10th March 2016, 06:49 | #36781 | Link | |
super-xbr and NNEDI3 look similar with SuperRes, but super-xbr will enhance any existing ringing, while NNEDI3 will not. If you can't see ringing, or if doesn't bother you, use super-xbr.
10th March 2016, 09:27 | #36784 | Link |
Sorry if this has been asked before. 1840 pages was daunting, and I couldn't find an answer searching.
I have 2 displays. If I set the viewing display to secondary I get dropped frames and glitches. If I'm doing nothing on the PC it drops a frame and produces a glitch every 7 seconds on the dot. I timed it.. bizarre. If I start using the pc on the primary monitor the video drops frames and glitches rapidly. Is any of this a known issue? I've changed and disabled every single setting in MadVR, to no avail. I use Lav Filters and Zoom Player. Thinking about it now I'll try with MPC-HC. I hope it isn''t the player cos I really don't like any others. |
10th March 2016, 11:49 | #36786 | Link |
I am using last development versions of MPC-HC and LAVFilters.
I updated yesterday from madVR 0.9010 to 0.9015. When I try to play videos I get sound but not image, not in window mode, neither in fullscreen (curiously, with the last version of PotPlayer+MadVR I have image in fullscreen mode but not in window mode). This happens with vids at 1080p and codec H264. It doesn't happen with vids at 480p and codec H264. The problem appears with version 0.9011. I have returned to madVR 0.9010 and the problem has disappeared. |
10th March 2016, 14:07 | #36789 | Link |
When doing 1080p to 2160p upscale with MadVr, I get some video judders (every 15/20 sec) on my UHD TV (2160p/60Hz & HDCP 2.2). The video input signal on my TV is well seen as 2160p. I tested several video rates: 23.976Hz, 24 Hz, ... Same issue. No dropped/delayed/... frame on MadVr. My GC is a Nvidia 970 GTX. How come ? When playing back a 2160p video directly on the TV (with an usb key for example), no problem. |
10th March 2016, 14:34 | #36790 | Link | |
Hi madshi, I kept getting black screens with 90.15, with Chroma NNEDI enabled, Doublind disabled, Chroma Jinc and Doubling NNEDI, and obviously with both using NNEDI. I need to check without using NNEDI at all. I always use NNEDI 32 Neurons for the tests. Black screens are really random, first one occurs after more than 50 minutes of playback, so testing requires lots of time. |
10th March 2016, 15:13 | #36791 | Link |
non-framepacked 3D output is broken in 0.90.15.
SBS only has the right eye showing, TB only the bottom, line interleaved is entirely black, and column interleaved behaves just like SBS (which seems odd in itself). On top of that, if i tick the swap eye checkbox, it becomes entirely black all the time. When I pause playback the image shows up properly, but goes away again when I play again, at least for SBS and TB, interleaved seems to always stay dead. On the same note, it would be nice if "auto" 3D mode would not switch the resolution if the OS doesn't even offer a stereo 3d mode in the control panel.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 10th March 2016 at 15:23. |
10th March 2016, 15:42 | #36792 | Link | |
10th March 2016, 17:45 | #36795 | Link | |||
I tested DXVA and it's not really better. Decoder queue go higher than before but I also have dropped frames when render queue drops down. Here some videos of my tests, I hope it will be usefull and easier for you to understand. http://www.filedropper.com/testdeinterlacing1_1 (It's the first time I'm using this file hosting website, I don't know what it worths). Quote:
Windows 8.1 and 10 x64 - Intel Core i5-4670K (4.2 GHz) - 8 GB DDR3 - MSI Geforce GTX 1080 8 GB - Sony KD-55A1 - Denon AVR-X3600H Last edited by Werewolfy; 10th March 2016 at 20:43. |
10th March 2016, 18:22 | #36796 | Link | |
Visual Novel Dev.
It does not work well with animated videos, inducing grain, and what could be perceived as noise.
Visual Novels! https://www.facebook.com/seventh.heart.studios/ https://audiophile-heaven.blogspot.com/ https://www.youtube.com/watch?v=27VWU3ydRY8 |
10th March 2016, 21:03 | #36797 | Link | |
Are you referring to some DXVA deinterlacing quality issues? At least deinterlacing seems to work glitch-free to my eyes, so I'm just curious what problems you are referring to. |
10th March 2016, 22:49 | #36798 | Link | |
Example 1 (1080p supersampling): Chroma - jinc Doubling - superxbr 100 Enhancements - crispen edges 1, enhance detail 1, superres 3 Downscaling - ssim 1d =30ms rendering time Example 2 (1080p supersampling): Chroma - jinc Doubling - superxbr 100 Enhancements - crispen edges 1, enhance detail 1, superres 3 Downscaling - ssim 2d =70ms rendering time As you can see, the only difference between the two examples is 1d / 2d, with 2d adding 40ms to rendering times. Surely, that can't be right? Like I said, in every other downscaling or doubling and then downscaling scenario 2d is perfectly usable. |
10th March 2016, 23:13 | #36799 | Link | |
and nvidia deint was kind of "broken" the last time i check and had issue with telecine/hybrid content. the high quality CUVID deint is not usable at all under windows 10. |
