30th September 2019, 21:08 | #17361 | Link | |
ByteShare
Had to run a job, used the same job that was getting ~12 FPS with these filters: `FastLineDarkenMOD4().LSFmod()` Found I was only getting ~2FPS, so yeah, Mdegrain is the slow down (I was wrong, wasn't to do with my GPU, sorry), but (not using DEmode) only using ~33% (20%-40% seems to be the range) of the CPU during encode, so it seems the multiple processing threads isn't working for some reason? I have the "Limit to following filters only" unchecked. Last edited by byteshare; 30th September 2019 at 21:11. |
30th September 2019, 21:56 | #17362 | Link |
Show me your full script
1st October 2019, 03:51 | #17363 | Link |
ByteShare
I ran it on a Ryzen 1700. I ran a similar test on a Ryzen 2700x and it is using more CPU ~60% in AVSmeter, which is showing correctly (not scrolling the data).
Update: Re-ran the above test after another reboot and an update to RB the AVSmeter isn't scrolling and not sure what you changed but it is using way more CPU and I'm getting ~9 FPS now! Awesome, thank you! Last edited by byteshare; 2nd October 2019 at 20:47. |
1st October 2019, 19:04 | #17364 | Link |
ByteShare
Something I'm noticing with the new update (now that my jobs are going faster!) is most of the jobs are failing at the remux step.
I don't think it is the filename, unless it is the "-" and if I manually run the batch file to make the video.265 it works fine and the video looks good. I have at least 4 others I am able to see this happening on and two others that worked correctly. I am only encoding the video (skipping the demux step in the options to skip audio) Update: Set my last update time to 2016, don't see any new updates, my Core is 2019.09.30. Added a job that was failing again, and it failed again. only characters not ABC123, were brackets and a dash: "[" "]" "-" Last edited by byteshare; 2nd October 2019 at 20:45. |
2nd October 2019, 11:05 | #17366 | Link |
No. You have to pass that data on your own.
2nd October 2019, 11:43 | #17367 | Link |
Possible cpu or windows bug, slow encode
Noticed when encoding some anime, using very slow and animation tunes, that my intel i5 9100f doesn’t use 100% cpu. It seems to max 2 cores and about 70-80% the other 4 cores.
The result is 2-4fps. But if I open taskmgr it will then creep upto 16fps, this is on the first pass of a 2 pass encode. So when I left some encodes to run 2 took nearly 3 hrs for 23min of video. But then the last 2 took 45mins. As I think I checked the cpu usage. It’s like rip bot is dozing until the pc is used. |
2nd October 2019, 12:51 | #17368 | Link |
Most likely win10 is doing something "Smart". Change power profile to high performance
2nd October 2019, 18:58 | #17370 | Link |
Not yet. Maybe in next update.
2nd October 2019, 22:17 | #17371 | Link |
There is a problem
If I run a job again, the program doesn't overwrite the previous file. I have to rename the old, for the new to be created EDIT To be more precise, running CombineAllChunks.cmd, doesn't overwrite existing video.264/5 in jobx folder EDIT 2 Delete previous line Something else is happening and overwrite doesn't work
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B Last edited by slalom; 3rd October 2019 at 12:36. |
3rd October 2019, 13:18 | #17372 | Link |
4K Disc Seamless Branching Causing Audio Sync Issue
Just wanted to bring this up again. I don't know how it would just be me though. I installed fresh versions of Ripbot264 a month or so ago and the 4K seamless branching is still causing issues. From a previous post:
I rip a 4K disc to the hard drive that has seamless branching, such as Incredibles 2. I then use Ripbot to pull in the movie and process it. The output will have out of sync audio towards the end of the movie. I think this only happens on 4K discs that are towards 2 hours or longer. Just had to go through this with Ralph Breaks the Internet and Snow White and the Huntsman Extended edition. The work around I've been doing is to use MakeMKV to create a video file from the same source and then pull that into Ripbot to process it and it comes out fine. This time the 4K disc in question is Ratatouille. Is anyone else experiencing this? |
3rd October 2019, 15:28 | #17373 | Link | |
ByteShare
3rd October 2019, 21:04 | #17377 | Link | |
4th October 2019, 12:03 | #17378 | Link | ||
This only seems to occur on 4K content. Blu-ray seamless branching seems to work great and I have no issues. |
4th October 2019, 18:17 | #17380 | Link | |
ByteShare
--Update, might be more to it but I'm having the issue on more than one machine for jobs not muxing at the end (was only using one for a bit), so two separate machines with different sources running DE mode locally. Running The batch CombineAllChunks then job1_MuxFiles works fine when I do it manually, so for now I'm run the combineallchunks then the jobxx_muxfiles batch manually. :/ Code:
"Z:\Temp\RipBot264temp\job1\video.265" mkvmerge v37.0.0 ('Leave It') 64-bit Error: The file 'Z:\Temp\RipBot264temp\job1\video.265' could not be opened for reading: open file error. Last edited by byteshare; 5th October 2019 at 08:35. |
