 | #42065 | Link |
As far as I know, you're not doing anything wrong.
You can't 'trigger' HDR mode as you say it from a PC (or MadVR can't yet). You need to manually tell your TV to enable HDR processing. Written as someone who does not have an HDR tv so I'm not up to speed on all the latest HDR-developments. |
16th January 2017, 15:20 | #42067 | Link | ||
Regarding this:
when watched on 720p projector. Quote:
In the meantime I have found out (I hope so) whatīs going on. In madVRīs OSD the movies are shown as 640x360. In MPC HCīs movie properties within the mediainfo part they are shown as well as 640x360. But in properties - details part the movies are shown as 641x360 (movie of first screenshot) or 640x361 (second screenshot). I think I canīt handle this problem with the given setting possibilities in madVR at the moment. I can crop the borders within madVR, but only ALL borders at the same time. So 641x360 -> 639x358 ; 640x361 -> 638x359. They are doubled then. 639x358 -> 1278x716 ; 638x359 -> 1276x718. And then scaled to 1280x720. The "disable scaling if image size changes" of course works when displaying at 640x360 and no scaling at all. But this doesnīt work with first doubling and do further scaling afterwards. Of course my hardware is a little bit oldschool being 720p, but the problem will be exactly the same when e.g doubling 1080p to 2160p and having movies with not exact 1920x1080. Maybe I have overlooked a possibility within madVR, maybe "misusing" certain settings that arenīt originally intended for doing that... So what would be needed is an option for cropping single borders. If I could crop the single line or the single additonal horizontal pixel before doubling, then everything would be fine... Hannes. |
16th January 2017, 16:19 | #42068 | Link | |
16th January 2017, 17:31 | #42069 | Link | ||
this question come about every 2 weeks and everything you need to know is written on the setting page. Quote:
the major difference between 8 bit and 10 bit madVR output is that the high bit deep data is dithered to 10 not 8 bit the rest is the same. so the same gamma settings are applied same scaler same everything. so what do you understand under "over-saturated colors". AMD high bit deep output works totally fine and madVR isn't doing something special either. so this leave you with your TV. so what TV is that and be aware that nearly every TV out there even the HDR ones are 8 bit. |
16th January 2017, 21:11 | #42070 | Link | ||
17th January 2017, 11:48 | #42071 | Link | |
Standards is here:
https://msdn.microsoft.com/en-us/lib...(v=vs.85).aspx but question is where it is implemented Quote:
2. AFAIK, ffdshow or avisynt will help Last edited by SweetLow; 17th January 2017 at 11:57. |
17th January 2017, 14:41 | #42072 | Link | |
I've found the source of my problem, i was using lav in native and not in copy-back, now (cb) it is possible to use color & gamma setting to adjust 10bit output mode. Thank you now all is perfect |
17th January 2017, 22:36 | #42074 | Link |
about OC nvidia memory
I have a question. The video card memory speed (nvidia 1080 in my case) affect the performance of Madvr? Is it convenient or useful OC the memory?
"To infinity, and beyond!" |
17th January 2017, 23:00 | #42076 | Link | |
So, it is better only OC the GPU and leave the original memory speed. Right?
"To infinity, and beyond!" Last edited by Oguignant; 17th January 2017 at 23:27. |
18th January 2017, 02:50 | #42077 | Link |
Madshi, I'd like to be able to cycle through selected profiles using the same key combination.
This would make it easy to review during playback what profile may be viewed as best for the playing content without needing to remember various key combinations for each suitable profile. Can you add support for this please? |
18th January 2017, 05:09 | #42078 | Link |
X Cinema Projectionist NZ
Can someone clarify this for me please?
I play everything at 60Hz rather than 24Hz with my JVC X9000 proj. The reason you might ask is that have a film group and we screen mixed content, shorts, trailers etc before the feature. I set the 1080 video card to 60Hz as this way the horrible SLOW SYNC on the JVC is instant between shorts/trls. I would like to run at 4K doubling, but each time I test I have issues even on low settings with any of the 30/60 material, I get skipped frames. All other material is perfect 1080p etc when doubled, no problems at all, just 30/60 content I get skipped frames. Is the problem due to me being on 60Hz rather than the normal that most would be using? Can madvr not image double 30/60 fps material? The image I have is out of this world so I can remain with everything upscaling to 1080p, but I just thought since many of the JVC forums are using 4K with madvr I too should..... Interested in your thoughts??? |
